Batterij vervangen van remote control van RAV bouwjaar 2000. Nu reageert de auto er niet meer op. Moet opnieuw ingelezen worden. Ben op zoek naar een instructie voor een RAV4 bouwjaar 2000. Kan wel instructies vinden vanaf 2001 maar niet van 2000. Wie kan mij daar aan helpen?
Niet gevonden wat je zocht? Misschien is je vraag al eens beantwoord voor je Toyota RAV4 of stel zelf een nieuwe vraag.
NOTE : Make sure the drivers door OPEN and UNLOCKED, and the key is out of the ignition.
1. Insert the key into the ignition and remove it, do not turn.
2. LOCK and UNLOCK 5 times using the door control switch within 40 seconds.
3. CLOSE the drivers door and OPEN it.
4. LOCK and UNLOCK 5 times using the door control switch within 40 seconds again.
5. Insert the key into the ignition.
6. Turn the ignition switch from LOCK to ON and back to LOCK at about 1 second intervals
to select the desired mode :
NOTE : 1 time for ADD.
NOTE : 2 times for REWRITE.
NOTE : 3 times for CONFIRMATION.
NOTE : 5 times for PROHIBITION.
7. Remove the key from the ignition.
8. To confirm your selection of all modes except CONFIRMATION, the power locks
will now cycle LOCK to UNLOCK a number of times corresponding to your key cycles
in step 6.
NOTE : If CONFIRMATION mode has been selected, the power door locks will now cycle
(in 2 seconds intervals) a number of times corresponding to the number of transmitters currently
registered.
NOTE : Closing the door will complete the procedure.
NOTE : If PROHIBITION mode has been selected, closing the door will complete the
procedure.
9. For ADD or REWRITE modes, within 20 seconds of Door Lock confirmation:
(a) Press the transmitter LOCK button for more than 1 second and release.
(b) If the door control receiver has received the signal from the transmitter, the power locks will
cycle LOCK to UNLOCK once at this time. If there is no response, return to step 1.
(c) Close the driver�s door and open it.
(d) Press the transmitter LOCK button for more than 1 second and release again.
(e) If the transmitter has been successfully programmed, the power locks will cycle LOCK to UNLOCK.
once at this time. If there are problems with the procedure used up to this point, the locks
will cycle twice, in which case you must go back and repeat the above steps (a) to (d).
(f) If multiple transmitters are to be programmed, repeat the above steps (a) to (e).
10. Close the drivers door to complete the procedure
