Algemeen: alle OBD2 codes *engels*
Alle OBD2 codes : P0*** !!! nog niet alle merk eigen P1*** etc *disclamer: ik & problem car zijn NIET aanspakelijk voor eventuele fouten hier in, nog gevolg schade hier door*
[b]P0010-P0099 Fuel and Air Metering and Auxiliary Emission Controls[/b]
P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1)
P0013 "B" Camshaft Position - Actuator Circuit (Bank 1)
P0014 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1) - See Trouble Code P0011
P0015 "B" Camshaft Position -Timing Over-Retarded (Bank 1) - See Trouble Code P0012
P0020 "A" Camshaft Position Actuator Circuit (Bank 2)
P0021 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
P0023 "B" Camshaft Position - Actuator Circuit (Bank 2) - See Trouble Code P0020
P0024 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) - See Trouble Code P0021
P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2) - See Trouble Code P0022
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
P0033 Turbo Charger Bypass Valve Control Circuit
P0034 Turbo Charger Bypass Valve Control Circuit Low
P0035 Turbo Charger Bypass Valve Control Circuit High
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
P0040 Upstream Oxygen Sensors Swapped From Bank To Bank
P0041 Downstream Oxygen Sensors Swapped From Bank To Bank
P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
P0061 HO2S Heater Resistance (Bank 2, Sensor 3)
P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector Control Range/Performance
P0066 Air Assisted Injector Control Circuit or Circuit Low
P0067 Air Assisted Injector Control Circuit High
P0070 Ambient Air Temperature Sensor Circuit
P0071 Ambient Air Temperature Sensor Range/Performance
P0072 Ambient Air Temperature Sensor Circuit Low Input
P0073 Ambient Air Temperature Sensor Circuit High Input
P0074 Ambient Air Temperature Sensor Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0081 Intake valve Control Solenoid Circuit (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
[b]DTC Codes - P0100-P0199 Fuel and Air Metering[/b]
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0109 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle Position Sensor/Switch A Circuit Malfunction
P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle Position Sensor/Switch A Circuit Low Input
P0123 Throttle Position Sensor/Switch A Circuit High Input
P0124 Throttle Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I)
P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1)
P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2)
P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3)
P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3)
P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3)
P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3)
P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3)
P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I)
P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I)
P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System too Lean (Bank 2)
P0175 System too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
[b]DTC Codes - P0200-P0299 Fuel and Air Metering (Injector Circuit)[/b]
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0207 Injector Circuit Malfunction - Cylinder 7
P0208 Injector Circuit Malfunction - Cylinder 8
P0209 Injector Circuit Malfunction - Cylinder 9
P0210 Injector Circuit Malfunction - Cylinder 10
P0211 Injector Circuit Malfunction - Cylinder 11
P0212 Injector Circuit Malfunction - Cylinder 12
P0213 Cold Start Injector 1 Malfunction
P0214 Cold Start Injector 2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Turbocharger Wastegate Solenoid A Malfunction
P0244 Turbocharger Wastegate Solenoid A Range/Performance
P0245 Turbocharger Wastegate Solenoid A Low
P0246 Turbocharger Wastegate Solenoid A High
P0247 Turbocharger Wastegate Solenoid B Malfunction
P0248 Turbocharger Wastegate Solenoid B Range/Performance
P0249 Turbocharger Wastegate Solenoid B Low
P0250 Turbocharger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance Injector)
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/R
P0259 Injection Pump Fuel Metering Control "B" High (Cam/R
P0260 Injection Pump Fuel Metering Control "B" Intermittent Injector)
P0261 Cylinder I Injector Circuit Low
P0262 Cylinder I Injector Circuit High
P0263 Cylinder I Contribution/Balance Fault
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder S Contribution/Balance Fault
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance Fault
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance Fault
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance Fault
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance Fault
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance Fault
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Range Fault
[b]DTC Codes - P0300-P0399 Ignition System or Misfire[/b]
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction (Bank I or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank I or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank I or Single Sensor)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Exhaust Gas Recirculation Flow Malfunction
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
[b]DTC Codes - P0400-P0499 Auxiliary Emissions Controls[/b]
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Relay A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0456 Evaporative Emissions System - Small leak detected
P0457
P0458
P0459
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan I Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
[b]DTC Codes - P0500-P0599 Vehicle Speed Controls and Idle Control System[/b]
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
[b]DTC Codes - P0600-P0699 Computer Output Circuit[/b]
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS Output "A Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfunction
P0656 Fuel Level Output Circuit Malfunction
[b]DTC Codes - P0700-P0899 Transmission[/b]
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear I Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque Converter Clutch Circuit Malfunction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stock On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stock Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
Renaultmonteurtje
33.765 km
al 18 jaar lid
[b]Audi Specific Trouble Codes [/b]
P1101 O2 Sensor Circ.,Bank1-Sensor1Voltage too Low/Air Leak
P1102 O2 Sensor Heating Circ.,Bank1-Sensor1 Short to B+
P1103 O2 Sensor Heating Circ.,Bank1-Sensor1 Output too Low
P1104 Bank1-Sensor2 Voltage too Low/Air Leak
P1105 O2 Sensor Heating Circ.,Bank1-Sensor2 Short to B+
P1106 O2 Sensor Circ.,Bank2-Sensor1 Voltage too Low/Air Leak
P1107 O2 Sensor Heating Circ.,Bank2-Sensor1 Short to B+
P1108 O2 Sensor Heating Circ.,Bank2-Sensor1 Output too Low
P1109 O2 Sensor Circ.,Bank2-Sensor2 Voltage too Low/Air Leak
P1110 O2 Sensor Heating Circ.,Bank2-Sensor2 Short to B+
P1111 O2 Control (Bank 1) System too lean
P1112 O2 Control (Bank 1) System too rich
P1113 Bank1-Sensor1 Internal Resistance too High
P1114 Bank1-Sensor2 Internal Resistant too High
P1115 O2 Sensor Heater Circ.,Bank1-Sensor1 Short to Ground
P1116 O2 Sensor Heater Circ.,Bank1-Sensor1 Open
P1117 O2 Sensor Heater Circ.,Bank1-Sensor2 Short to Ground
P1118 O2 Sensor Heater Circ.,Bank1-Sensor2 Open
P1119 O2 Sensor Heater Circ.,Bank2-Sensor1 Short to Ground
P1120 O2 Sensor Heater Circ.,Bank2-Sensor1 Open
P1121 O2 Sensor Heater Circ.,Bank2-Sensor2 Short to Ground
P1122 O2 Sensor Heater Circ.,Bank2-Sensor2 Open
P1123 Long Term Fuel Trim Add.Air.,Bank1 System too Rich
P1124 Long Term Fuel Trim Add.Air.,Bank1 System too Lean
P1125 Long Term Fuel Trim Add.Air.,Bank2 System too Rich
P1126 Long Term Fuel Trim Add.Air.,Bank2 System too Lean
P1127 Long Term Fuel Trim mult.,Bank1 System too Rich
P1128 Long Term Fuel Trim mult.,Bank1 System too Lean
P1129 Long Term Fuel Trim mult.,Bank2 System too Rich
P1130 Long Term Fuel Trim mult.,Bank2 System too Lean
P1131 Bank2-Sensor1 Internal Rsistance too High
P1132 O2 Sensor Heating Circ.,Bank1+2-Sensor1 Short to B+
P1133 O2 Sensor Heating Circ.,Bank1+2-Sensor1 Electrical Malfunction
P1134 O2 Sensor Heating Circ.,Bank1+2-Sensor2 Short to B+
P1135 O2 Sensor Heating Circ.,Bank1+2-Sensor2 Electrical Malfunction
P1136 Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
P1137 Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
P1138 Long Term Fuel Trim Add.Fuel,Bank2 System too Lean
P1139 Long Term Fuel Trim Add.Fuel,Bank2 System too Rich
P1140 Bank2-Sensor2 Internal Resistance too High
P1141 Load Calculation Cross Check Range/Performance
P1142 Load Calculation Cross Check Lower Limit Exceeded
P1143 Load Calculation Cross Check Upper Limit Exceeded
P1144 Mass or Volume Air Flow Circ Open/Short to Ground
P1145 Mass or Volume Air Flow Circ Short to B+
P1146 Mass or Volume Air Flow Circ Supply Malfunction
P1147 O2 Control (Bank 2) System too lean
P1148 O2 Control (Bank 2) System too rich
P1149 O2 Control (Bank 1) Out of range
P1150 O2 Control (Bank 2) Out of range
P1151 Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded
P1152 Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded
P1154 Manifold Switch Over Malfunction
P1155 Manifold Abs.Pressure Sensor Circ. Short to B+
P1156 Manifold Abs.Pressure Sensor Circ. Open/Short to Ground
P1157 Manifold Abs.Pressure Sensor Circ. Power Supply Malfunction
P1158 Manifold Abs.Pressure Sensor Circ. Range/Performance
P1160 Manifold Temp.Sensor Circ. Short to Ground
P1161 Manifold Temp.Sensor Circ. Open/Short to B+
P1162 Fuel Temp.Sensor Circ. Short to Ground
P1163 Fuel Temp.Sensor Circ. Open/Short to B+
P1164 Fuel Temperature Sensor Range/Performance/Incorrect Signal
P1165 Bank1, Long Term Fuel Trim, Range 1 Rich Limit Exceeded
P1166 Bank1, Long Term Fuel Trim, Range 2 Rich Limit Exceeded
P1171 Throttle Actuation Potentiometer Sign.2 Range/Performance
P1172 Throttle Actuation Potentiometer Sign.2 Signal too Low
P1173 Throttle Actuation Potentiometer Sign.2 Signal too High
P1174 Fuel Trim, Bank 1 Different injection times
P1176 O2 Correction Behind Catalyst,B1 Limit Attained
P1177 O2 Correction Behind Catalyst,B2 Limit Attained
P1178 Linear 02 Sensor / Pump Current Open Circuit
P1179 Linear 02 Sensor / Pump Current Short to ground
P1180 Linear 02 Sensor / Pump Current Short to B+
P1181 Linear 02 Sensor / Reference Voltage Open Circuit
P1182 Linear 02 Sensor / Reference Voltage Short to ground
P1183 Linear 02 Sensor / Reference Voltage Short to B+
P1184 Linear 02 Sensor / Common Ground Wire Open Circuit
P1185 Linear 02 Sensor / Common Ground Wire Short to ground
P1186 Linear 02 Sensor / Common Ground Wire Short to B+
P1187 Linear 02 Sensor / Compens. Resistor Open Circuit
P1188 Linear 02 Sensor / Compens. Resistor Short to ground
P1189 Linear 02 Sensor / Compens. Resistor Short to B+
P1190 Linear 02 Sensor / Reference Voltage Incorrect Signal
P1196 O2 Sensor Heater Circ.,Bank1-Sensor1 Electrical Malfunction
P1197 O2 Sensor Heater Circ.,Bank2-Sensor1 Electrical Malfunction
P1198 O2 Sensor Heater Circ.,Bank1-Sensor2 Electrical Malfunction
P1199 O2 Sensor Heater Circ.,Bank2-Sensor2 Electrical Malfunction
P1201 Cyl.1-Fuel Inj.Circ. Electrical Malfunction
P1202 Cyl.2-Fuel Inj.Circ. Electrical Malfunction
P1203 Cyl.3-Fuel Inj.Circ. Electrical Malfunction
P1204 Cyl.4-Fuel Inj.Circ. Electrical Malfunction
P1205 Cyl.5-Fuel Inj.Circ. Electrical Malfunction
P1206 Cyl.6-Fuel Inj.Circ. Electrical Malfunction
P1207 Cyl.7-Fuel Inj.Circ. Electrical Malfunction
P1208 Cyl.8-Fuel Inj.Circ. Electrical Malfunction
P1209 Intake valves for cylinder shut-off Short circuit to ground
P1210 Intake valves for cylinder shut-off Short to B+
P1211 Intake valves for cylinder shut-off Open circuit
P1213 Cyl.1-Fuel Inj.Circ. Short to B+
P1214 Cyl.2-Fuel Inj.Circ. Short to B+
P1215 Cyl.3-Fuel Inj.Circ. Short to B+
P1216 Cyl.4-Fuel Inj.Circ. Short to B+
P1217 Cyl.5-Fuel Inj.Circ. Short to B+
P1218 Cyl.6-Fuel Inj.Circ. Short to B+
P1219 Cyl.7-Fuel Inj.Circ. Short to B+
P1220 Cyl.8-Fuel Inj.Circ. Short to B+
P1221 Cylinder shut-off exhaust valves Short circuit to ground
P1222 Cylinder shut-off exhaust valves Short to B+
P1223 Cylinder shut-off exhaust valves Open circuit
P1225 Cyl.1-Fuel Inj.Circ. Short to Ground
P1226 Cyl.2-Fuel Inj.Circ. Short to Ground
P1227 Cyl.3-Fuel Inj.Circ. Short to Ground
P1228 Cyl.4-Fuel Inj.Circ. Short to Ground
P1229 Cyl.5-Fuel Inj.Circ. Short to Ground
P1230 Cyl.6-Fuel Inj.Circ. Short to Ground
P1231 Cyl.7-Fuel Inj.Circ. Short to Ground
P1232 Cyl.8-Fuel Inj.Circ. Short to Ground
P1237 Cyl.1-Fuel Inj.Circ. Open Circ.
P1238 Cyl.2-Fuel Inj.Circ. Open Circ.
P1239 Cyl.3-Fuel Inj.Circ. Open Circ.
P1240 Cyl.4-Fuel Inj.Circ. Open Circ.
P1241 Cyl.5-Fuel Inj.Circ. Open Circ.
P1242 Cyl.6-Fuel Inj.Circ. Open Circ.
P1243 Cyl.7-Fuel Inj.Circ. Open Circ.
P1244 Cyl.8-Fuel Inj.Circ. Open Circ.
P1245 Needle Lift Sensor Circ. Short to Ground
P1246 Needle Lift Sensor Circ. Range/Performance
P1247 Needle Lift Sensor Circ. Open/Short to B+
P1248 Injection Start Control Deviation
P1249 Fuel consumption signal Electrical Fault in Circuit
P1250 Fuel Level Too Low
P1251 Start of Injection Solenoid Circ Short to B+
P1252 Start of Injection Solenoid Circ Open/Short to Ground
P1253 Fuel consumption signal Short to ground
P1254 Fuel consumption signal Short to B+
P1255 Engine Coolant Temp.Circ Short to Ground
P1256 Engine Coolant Temp.Circ Open/Short to B+
P1257 Engine Coolant System Valve Open
P1258 Engine Coolant System Valve Short to B+
P1259 Engine Coolant System Valve Short to Ground
P1280 Fuel Inj.Air Contr.Valve Circ. Flow too Low
P1283 Fuel Inj.Air Contr.Valve Circ. Electrical Malfunction
P1284 Fuel Inj.Air Contr.Valve Circ. Open
P1285 Fuel Inj.Air Contr.Valve Circ. Short to Ground
P1286 Fuel Inj.Air Contr.Valve Circ. Short to B+
P1287 Turbocharger bypass valve open
P1288 Turbocharger bypass valve short to B+
P1289 Turbocharger bypass valve short to ground
P1296 Cooling system malfunction
P1297 Connection turbocharger - throttle valve pressure hose
P1300 Misfire detected Reason: Fuel level too low
P1319 Knock Sensor 1 Circ. Short to Ground
P1320 Knock Sensor 2 Circ. Short to Ground
P1321 Knock Sensor 3 Circ. Low Input
P1322 Knock Sensor 3 Circ. High Input
P1323 Knock Sensor 4 Circ. Low Input
P1324 Knock Sensor 4 Circ. High Input
P1325 Cyl.1-Knock Contr. Limit Attained
P1326 Cyl.2-Knock Contr. Limit Attained
P1327 Cyl.3-Knock Contr. Limit Attained
P1328 Cyl.4-Knock Contr. Limit Attained
P1329 Cyl.5-Knock Contr. Limit Attained
P1330 Cyl.6-Knock Contr. Limit Attained
P1331 Cyl.7-Knock Contr. Limit Attained
P1332 Cyl.8-Knock Contr. Limit Attained
P1335 Engine Torque Monitoring 2 Control Limint Exceeded
P1336 Engine Torque Monitoring Adaptation at limit
P1337 Camshaft Pos.Sensor,Bank1 Short to Ground
P1338 Camshaft Pos.Sensor,Bank1 Open Circ./Short to B+
P1339 Crankshaft Pos./Engine Speed Sensor Cross Connected
P1340 Crankshaft-/Camshaft Pos.Sens.Signals Out of Sequence
P1341 Ignition Coil Power Output Stage 1 Short to Ground
P1342 Ignition Coil Power Output Stage 1 Short to B+
P1343 Ignition Coil Power Output Stage 2 Short to Ground
P1344 Ignition Coil Power Output Stage 2 Short to B+
P1345 Ignition Coil Power Output Stage 3 Short to Ground
P1346 Ignition Coil Power Output Stage 3 Short to B+
P1347 Bank2,Crankshaft-/Camshaft os.Sens.Sign. Out of Sequence
P1348 Ignition Coil Power Output Stage 1 Open Circuit
P1349 Ignition Coil Power Output Stage 2 Open Circuit
P1350 Ignition Coil Power Output Stage 3 Open Circuit
P1354 Modulation Piston Displ.Sensor Circ. Malfunction
P1355 Cyl. 1, ignition circuit Open Circuit
P1356 Cyl. 1, ignition circuit Short to B+
P1357 Cyl. 1, ignition circuit Short to ground
P1358 Cyl. 2, ignition circuit Open Circuit
P1359 Cyl. 2, ignition circuit Short Circuit to B+
P1360 Cyl. 2, ignition circuit Short Circuit to Ground
P1361 Cyl. 3, ignition circuit Open Circuit
P1362 Cyl. 3, ignition circuit Short Circuit to B+
P1363 Cyl. 3, ignition circuit Short Circuit to ground
P1364 Cyl. 4 ignition circuit Open Circuit
P1365 Cyl. 4 ignition circuit Short circuit to B+
P1366 Cyl. 4 ignition circuit Short circuit to ground
P1367 Cyl. 5, ignition circuit Open Circuit
P1368 Cyl. 5, ignition circuit Short Circuit to B+
P1369 Cyl. 5, ignition circuit short to ground
P1370 Cyl. 6, ignition circuit Open Circuit
P1371 Cyl. 6, ignition circuit Short Circuit to B+
P1372 Cyl. 6, ignition circuit short to ground
P1373 Cyl. 7, ignition circuit Open Circuit
P1374 Cyl. 7, ignition circuit Short Circuit to B+
P1375 Cyl. 7, ignition circuit short to ground
P1376 Cyl. 8, ignition circuit Open Circuit
P1377 Cyl. 8, ignition circuit Short Circuit to B+
P1378 Cyl. 8, ignition circuit short to ground
P1386 Internal Control Module Knock Control Circ.Error
P1387 Internal Contr. Module altitude sensor error
P1388 Internal Contr. Module drive by wire error
P1391 Camshaft Pos.Sensor,Bank2 Short to Ground
P1392 Camshaft Pos.Sensor,Bank2 Open Circ./Short to B+
P1393 Ignition Coil Power Output Stage 1 Electrical Malfunction
P1394 Ignition Coil Power Output Stage 2 Electrical Malfunction
P1395 Ignition Coil Power Output Stage 3 Electrical Malfunction
P1396 Engine Speed Sensor Missing Tooth
P1397 Engine speed wheel Adaptation limit reached
P1398 Engine RPM signal, TD Short to ground
P1399 Engine RPM signal, TD Short Circuit to B+
P1400 EGR Valve Circ Electrical Malfunction
P1401 EGR Valve Circ Short to Ground
P1402 EGR Valve Circ Short to B+
P1403 EGR Flow Deviation
P1404 EGR Flow Basic Setting not carried out
P1406 EGR Temp.Sensor Range/Performance
P1407 EGR Temp.Sensor Signal too Low
P1408 EGR Temp.Sensor Signal too High
P1409 Tank Ventilation Valve Circ. Electrical Malfunction
P1410 Tank Ventilation Valve Circ. Short to B+
P1411 Sec.Air Inj.Sys.,Bank2 Flow too Flow
P1412 EGR Different.Pressure Sensor Signal too Low
P1413 EGR Different.Pressure Sensor Signal too High
P1414 Sec.Air Inj.Sys.,Bank2 Leak Detected
P1417 Fuel Level Sensor Circ Signal too Low
P1418 Fuel Level Sensor Circ Signal too High
P1420 Sec.Air Inj.Valve Circ Electrical Malfunction
P1421 Sec.Air Inj.Valve Circ Short to Ground
P1422 Sec.Air Inj.Sys.Contr.Valve Circ Short to B+
P1423 Sec.Air Inj.Sys.,Bank1 Flow too Low
P1424 Sec.Air Inj.Sys.,Bank1 Leak Detected
P1425 Tank Vent.Valve Short to Ground
P1426 Tank Vent.Valve Open
P1432 Sec.Air Inj.Valve Open
P1433 Sec.Air Inj.Sys.Pump Relay Circ. open
P1434 Sec.Air Inj.Sys.Pump Relay Circ. Short to B+
P1435 Sec.Air Inj.Sys.Pump Relay Circ. Short to ground
P1436 Sec.Air Inj.Sys.Pump Relay Circ. Electrical Malfunction
P1439 EGR Potentiometer Error in Basic Seting
P1440 EGR Valve Power Stage Open
P1441 EGR Valve Circ Open/Short to Ground
P1442 EGR Valve Position Sensor Signal too high
P1443 EGR Valve Position Sensor Signal too low
P1444 EGR Valve Position Sensor range/performance
P1445 Catalyst Temp.Sensor 2 Circ. Range/Performance
P1446 Catalyst Temp.Circ Short to Ground
P1447 Catalyst Temp.Circ Open/Short to B+
P1448 Catalyst Temp.Sensor 2 Circ. Short to Ground
P1449 Catalyst Temp.Sensor 2 Circ. Open/Short to B+
P1450 Sec.Air Inj.Sys.Circ Short to B+
P1451 Sec.Air Inj.Sys.Circ Short to Ground
P1452 Sec.Air Inj.Sys. Open Circ.
P1453 Exhaust gas temperature sensor 1 open/short to B+
P1454 Exhaust gas temperature sensor short 1 to ground
P1455 Exhaust gas temperature sensor 1 range/performance
P1456 Exhaust gas temperature control bank 1 limit attained
P1457 Exhaust gas temperature sensor 2 open/short to B+
P1458 Exhaust gas temperature sensor 2 short to ground
P1459 Exhaust gas temperature sensor 2 range/performance
P1460 Exhaust gas temperature control bank 2 limit attained
P1461 Exhaust gas temperature control bank 1 Range/Performance
P1462 Exhaust gas temperature control bank 2 Range/Performance
P1465 Additive Pump Short Circuit to B+
P1466 Additive Pump Open/Short to Ground
P1467 EVAP Canister Purge Solenoid Valve Short Circuit to B+
P1468 EVAP Canister Purge Solenoid Valve Short Circuit to Ground
P1469 EVAP Canister Purge Solenoid Valve Open Circuit
P1470 EVAP Emission Contr.LDP Circ Electrical Malfunction
P1471 EVAP Emission Contr.LDP Circ Short to B+
P1472 EVAP Emission Contr.LDP Circ Short to Ground
P1473 EVAP Emission Contr.LDP Circ Open Circ.
P1474 EVAP Canister Purge Solenoid Valve electrical malfunction
P1475 EVAP Emission Contr.LDP Circ Malfunction/Signal Circ.Open
P1476 EVAP Emission Contr.LDP Circ Malfunction/Insufficient Vacuum
P1477 EVAP Emission Contr.LDP Circ Malfunction
P1478 EVAP Emission Contr.LDP Circ Clamped Tube Detected
P1500 Fuel Pump Relay Circ. Electrical Malfunction
P1501 Fuel Pump Relay Circ. Short to Ground
P1502 Fuel Pump Relay Circ. Short to B+
P1503 Load signal from Alternator Term. DF Range/performance/Incorrect Signal
P1504 Intake Air Sys.Bypass Leak Detected
P1505 Closed Throttle Pos. Does Not Close/Open Circ
P1506 Closed Throttle Pos.Switch Does Not Open/Short to Ground
P1507 Idle Sys.Learned Value Lower Limit Attained
P1508 Idle Sys.Learned Value Upper Limit Attained
P1509 Idle Air Control Circ. Electrical Malfunction
P1510 Idle Air Control Circ. Short to B+
P1511 Intake Manifold Changeover Valve circuit electrical malfunction
P1512 Intake Manifold Changeover Valve circuit Short to B+
P1513 Intake Manifold Changeover Valve2 circuit Short to B+
P1514 Intake Manifold Changeover Valve2 circuit Short to ground
P1515 Intake Manifold Changeover Valve circuit Short to Ground
P1516 Intake Manifold Changeover Valve circuit Open
P1517 Main Relay Circ. Electrical Malfunction
P1518 Main Relay Circ. Short to B+
P1519 Intake Camshaft Contr.,Bank1 Malfunction
P1520 Intake Manifold Changeover Valve2 circuit Open
P1521 Intake Manifold Changeover Valve2 circuit electrical malfunction
P1522 Intake Camshaft Contr.,Bank2 Malfunction
P1523 Crash Signal from Airbag Control Unit range/performance
P1525 Intake Camshaft Contr.Circ.,Bank1 Electrical Malfunction
P1526 Intake Camshaft Contr.Circ.,Bank1 Short to B+
P1527 Intake Camshaft Contr.Circ.,Bank1 Short to Ground
P1528 Intake Camshaft Contr.Circ.,Bank1 Open
P1529 Camshaft Control Circuit Short to B+
P1530 Camshaft Control Circuit Short to ground
P1531 Camshaft Control Circuit open
P1533 Intake Camshaft Contr.Circ.,Bank2 Electrical Malfunction
P1534 Intake Camshaft Contr.Circ.,Bank2 Short to B+
P1535 Intake Camshaft Contr.Circ.,Bank2 Short to Ground
P1536 Intake Camshaft Contr.Circ.,Bank2 Open
P1537 Engine Shutoff Solenoid Malfunction
P1538 Engine Shutoff Solenoid Open/Short to Ground
P1539 Clutch Vacuum Vent Valve Switch Incorrect signal
P1540 Vehicle Speed Sensor High Input
P1541 Fuel Pump Relay Circ Open
P1542 Throttle Actuation Potentiometer Range/Performance
P1543 Throttle Actuation Potentiometer Signal too Low
P1544 Throttle Actuation Potentiometer Signal too High
P1545 Throttle Pos.Contr Malfunction
P1546 Boost Pressure Contr.Valve Short to B+
P1547 Boost Pressure Contr.Valve Short to Ground
P1548 Boost Pressure Contr.Valve Open
P1549 Boost Pressure Contr.Valve Short to Ground
P1550 Charge Pressure Deviation
P1551 Barometric Pressure Sensor Circ. Short to B+
P1552 Barometric Pressure Sensor Circ. Open/Short to Ground
P1553 Barometric/manifold pressure signal ratio out of range
P1554 Idle Speed Contr.Throttle Pos. Basic Setting Conditions not met
P1555 Charge Pressure Upper Limit exceeded
P1556 Charge Pressure Contr. Negative Deviation
P1557 Charge Pressure Contr. Positive Deviation
P1558 Throttle Actuator Electrical Malfunction
P1559 Idle Speed Contr.Throttle Pos. Adaptation Malfunction
P1560 Maximum Engine Speed Exceeded
P1561 Quantity Adjuster Deviation
P1562 Quantity Adjuster Upper Limit Attained
P1563 Quantity Adjuster Lower Limit Attained
P1564 Idle Speed Contr.Throttle Pos. Low Voltage During Adaptation
P1565 Idle Speed Control Throttle Position lower limit not attained
P1566 Load signal from A/C compressor range/performance
P1567 Load signal from A/C compressor no signal
P1568 Idle Speed Contr.Throttle Pos. mechanical Malfunction
P1569 Cruise control switch Incorrect signal
P1570 Contr.Module Locked
P1571 Left Eng. Mount Solenoid Valve Short to B+
P1572 Left Eng. Mount Solenoid Valve Short to ground
P1573 Left Eng. Mount Solenoid Valve Open circuit
P1574 Left Eng. Mount Solenoid Valve Electrical fault in circuit
P1575 Right Eng. Mount Solenoid Valve Short to B+
P1576 Right Eng. Mount Solenoid Valve Short to ground
P1577 Right Eng. Mount Solenoid Valve Open circuit
P1578 Right Eng. Mount Solenoid Valve Electrical fault in circuit
P1579 Idle Speed Contr.Throttle Pos. Adaptation not started
P1580 Throttle Actuator B1 Malfunction
P1581 Idle Speed Contr.Throttle Pos. Basic Setting Not Carried Out
P1582 Idle Adaptation at Limit
P1583 Transmission mount valves Short to B+
P1584 Transmission mount valves Short to ground
P1585 Transmission mount valves Open circuit
P1586 Engine mount solenoid valves Short to B+
P1587 Engine mount solenoid valves Short to ground
P1588 Engine mount solenoid valves Open circuit
P1600 Power Supply (B+) Terminal 15 Low Voltage
P1602 Power Supply (B+) Terminal 30 Low Voltage
P1603 Internal Control Module Malfunction
P1604 Internal Control Module Driver Error
P1605 Rough Road/Acceleration Sensor Electrical Malfunction
P1606 Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction
P1607 Vehicle speed signal Error message from instrument cluster
P1608 Steering angle signal Error message from steering angle sensor
P1609 Crash shut-down activated
P1611 MIL Call-up Circ./Transm.Contr.Module Short to Ground
P1612 Electronic Control Module Incorrect Coding
P1613 MIL Call-up Circ Open/Short to B+
P1614 MIL Call-up Circ./Transm.Contr.Module Range/Performance
P1615 Engine Oil Temperature Sensor Circuit range/performance
P1616 Glow Plug/Heater Indicator Circ. Short to B+
P1617 Glow Plug/Heater Indicator Circ. Open/Short to Ground
P1618 Glow Plug/Heater Relay Circ. Short to B+
P1619 Glow Plug/Heater Relay Circ. Open/Short to Ground
P1620 Engine coolant temperature signal open/short to B+
P1621 Engine coolant temperature signal short to ground
P1622 Engine coolant temperature signal range/performance
P1623 Data Bus Powertrain No Communication
P1624 MIL Request Sign.active
P1625 Data-Bus Powertrain Unplausible Message from Transm.Contr.
P1626 Data-Bus Powertrain Missing Message from Transm.Contr.
P1627 Data-Bus Powertrain missing message from fuel injection pump
P1628 Data-Bus Powertrain missing message from steering sensor
P1629 Data-Bus Powertrain missing message from distance control
P1630 Accelera.Pedal Pos.Sensor 1 Signal too Low
P1631 Accelera.Pedal Pos.Sensor 1 Signal too High
P1632 Accelera.Pedal Pos.Sensor 1 Power Supply Malfunction
P1633 Accelera.Pedal Pos.Sensor 2 Signal too Low
P1634 Accelera.Pedal Pos.Sensor 2 Signal too High
P1635 Data Bus Powertrain missing message f.air condition control
P1636 Data Bus Powertrain missing message from Airbag control
P1637 Data Bus Powertrain missing message f.central electr.control
P1638 Data Bus Powertrain missing message from clutch control
P1639 Accelera.Pedal Pos.Sensor 1+2 Range/Performance
P1640 Internal Contr.Module (EEPROM) Error
P1641 Please check DTC Memory of Air Condition ECU
P1642 Please check DTC Memory of Airbag ECU
P1643 Please check DTC Memory of central electric ECU
P1644 Please check DTC Memory of clutch ECU
P1645 Data Bus Powertrain missing message f.all wheel drive contr.
P1646 Please Check DTC Memory of all wheel drive ECU
P1647 Please check coding of ECUs in Data Bus Powertrain
P1648 Data Bus Powertrain Malfunction
P1649 Data Bus Powertrain Missing message from ABS Control Module
P1650 Data Bus Powertrain Missing message fr.instrument panel ECU
P1651 Data Bus Powertrain missing messages
P1652 Please check DTC Memory of transmission ECU
P1653 Please check DTC Memory of ABS Control Module
P1654 Please check DTC Memory of control panel ECU
P1655 Please check DTC Memory of ADR Control Module
P1656 A/C clutch relay circuit short to ground
P1657 A/C clutch relay circuit short to B+
P1658 Data Bus Powertrain Incorrect signal from ADR Control Module
P1676 Drive by Wire-MIL Circ. Electrical Malfunction
P1677 Drive by Wire-MIL Circ. Short to B+
P1678 Drive by Wire-MIL Circ. Short to Ground
P1679 Drive by Wire-MIL Circ. Open
P1681 Contr.Unit Programming, Programming not Finished
P1684 Contr.Unit Programming Communication Error
P1686 Contr.Unit Error Programming Error
P1690 Malfunction Indication Light Malfunction
P1691 Malfunction Indication Light Open
P1692 Malfunction Indication Light Short to Ground
P1693 Malfunction Indication Light Short to B+
P1694 Malfunction Indication Light Open/Short to Ground
P1704 Kick Down Switch Malfunction
P1705 Gear/Ratio Monitoring Adaptation limit reached
P1711 Wheel Speed Signal 1 Range/Performance
P1716 Wheel Speed Signal 2 Range/Performance
P1721 Wheel Speed Signal 3 Range/Performance
P1723 Starter Interlock Circ. Open
P1724 Starter Interlock Circ. Short to Ground
P1726 Wheel Speed Signal 4 Range/Performance
P1728 Different Wheel Speed Signals Range/Performance
P1729 Starter Interlock Circ. Short to B+
P1733 Tiptronic Switch Down Circ. Short to Ground
P1739 Tiptronic Switch up Circ. Short to Ground
P1740 Clutch temperature control
P1741 Clutch pressure adaptation at limit
P1742 Clutch torque adaptation at limit
P1743 Clutch slip control signal too high
P1744 Tiptronic Switch Recognition Circ. Short to Ground
P1745 Transm.Contr.Unit Relay Short to B+
P1746 Transm.Contr.Unit Relay Malfunction
P1747 Transm.Contr.Unit Relay Open/Short to Ground
P1748 Transm.Contr.Unit Self-Check
P1749 Transm.Contr.Unit Incorrect Coded
P1750 Power Supply Voltage Low Voltage
P1751 Power Supply Voltage High Voltage
P1752 Power Supply Malfunction
P1760 Shift Lock Malfunction
P1761 Shift Lock Short to Ground
P1762 Shift Lock Short to B+
P1763 Shift Lock Open
P1764 Transmission temperature control
P1765 Hydraulic Pressure Sensor 2 adaptation at limit
P1766 Throttle Angle Signal Stuck Off
P1767 Throttle Angle Signal Stuck On
P1768 Hydraulic Pressure Sensor 2 Too High
P1769 Hydraulic Pressure Sensor 2 Too Low
P1770 Load Signal Range/Performance
P1771 Load Signal Stuck Off
P1772 Load Signal Stuck On
P1773 Hydraulic Pressure Sensor 1 Too High
P1774 Hydraulic Pressure Sensor 1 Too Low
P1775 Hydraulic Pressure Sensor 1 adaptation at limit
P1776 Hydraulic Pressure Sensor 1 range/performance
P1777 Hydraulic Pressure Sensor 2 range/performance
P1778 Solenoid EV7 Electrical Malfunction
P1781 Engine Torque Reduction Open/Short to Ground
P1782 Engine Torque Reduction Short to B+
P1784 Shift up/down Wire Open/Short to Ground
P1785 Shift up/down Wire Short to B+
P1786 Reversing Light Circ. Open
P1787 Reversing Light Circ. Short to Ground
P1788 Reversing Light Circ. Short to B+
P1789 Idle Speed Intervention Circ. Error Message from Engine Contr.
P1790 Transmission Range Display Circ. Open
P1791 Transmission Range Display Circ. Short to Ground
P1792 Transmission Range Display Circ. Short to B+
P1793 Output Speed Sensor 2 Circ. No Signal
P1795 Vehicle Speed Signal Circ. Open
P1796 Vehicle Speed Signal Circ. Short to Ground
P1797 Vehicle Speed Signal Circ. Short to B+
P1798 Output Speed Sensor 2 Circ. Range/Performance
P1799 Output Speed Sensor 2 Circ. Rpm too High
P1813 Pressure Contr.Solenoid 1 Electrical
P1814 Pressure Contr.Solenoid 1 Open/Short to Ground
P1815 Pressure Contr.Solenoid 1 Short to B+
P1818 Pressure Contr.Solenoid 2 Electrical
P1819 Pressure Contr.Solenoid 2 Open/Short to Ground
P1820 Pressure Contr.Solenoid 2 Short to B+
P1823 Pressure Contr.Solenoid 3 Electrical
P1824 Pressure Contr.Solenoid 3 Open/Short to Ground
P1825 Pressure Contr.Solenoid 3 Short to B+
P1828 Pressure Contr.Solenoid 4 Electrical
P1829 Pressure Contr.Solenoid 4 Open/Short to Ground
P1830 Pressure Contr.Solenoid 4 Short to B+
P1834 Pressure Contr.Solenoid 5 Open/Short to Ground
P1835 Pressure Contr.Solenoid 5 Short to B+
P1841 Engine/Transmission Control Modules Versions do not match
P1842 Please check DTC Memory of instrument panel ECU
P1843 Please check DTC Memory of ADR Control Module
P1844 Please check DTC Memory of central electric control ECU
P1847 Please check DTC Memory of brake system ECU
P1848 Please check DTC Memory of engine ECU
P1849 Please check DTC Memory of transmission ECU
P1850 Data-Bus Powertrain Missing Message from Engine Contr.
P1851 Data-Bus Powertrain Missing Message from Brake Contr.
P1852 Data-Bus Powertrain Unplausible Message from Engine Contr.
P1853 Data-Bus Powertrain Unplausible Message from Brake Contr.
P1854 Data-Bus Powertrain Hardware Defective
P1855 Data-Bus Powertrain Software version Contr.
P1856 Throttle/Pedal Pos.Sensor A Circ. Error Message from Engine Contr.
P1857 Load Signal Error Message from Engine Contr.
P1858 Engine Speed Input Circ. Error Message from Engine Contr.
P1859 Brake Switch Circ. Error Message from Engine Contr.
P1860 Kick Down Switch Error Message from Engine Contr.
P1861 Throttle Position (TP) sensor Error Message from ECM
P1862 Data Bus Powertrain Missing message from instr. panel ECU
P1863 Data Bus Powertrain Missing Message from St. Angle Sensor
P1864 Data Bus Powertrain Missing message from ADR control module
P1865 Data Bus Powertrain Missing message from central electronics
P1866 Data Bus Powertrain Missing messages
Renaultmonteurtje Topicstarter 33.765 km Reageer
[b]BMW Specific Trouble Codes[/b]
P1083 Fuel Control Mixture Lean (Bank 1 Sensor 1)
P1084 Fuel Control Mixture Rich (Bank 1 Sensor 1)
P1085 Fuel Control Mixture Lean (Bank 2 Sensor 1)
P1086 Fuel Control Mixture Rich (Bank 2 Sensor 1)
P1087 O2 Sensor Circuit Slow Response in Lean Control Range (Bank 1 Sensor 1)
P1088 O2 Sensor Circuit Slow Response in Rich Control Range (Bank 1 Sensor 1)
P1089 O2 Sensor Circuit Slow Response in Lean Control Range (Bank 1 Sensor 2)
P1090 Pre-Catalyst Fuel Trim Too Lean Bank 1
P1091 Pre-Catalyst Fuel Trim Too Rich Bank 1
P1092 Pre-Catalyst Fuel Trim Too Lean Bank 2
P1093 Pre-Catalyst Fuel Trim Too Rich Bank 2
P1094 O2 Sensor Circuit Slow Response in Rich Control Range (Bank 2 Sensor 1)
P1095 O2 Sensor Circuit Slow Switching From Lean to Rich (Bank 1 Sensor 1)
P1096 O2 Sensor Circuit Slow Switching From Lean to Rich (Bank 2 Sensor 1)
P1097 O2 Sensor Circuit Slow Response after Coast Down Fuel Cutoff (Bank 1 Sensor 1)
P1098 O2 Sensor Circuit Slow Response after Coast Down Fuel Cutoff (Bank 2 Sensor 2)
P1111 Engine Coolant Temperature Radiator Outlet Sensor Low Input
P1112 Engine Coolant Temperature Radiator Outlet Sensor High Input
P1115 Coolant Temperature Sensor Plausibility
P1116 Mass Or Volume Air Flow Circuit Range/Performance Problem (Bank 2)
P1117 Mass Or Volume Air Flow Circuit Low Input (Bank 2)
P1118 Mass Or Volume Air Flow Circuit High Input (Bank 2)
P1120 Pedal Position Sensor Circuit
P1121 Pedal Position 1 Range/Performance Problem
P1122 Pedal Position 1 Low Input
P1123 Pedal Position 1 High Input
P1132 O2 Sensor Heater Control Circuit (Bank 1 Sensor 1)
P1133 O2 Sensor Heater Control Circuit (Bank 2 Sensor 1)
P1134 O2 Sensor Heater Circuit Signal Intermittent (Bank 1 Sensor 2)
P1135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1)
P1136 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1)
P1137 O2 Sensor Heater Circuit Signal Intermittant (Bank 1 Sensor 2)
P1138 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2)
P1139 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2)
P1140 Mass or Volume Air Flow Circuit Range/Performance Problem
P1145 Solenoid Valve Running Losses Control Circuit Electrical
P1151 O2 Sensor Heater Circuit Signal Intermittant (Bank 2 Sensor 1)
P1152 O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 1)
P1153 O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 1)
P1155 O2 Sensor Heater Circuit Intermittant (Bank 2 Sensor 2)
P1156 O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 2)
P1157 O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 2)
P1158 Fuel Trim Additve Bank 1 Low
P1159 Fuel Trim Additve Bank 1 High
P1160 Fuel Trim Additve Bank 2 Low
P1161 Fuel Trim Additve Bank 2 High
P1162 Fuel Trim Additve Per Ignition Bank 1 Low
P1163 Fuel Trim Additve Per Ignition Bank 1 High
P1164 Fuel Trim Additve Per Ignition Bank 2 Low
P1165 Fuel Trim Additve Per Ignition Bank 2 High
P1174 Fuel Trim Adaptation Additve Bank 1 Malfunction
P1175 Fuel Trim Adaptation Additve Bank 2 Malfunction
P1176 O2 Sensor Slow Response Bank 1
P1177 O2 Sensor Slow Response Bank 2
P1178 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 1 Sensor 1)
P1179 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 2 Sensor 1)
P1180 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 1 Sensor 2)
P1181 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 2 Sensor 2)
P1182 O2 Sensor (Bank 1 Sensor 2) Open Circuit During Coast Down Fuel Cut-off
P1183 O2 Sensor (Bank 2 Sensor 2) Open Circuit During Coast Down Fuel Cut-off
P1186 O2 Sensor Heater Control Circuit (Bank 1 Sensor 2)
P1187 O2 Sensor Heater Control Circuit (Bank 2 Sensor 2)
P1188 Fuel Control (Bank 1 Sensor 1)
P1189 Fuel Control (Bank 2 Sensor 1)
P1190 Pre-catalyst Fuel Trim System Bank 1
P1191 Pre-catalyst Fuel Trim System Bank 2
P1192 Post-catalyst Fuel Trim System Bank 1
P1193 Post-catalyst Fuel Trim System Bank 2
P1221 Pedal Position Sensor 2 Range/Performance Problem
P1222 Pedal Position Sensor 2 Low Input
P1223 Pedal Position Sensor 2 High Input
P1270 Control Module Self-Test, Torque Monitoring
P1271 Ambient Air Pressure Sensor Electrical
P1283 Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Electrical
P1284 Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Signal Low
P1285 Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Signal High
P1287 Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Electrical
P1288 Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Signal Low
P1289 Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Signal High
P1313 "A" Camshaft Position Plausibility
P1317 "B" Camshaft Position Plausibility
P1327 Knock Sensor 2 (Bank 1) Low Input
P1328 Knock Sensor 2 (Bank 1) High Input
P1332 Knock Sensor 4 Low Input
P1333 Knock Sensor 4 High Input
P1340 Multiple Cylinder Misfire During Start
P1341 Multiple Cylinder Misfire With Fuel Cut-off
P1342 Misfire During Start Cylinder 1
P1343 Misfire Cylinder 1 With Fuel Cut-off
P1344 Misfire During Start Cylinder 2
P1345 Misfire Cylinder 2 With Fuel Cut-off
P1346 Misfire During Start Cylinder 3
P1347 Misfire Cylinder 3 With Fuel Cut-off
P1348 Misfire During Start Cylinder 4
P1349 Misfire Cylinder 4 With Fuel Cut-off
P1350 Misfire During Start Cylinder 5
P1351 Misfire Cylinder 5 With Fuel Cut-off
P1352 Misfire During Start Cylinder 6
P1353 Misfire Cylinder 6 With Fuel Cut-off
P1354 Misfire During Start Cylinder 7
P1355 Misfire Cylinder 7 With Fuel Cut-off
P1356 Misfire During Start Cylinder 8
P1357 Misfire Cylinder 8 With Fuel Cut-off
P1358 Misfire During Start Cylinder 9
P1359 Misfire Cylinder 9 With Fuel Cut-off
P1360 Misfire During Start Cylinder 10
P1361 Misfire Cylinder 10 With Fuel Cut-off
P1362 Misfire During Start Cylinder 11
P1363 Misfire Cylinder 11 With Fuel Cut-off
P1364 Misfire During Start Cylinder 12
P1365 Misfire Cylinder 12 With Fuel Cut-off
P1384 Knock Sensor 3 Circuit
P1385 Knock Sensor 4 Circuit
P1386 Control Module Self-test, Knock Control Baseline Test Bank 1
P1396 Crankshaft Position Sensor Segment Timing Plausibility
P1397 Camshaft Position Sensor "B" Circuit (Bank 1)
P1400 Heated Catalyst Battery Voltage or Current too Low During Heating (Bank 1)
P1401 Heated Catalyst Current too High During Heating (Bank 1)
P1402 Heated Catalyst Power Switch Overtemperature Condition (Bank 1)
P1403 Carbon Canister Shut Off valve Control Circuit Electrical
P1404 Heated Catalyst Current too High During Heating (Bank 2)
P1405 Heated Catalyst Power Switch Overtemperature Condition (Bank 2)
P1406 Heated Catalyst Internal Control Module Checksum/ROM Error
P1413 Secondary Air Injection Pump Relay Control Circuit Signal Low
P1414 Secondary Air Injection System Monitor Circuit High
P1420 Secondary Air Valve Control Circuit Electrical
P1421 Secondary Air System Bank 1
P1422 Secondary Air System Bank 2
P1432 Secondary Air Injection System Incorrect Flow Detected
P1438 Purge Control Valve Control Open Circuit
P1439 Purge Control Valve Control Circuit Signal Low
P1440 Purge Control Valve Control Circuit Signal High
P1441 Leakage Diagnostic Pump Control Open Circuit
P1442 Leakage Diagnostic Pump Control Circuit Signal Low
P1443 Leakage Diagnostic Pump Control Circuit Signal High
P1444 Diagnostic Module Tank Leakage (DM-TL) Pump Control Open Circuit
P1445 Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal Low
P1446 Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal High
P1447 Diagnostic Module Tank Leakage (DM-TL) Pump Too High During Switching
P1448 Diagnostic Module Tank Leakage (DM-TL) Pump Too Low During Switching
P1449 Diagnostic Module Tank Leakage (DM-TL) Pump Too High
P1450 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Open Circuit
P1451 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal Low
P1452 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal High
P1453 Secondary Air Injection Pump Relay Control Circuit Electrical
P1454 Secondary Air Injection Pump With Series Resistor Control Circuit Electrical
P1456 Heated Catalyst Heater Power Supply Open Circuit (Bank 1)
P1457 Heated Catalyst Heater Power Switch Temperature Sensor Electrical (Bank 1)
P1459 Heated Catalyst Heater Power Supply Open Circuit (Bank 2)
P1460 Heated Catalyst Heater Power Switch Temperature Sensor Electrical (Bank 2)
P1461 Heated Catalyst Gate Voltage Signal Low
P1462 Heated Catalyst Internal Control Module Checksum/ROM Error
P1463 Heated Catalyst Battery Temperature Sensor 1 Electrical
P1464 Heated Catalyst Battery Temperature Sensor 2 Electrical
P1465 Heated Catalyst Battery Temperature Sensor 1 or 2 Plausibility
P1466 Heated Catalyst Power Switch Temperature Sensor Plausibility
P1467 Heated Catalyst Comparison Battery Voltages of Power Switches Plausibility
P1468 Heated Catalyst Battery Disconnecting Switch Plausibility
P1470 Leakage Diagnostic Pump Control Circuit Electrical
P1472 Diagnostic Module Tank leakage (DM-TL) Switching Solenoid Control Circuit Electrical
P1473 Diagnostic Module Tank leakage (DM-TL) Pump Current Plausibility
P1475 Leakage Diagnostic Pump Reed Switch Did Not Close
P1476 Leakage Diagnostic Pump Clamped Tube
P1477 Leakage Diagnostic Pump Reed Switch Did Not Open
P1500 Idle Speed Control Valve Stuck Open
P1501 Idle Speed Control Valve Stuck Closed
P1502 Idle Speed Control Valve Closing Solenoid Control Circuit Signal High or Low
P1503 Idle Speed Control Valve Closing Solenoid Control Circuit Signal Low
P1504 Idle Speed Control Valve Closing Solenoid Control Open Circuit
P1505 Idle Speed Control Valve Closing Solenoid Control Circuit Electrial
P1506 Idle Speed Control Valve Open Solenoid Control Circuit Signal High
P1507 Idle Speed Control Valve Open Solenoid Control Circuit Signal Low
P1508 Idle Speed Control Valve Opening Solenoid Control Open Circuit
P1509 Idle Speed Control Valve Opening Solenoid Control Circuit Electrial
P1510 Idle Speed Control Valve Stuck
P1511 DISA Control Circuit Electrical
P1512 DISA Control Circuit Signal Low
P1513 DISA Control Circuit Signal High
P1519 "A" Camshaft Position Actuator Bank 1
P1520 "B" Camshaft Position Actuator Bank 1
P1522 "A" Camshaft Position Actuator Bank 2
P1523 "A" Camshaft Position Actuator Signal Low Bank 1
P1524 "A" Camshaft Position Actuator Signal High Bank 1
P1525 "A" Camshaft Position Actuator Control Open Circuit Bank 1
P1526 "A" Camshaft Position Actuator Control Open Circuit Bank 2
P1527 "A" Camshaft Position Actuator Control Circuit Signal Low Bank 1
P1528 "A" Camshaft Position Actuator Control Circuit Signal High Bank 1
P1529 "B" Camshaft Position Actuator Control Circuit Signal Low Bank 1
P1530 "B" Camshaft Position Actuator Control Circuit Signal High Bank 1
P1531 "B" Camshaft Position Actuator Control Open Circuit Bank 1
P1532 "B" Camshaft Position Actuator Control Open Circuit Bank 2
P1533 "B" Camshaft Position Actuator Control Circuit Signal Low Bank 2
P1534 "B" Camshaft Position Actuator Control Circuit Signal High Bank 2
P1540 Pedal Position Sensor
P1541 Pedal Position Sensor Double Error
P1542 Pedal Position Sensor Electrical
P1543 Pedal Position Sensor
P1544 Pedal Position Sensor
P1545 Pedal Position Sensor
P1546 Pedal Position Sensor
P1550 Idle Speed Control valve Closing Solenoid Control Circuit Electrical
P1551 "A" Camshaft Position Actuator Control Open Circuit Bank 1
P1552 "A" Camshaft Position Actuator Control Open Circuit Bank 1
P1556 "A" Camshaft Position Actuator Control Open Circuit Bank 1
P1560 "B" Camshaft Position Actuator Control Open Circuit Bank 1
P1564 Control Module Selection
P1565 "B" Camshaft Position Actuator Control Open Circuit Bank 1
P1569 "A" Camshaft Position Actuator Control Open Circuit Bank 2
P1580 Throttle Valve Mechanically Stuck
P1581 "B" Camshaft Position Actuator Control Open Circuit Bank 2
P1589 Control Module Self Test, Knock Control Test Pulse Bank 1
P1593 DISA Control Circuit Electrical
P1594 "B" Camshaft Position Actuator Control Open Circuit Bank 2
P1602 Control Module Self Test, Control Module Defective
P1603 Control Module Self Test, Torque Monitoring
P1604 Control Module Self Test, Speed Monitoring
P1607 CAN Version
P1608 Serial Communicating Link Control Module
P1609 Serial Communicating Link EML
P1611 Serial Communicating Link Transmission Control Module
P1619 MAP Cooling Control Circuit Signal Low
P1620 MAP Cooling Control Circuit Signal High
P1622 MAP Cooling Control Circuit Electrical
P1623 Pedal Position Sensor Potentiometer Supply
P1624 Pedal Position Sensor Potentiometer Supply Channel 1 Electrical
P1625 Pedal Position Sensor Potentiometer Supply Channel 2 Electrical
P1632 Throttle Valve Adaptation; Adaptation Condition Not Met
P1633 Throttle Valve Adaptation; Limp Home Position
P1634 Throttle Valve Adaptation; Spring Test Failed
P1635 Throttle Valve Adaptation; Lower Mechanical Stop Not Adapted
P1636 Throttle Valve Control Circuit
P1637 Throttle Valve Position Control; Control Deviation
P1638 Throttle Valve Position Control; Throttle Stuck Temporarily
P1639 Throttle Valve Position Control; Throttle Stuck Permanently
P1640 Internal Control Module (ROM/RAM) Error
P1690 Malfunction Indicator Lamp (MIL) Electrical
P1734 Pressure Control Solenoid "B" Electrical
P1738 Pressure Control Solenoid "C" Electrical
P1743 Pressure Control Solenoid "E" Electrical
P1744 Pressure Control Solenoid "A" Electrical
P1746 Transmission Control Module Output Stage
P1747 CAN Bus Monitoring
P1748 Transmission Control Module Self Test
P1749 Secondary Pressure Solenoid Communication Error
P1750 Secondary Pressure Solenoid Circuit Range/Performance
P1751 Secondary Pressure Solenoid Open Circuit
P1761 Shift Solenoid Malfunction
P1765 CAN Throttle Valve
P1770 CAN Torque Interface
P1780 CAN Torque Reduction
[b]Dodge / Chrysler / Jeep Specific Trouble Codes [/b]
P1192 Inlet Air Temp. Circuit Low
P1193 Inlet Air Temp. Circuit High
P1195 1/1 O2 Sensor Slow During Catalyst Monitor
P1196 2/1 O2 Sensor Slow During Catalyst Monitor
P1197 1/2 O2 Sensor Slow During Catalyst Monitor
P1198 Radiator Temperature Sensor Volts Too High
P1199 Radiator Temperature Sensor Volts Too Low
P1281 Engine Is Cold Too Long
P1282 Fuel Pump Relay Control Circuit
P1283 Idle Select Signal Invalid
P1284 Fuel Injection Pump Battery Voltage Out Of Range
P1285 Fuel Injection Pump Controller Always On
P1286 Accelerator Pedal Position Sensor Supply Voltage Too High
P1287 Fuel Injection Pump Controller Supply Voltage Low
P1288 Intake Manifold Short Runner Solenoid Circuit
P1289 Manifold Tune Valve Solenoid Circuit
P1290 CNG Fuel Pressure Too High
P1291 No Temp Rise Seen From Fuel Heaters
P1292 CNG Pressure Sensor Voltage Too High
P1293 CNG Pressure Sensor Voltage Too Low
P1294 Target Idle Not Reached
P1295 No 5 Volts To TP Sensor
P1296 No 5 Volts To MAP Sensor
P1297 No Change in MAP From Start To Run
P1298 Lean Operation At wide Open Throttle
P1299 Vacuum Leak Found (IAC Fully Seated)
P1388 Auto Shutdown (ASD) Relay Control Circuit
P1389 No Auto Shutdown (ASD) Relay Output Voltage At PCM
P1390 Timing Belt Skipped One Tooth or More
P1391 Intermittent Loss of CMP or CKP
P1398 Mis-Fire Adapter Numerator at Limit
P1399 Wait To Start Lamp Circuit
P1403 No 5 Volts To EGR Sensor
P1475 Aux. 5 Volt Output Too High
P1476 Too Little Secondary Air
P1477 Too Much Secondary Air
P1478 Battery Temp Sensor Volts Out of Limit
P1479 Transmission Fan Relay Circuit
P1480 PCV Solenoid Valve
P1482 Catalyst Temperature Sensor Circuit Shorted Low
P1483 Catalyst Temperature Sensor Circuit Shorted High
P1484 Catalytic Converter Overheat Detected
P1485 Air Injection Solenoid Circuit
P1486 Evap Leak Monitor Pinched Hose
P1487 Hi Speed Rad Fan CTRL Relay Circuit
P1488 Auxiliary 5 Volt Supply Output Too Low
P1489 High Speed Fan CTRL Relay Circuit
P1490 Low Speed Fan CTRL Relay Circuit
P1491 Rad Fan Control Relay Circuit
P1492 Battery Temperature Sensor Voltage Too High
P1493 Battery Temperature Sensor Voltage Too Low
P1494 Leak Detection Pump Switch or Mechanical Fault
P1495 Leak Detection Pump Solenoid Circuit
P1496 5 Volt Supply Output Too Low
P1498 High speed Rad Fan Ground CTRL Rly Circuit
P1594 Charging System Voltage Too High
P1595 Speed Control Solenoid Circuits
P1596 Speed Control Switch Always High
P1597 Speed Control Switch Always Low
P1598 A/C Pressure Sensor Volts Too High
P1599 A/C Pressure Sensor Volts Too Low
P1602 PCM Not Programmed
P1680 Clutch Released Switch Circuit
P1681 No I/P Cluster CCD/J1850 Messages Received
P1682 Charging System Voltage Too Low
P1683 Speed Control Power Relay Or Speed Control 12 Volt Driver Circuit
P1684 Battery Disconnected Within Last 50 Starts
P1685 Skim Invalid Key
P1686 No SKIM Bus Message Received
P1687 No Cluster Bus Message
P1688 Internal Fuel Injection Pump Controller Failure
P1689 No Communication Between ECM & Injection Pump Module
P1690 Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor
P1691 Fuel Injection Pump Controller Calibration Failure
P1693 DTC Detected In ECM Or PCM
P1694 No CCD Messages Received From ECM
P1695 No CCD/J185O Message From BCM
P1696 PCM Failure EEPROM Write Denied
P1697 PCM Failure SRI Mile Not Stored
P1698 No CCD Messages Received From PCM
P1719 Skip Shift Solenoid Circuit
P1740 TCC Or OD Solenoid Performance
P1756 Governor Pressure Not Equal To Target At 1520 PSI
P1757 Governor Pressure Above 3 PSI When Request Is 0 PSI
P1762 Governor Pressure Sensor Offset Improper Voltage
P1763 Governor Pressure Sensor Voltage Too High
P1764 Governor Pressure Sensor Voltage Too Low
P1765 Trans 12 Volt Supply Relay Control Circuit
P1899 Park/Neutral Position Switch Stuck In Park or In Gear
[b]Ford OBD-II Trouble Codes[/b]
P1000 OBD-II Monitor Testing Incomplete
P1001 KOER Test Cannot Be Completed
P1039 Vehicle Speed Signal Missing or Improper
P1051 Brake Switch Signal Missing or Improper
P1100 Mass Air Flow Sensor Intermittent
P1101 Mass Air Flow Sensor out of Self-Test Range
P1112 Intake Air Temperature Sensor Intermittent
P1116 Engine Coolant Temperature Sensor is out of Self-Test Range
P1117 Engine Coolant Temperature Sensor Intermittent
P1120 Throttle Position Sensor out of range
P1121 Throttle Position Sensor Inconsistent with Mass Air Flow Sensor
P1124 Throttle Position Sensor out of Self-Test Range
P1125 Throttle Position Sensor Intermittent
P1127 Heated Oxygen Sensor Heater not on During KOER Test
P1128 Heated Oxygen Sensor Signals reversed
P1129 Heated Oxygen Sensor Signals reversed
P1130 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1
P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1132 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1135 Ignition Switch Signal Missing or Improper
P1137 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1138 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1150 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1152 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1157 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1158 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1220 Series Throttle Control fault
P1224 Throttle Position Sensor B out of Self-Test Range
P1230 Open Power to Fuel Pump circuit
P1231 High Speed Fuel Pump Relay activated
P1232 Low Speed Fuel Pump Primary circuit failure
P1233 Fuel Pump Driver Module off-line
P1234 Fuel Pump Driver Module off-line
P1235 Fuel Pump Control out of range
P1236 Fuel Pump Control out of range
P1237 Fuel Pump Secondary circuit fault
P1238 Fuel Pump Secondary circuit fault
P1250 Lack of Power to FPRC Solenoid
P1260 Theft Detected - Engine Disabled
P1270 Engine RPM or Vehicle Speed Limiter Reached
P1288 Cylinder Head Temperature Sensor out of Self-Test Range
P1289 Cylinder Head Temperature Sensor Signal Greater Than Self-Test Range
P1290 Cylinder Head Temperature Sensor Signal Less Than Self-Test Range
P1299 Cylinder Head Temperature Sensor Detected Engine Overheating Condition
P1309 Misfire Detection Monitor not enabled
P1351 Ignition Diagnostic Monitor circuit Input fault
P1352 Ignition Coil A - Primary circuit fault
P1353 Ignition Coil B - Primary circuit fault
P1354 Ignition Coil C - Primary circuit fault
P1355 Ignition Coil D - Primary circuit fault
P1356 Loss of Ignition Diagnostic Module Input to PCM
P1358 Ignition Diagnostic Monitor Signal out of Self-Test Range
P1359 Spark Output circuit fault
P1364 Ignition Coil Primary circuit fault
P1380 VCT Solenoid Valve circuit Short or Open
P1381 Cam Timing Advance is excessive
P1383 Cam Timing Advance is excessive
P1390 Octane Adjust out of Self-Test Range
P1400 Differential Pressure Feedback Electronic Sensor circuit Low Voltage
P1401 Differential Pressure Feedback Electronic Sensor circuit High Voltage
P1403 Differential Pressure Feedback Electronic Sensor Hoses Reversed
P1405 Differential Pressure Feedback Electronic Sensor circuit Upstream Hose
P1406 Differential Pressure Feedback Electronic Sensor circuit Downstream Hose
P1407 EGR No Flow Detected
P1408 EGR Flow out of Self-Test Range
P1409? EGR Vacuum Regulator circuit malfunction
P1409? Electronic Vacuum Regulator Control circuit fault
P1410 EGR Barometric Pressure Sensor VREF Voltage
P1411 Secondary Air is not being diverted
P1413 Secondary Air Injection System Monitor circuit Low Voltage
P1414 Secondary Air Injection System Monitor circuit High Voltage
P1442 Secondary Air Injection System Monitor circuit High Voltage
P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault
P1444 Purge Flow Sensor circuit Input Low
P1445 Purge Flow Sensor circuit Input High
P1450 Inability of Evaporative Emission Control System to Bleed Fuel Tank
P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction
P1452 Inability of Evaporative Emission Control System to Bleed Fuel Tank
P1455 Substantial Leak or Blockage in Evaporative Emission Control System
P1460 Wide Open Throttle Air Conditioning Cutoff circuit malfunction
P1461 Air Conditioning Pressure Sensor circuit Low Input
P1462 Air Conditioning Pressure Sensor circuit high Input
P1463 Air Conditioning Pressure Sensor Insufficient Pressure change
P1464 ACCS to PCM High During Self-Test
P1469 Low Air Conditioning Cycling Period
P1473 Fan Secondary High with Fans Off
P1474 Low Fan Control Primary circuit
P1479 High Fan Control Primary circuit
P1480 Fan Secondary Low with Low Fans On
P1481 Fan Secondary Low with High Fans On
P1483 Power to Cooling Fan Exceeded Normal Draw
P1484 Variable Load Control Module Pin 1 Open
P1500 Vehicle Speed Sensor Intermittent
P1501 Programmable Speedometer & Odometer Module/Vehicle Speed Sensor Intermittent circuit-failure
P1502 Invalid or Missing Vehicle Speed Message or Brake Data
P1504 Intake Air Control circuit malfunction
P1505 Idle Air Control System at Adaptive Clip
P1506 Idle Air Control Over Speed Error
P1507 Idle Air Control Under Speed Error
P1512 Intake Manifold Runner Control Stuck Closed
P1513 Intake Manifold Runner Control Stuck Closed
P1516 Intake Manifold Runner Control Input Error
P1517 Intake Manifold Runner Control Input Error
P1518 Intake Manifold Runner Control fault - Stuck Open
P1519? Intake Manifold Runner Control Stuck Open
P1520? Intake Manifold Runner Control circuit fault
P1519? Intake Manifold Runner Control fault - Stuck Closed
P1520? Intake Manifold Runner Control fault
P1530 Open or Short to A/C Compressor Clutch circuit
P1537 Intake Manifold Runner Control Stuck Open
P1538 Intake Manifold Runner Control Stuck Open
P1539 Power to A/C Compressor Clutch circuit Exceeded Normal Current Draw
P1549 Intake Manifold Temperature Valve Vacuum Actuator Connection
P1550 Power Steering Pressure Sensor out of Self-Test Range
P1605 PCM Keep Alive Memory Test Error
P1625 Voltage to Vehicle Load Control Module Fan circuit not detected
P1626 Voltage to Vehicle Load Control Module circuit not detected
P1650 Power Steering Pressure Switch out of Self-Test Range
P1651 Power Steering Pressure Switch Input fault
P1700 Transmission system problems
P1701 Reverse Engagement Error
P1702 Transmission system problems
P1703 Brake On/Off Switch out of Self-Test Range
P1704 Transmission system problems
P1705 Manual Lever Position Sensor out of Self-Test Range
P1709 Park or Neutral Position Switch out of Self-Test Range
P1710 Transmission system problems
P1711 Transmission Fluid Temperature Sensor out of Self-Test Range
P1713
thru
P172 Transmission system problems
P1729 4x4 Low Switch Error
P1740 Transmission system problems
P1741 Torque Converter Clutch Control Error
P1742 Torque Converter Clutch Solenoid Faulty
P1743 Torque Converter Clutch Solenoid Faulty
P1744 Torque Converter Clutch System Stuck in Off Position
P1745 Transmission system problems
P1746 Electronic Pressure Control Solenoid - Open circuit
P1747 Electronic Pressure Control Solenoid - Short circuit
P1749 Electronic Pressure Control Solenoid Failed Low
P1751 Shift Solenoid No. 1 Performance
P1754 Coast Clutch Solenoid circuit malfunction
P1756 Shift Solenoid No. 2 Performance
P1760 Transmission system problems
P1761 Shift Solenoid No. 3 Performance
P1762 Transmission system problems
P1767 Transmission system problems
P1780 Transmission Control Switch circuit is out of Self-Test Range
P1781 4x4 Low Switch is out of Self-Test Range
P1783 Transmission Over-Temperature Condition
P1784 Transmission system problems
P1785 Transmission system problems
P1786 Transmission system problems
P1787 Transmission system problems
P1788 Transmission system problems
P1789 Transmission system problems
P1900 Transmission system problems
[b]Honda Specific Trouble Codes[/b]
P1106 Barometric Pressure Circuit Range/Performance
P1107 Barometric Pressure Circuit Low Input
P1108 Barometric Pressure Circuit High Input
P1121 Throttle Position Lower Than Expected
P1122 Throttle Position Higher Than Expected
P1128 MAP Lower Than Expected
P1129 MAP Higher Than Expected
P1149 Primary HO2S (Sensor 1) Circuit Range/Performance Problem
P1162 Primary HO2S (No. 1) Circuit Malfunction
P1163 Primary HO2S (No. 1) Circuit Slow Response
P1164 Primary HO2S (No. 1) Circuit Range/Performance
P1165 Primary HO2S (No. 1) Circuit Range/Performance
P1166 Primary HO2S (No. 1) Heater System Electrical
P1167 Primary HO2S (No. 1) Heater System
P1168 Primary HO2S (No. 1) LABEL Low Input
P1169 Primary HO2S (No. 1) LABEL High Input
P1253 VTEC System Malfunction
P1257 VTEC System Malfunction
P1258 VTEC System Malfunction
P1259 VTEC System Malfunction
P1297 Electrical Load Detector Circuit Low Input
P1298 Electrical Load Detector Circuit High Input
P1300 Multiple Cylinder Misfire Detected
P1336 CSF Sensor Intermittent Interruption
P1337 CSF Sensor No Signal
P1359 CKP/TDC Sensor Connector Disconnection
P1361 Intermittent Interruption In TDC 1 Sensor Circuit
P1362 No Signal In TDC 1 Sensor Circuit
P1366 Intermittent Interruption In TDC 2 Sensor Circuit
P1367 No Signal In TDC 2 Sensor Circuit
P1381 Cylinder Position Sensor Intermittent Interruption
P1382 Cylinder Position Sensor No Signal
P1456 EVAP Emission Control System Leak Detected (Fuel Tank System)
P1457 EVAP Emission Control System Leak Detected (Control Canister System)
P1459 EVAP Emission Purge Flow Switch Malfunction
P1486 Thermostat Range/Performance Problem
P1491 EGR Valve Lift Insufficient Detected
P1498 EGR Valve Lift Sensor High Voltage
P1508 IAC Valve Circuit Failure
P1509 IAC Valve Circuit Failure
P1519 Idle Air Control Valve Circuit Failure
P1607 ECM/PCM Internal Circuit Failure A
P1655 SEAF/SEFA/TMA/TMB Signal Line Failure
P1656 Automatic Transaxle
P1660 Automatic Transaxle FI Signal A Circuit Failure
P1676 FPTDR Signal Line Failure
P1678 FPTDR Signal Line Failure
P1681 Automatic Transaxle FI Signal A Low Input
P1682 Automatic Transaxle FI Signal A High Input
P1686 Automatic Transaxle FI Signal B Low Input
P1687 Automatic Transaxle FI Signal B High Input
P1705 Automatic Transaxle Concerns
P1706 Automatic Transaxle Concerns
P1738 Automatic Transaxle Concerns
P1739 Automatic Transaxle Concerns
P1753 Automatic Transaxle Concerns
P1758 Automatic Transaxle Concerns
P1768 Automatic Transaxle Concerns
P1773 Automatic Transaxle Concerns
P1785 Automatic Transaxle Concerns
P1786 Automatic Transaxle Concerns
P1790 Automatic Transaxle Concerns
P1791 Automatic Transaxle Concerns
P1792 Automatic Transaxle Concerns
P1793 Automatic Transaxle Concerns
P1794 Automatic Transaxle Concerns
P1870 Automatic Transaxle Concerns
P1873 Automatic Transaxle Concerns
P1879 Automatic Transaxle Concerns
P1885 Automatic Transaxle Concerns
P1886 Automatic Transaxle Concerns
P1888 Automatic Transaxle Concerns
P1890 Automatic Transaxle Concerns
P1891 Automatic Transaxle Concerns
[b]Hyundai Specific Trouble [/b]
P1100 Manifold Absolute Pressure (MAP) Sensor Malfunction (Open/Short)
P1102 Manifold Absolute Pressure (MAP) Sensor Malfunction - Low Voltage
P1103 Manifold Absolute Pressure (MAP) Sensor Malfunction - High Voltage
P1147 ETS Sub Accel Position Sensor 1 Malfunction
P1151 ETS Main Accel Position Sensor 2 Malfunction
P1155 ETS Limp Home Valve
P1159 Variable Intake Motor Malfunction
P1171 Electronic Throttle System Open
P1172 Electronic Throttle System Motor Current
P1173 Electronic Throttle System Rationality Malfunction
P1174 Electronic Throttle System #1 Close Malfunction
P1175 Electronic Throttle System #2 Close Malfunction
P1176 ETS Motor Open/Short #1
P1176 ETS Motor Open/Short #2
P1178 ETS Motor Battery Voltage Open
P1330 Spark Timing Adjust Malfunction
P1521 Power Steering Switch Malfunction
P1607 Electronic Throttle System Communication Error
P1614 Electronic Throttle System Module Malfunction
P1632 Traction Control System Malfunction
[b]Infiniti Specific Trouble Codes[/b]
P1105 MAP/BARO Switch Solenoid Valve
P1110 Intake Valve Timing Control (Left Bank)
P1120 Secondary Throttle Position Sensor (STPS)
P1125 TPS Intermittant
P1130 Swirl Control Valve Control Solenoid Valve
P1135 Intake Valve Timing Control (Right Bank)
P1140 Intake Valve Timing Control Position Sensor (Left Bank)
P1145 Intake Valve Timing Control Position Sensor (Right Bank)
P1148 Closed Loop Control (Bank 1)
P1165 Swirl Control Valve Control Vacuum Check Switch
P1168 Closed Loop Control (Bank 2)
P1210 Traction Control System (TCS) Signal Circuit
P1220 Fuel Pump Control Module (FPCM)
P1320 Ignition Signal, Primary
P1335 Crankshaft Position Sensor (CKPS) (Ref)
P1336 Crankshaft Position Sensor (CKPS) (Cog)
P1400 EGRC Solenoid Valve
P1401 EGR Temperature Sensor
P1402 EGR Function (Open)
P1440 EVAP Control System (Small Leak) (Positive Pressure)
P1441 VC/V Bypass Valve
P1443 Canister Control Vacuum Check Switch
P1444 Canister Purge Volume Control Solenoid Valve
P1445 Purge Volume Control/V
P1446 EVAP Canister Vent Control Valve (Close)
P1447 EVAP Control System Purge Flow Monitoring
P1448 EVAP Canister Vent Control Valve (Open)
P1490 Vacuum Cut Valve Bypass Valve (Circuit)
P1491 Vacuum Cut Valve Bypass Valve
P1492 EVAP Canister Purge Control/Solenoid Valve (Circuit)
P1493 EVAP Canister Purge Control Valve/Solenoid Valve
P1605 A/T Diagnosis Communication Line
P1705 Throttle Position Sensor
P1706 PNP Switch
P1760 Overrun Clutch Solenoid Valve
P1900 Cooling Fan
[b]Isuzu Specific Trouble Codes [/b]
P1106 MAP Circuit Intermittent Voltage High
P1107 MAP Circuit Intermittent Voltage Low
P1108 Barometric Pressure Circuit Input High
P1111 IAT Sensor Circuit Intermittent Voltage High
P1112 IAT Sensor Circuit Intermittent Voltage Low
P1114 ECT Sensor Circuit Intermittent Voltage Low
P1115 ECT Sensor Circuit Intermittent Voltage High
P1121 TP Sensor Circuit Intermittent Voltage High
P1122 TP Sensor Circuit Intermittent Voltage Low
P1133 H02S Insufficient Switching Bank 1 Sensor 1
P1134 H02S Transition Time Ratio Bank 1 Sensor 1
P1153 H02S Insufficient Switching Bank 2 Sensor 1
P1154 H02S Transition Time Ratio Bank 2 Sensor 1
P1171 Fuel System Lean During Acceleration
P1297 Electrical Load Detector Circuit Input Low
P1298 Electrical Load Detector Circuit Input High
P1300 Random Misfire
P1336 CKP System Variation Not Learned
P1359 CKP/TDC Sensor Disconnected
P1361 TDC Sensor Intermittent Interruption
P1362 TDC Sensor No Signal
P1380 ABS Rough Road System Fault
P1381 Cylinder Position Sensor Intermittent Interruption, Misfire Detected (Except 1998 Rodeo)
P1381 ABS Rough Road Class 2 Serial Data Fault Or Link Error (1998 Rodeo)
P1390 G Sensor Circuit Intermittent Voltage Low
P1391 G Sensor Performance
P1392 G Sensor Voltage Low
P1393 G Sensor Voltage High
P1394 G Sensor Intermittent Voltage High
P1404 EGR Valve Stuck Closed
P1406 EGR Valve Pintle Position Circuit
P1441 EVAP System Flow During Non-Purge
P1442 EVAP Vacuum Switch Voltage High During Ignition On
P1498 EGR Valve Lift Sensor Voltage High
P1508 IAC System RPM Low
P1509 IAC System RPM High
P1546 A/C Compressor Clutch Output Circuit Malfunction
P1548 A/C Compressor Clutch Output Circuit Malfunction
P1607 PCM Internal Circuit Failure A
P1618 SPI Communications Error
P1625 PCM Unexpected Reset
P1627 PCM A/D Conversion Malfunction
P1635 5 Volt Reference Voltage Circuit Malfunction
P1640 ODM 1 Input Voltage High (Except 1998 Rodeo)
P1640 ODM Output A Circuit Fault (1998 Rodeo)
P1650 Quad Driver Module A Fault
P1790 Trans ROM Checksum Error
P1792 Trans EEPROM Checksum Error
P1835 Trans Kickdown Switch Malfunction
P1850 Brake Band Apply Solenoid Malfunction
P1860 TCC PWM Solenoid Circuit Failure
P1870 Transmission Component Slipping
[b]Kia Specific Trouble Codes [/b]
P1115 Engine Coolant Temperature Signal from ECM to TCM.
P1121 Throttle Position Sensor Signal Malfunction from ECM to TCM.
P1170 Front Heated Oxygen Sensor Stuck.
P1195 EGR Pressure Sensor (1.6L) or Boost Sensor (1.8L) Open or Short.
P1196 Ignition Switch "Start" Open or Short (1.6L).
P1250 Pressure Regulator Control Solenoid Valve Open or Short.
P1252 Pressure Regulator Control Solenoid Valve No. 2 Circuit Malfunction.
P1307 Chassis Acceleration Sensor Signal Malfunction.
P1308 Chassis Acceleration Sensor Signal Low.
P1309 Chassis Acceleration Sensor Signal High.
P1345 No SGC Signal (1.6L).
P1386 Knock Sensor Control Zero Test.
P1402 EGR Valve Position Sensor Open or Short.
P1449 Canister Drain Cut Valve Open or Short (1.8L).
P1450 Excessive Vacuum Leak.
P1455 Fuel Tank Sending Unit Open or Short (1.8L).
P1457 Purge Solenoid Valve Low System Malfunction.
P1458 A/C Compressor Control Signal Malfunction.
P1485 EGR Solenoid Valve Vacuum Open or Short.
P1486 EGR Solenoid Valve Vent Open or Short.
P1487 EGR Boost Sensor Solenoid Valve Open or Short.
P1496 EGR Stepper Motor Malfunction - Circuit 1 (1.8L).
P1497 EGR Stepper Motor Malfunction - Circuit 2 (1.8L).
P1498 EGR Stepper Motor Malfunction - Circuit 3 (1.8L).
P1499 EGR Stepper Motor Malfunction - Circuit 4 (1.8L).
P1500 No Vehicle Speed Signal to TCM.
P1505 Idle Air Control Valve Opening Coil Voltage Low.
P1506 Idle Air Control Valve Opening Coil Voltage High.
P1507 Idle Air Control Valve Closing Coil Voltage Low.
P1508 Idle Air Control Valve Closing Coil Voltage High.
P1523 VICS Solenoid Valve.
P1586 A/T-M/T Codification.
P1608 PCM Malfunction.
P1611 MIL Request Circuit Voltage Low.
P1614 MIL Request Circuit Voltage High.
P1624 MIL Request Signal from TCM to ECM.
P1631 Alternator "T" Open or No Power Output (1.8L).
P1632 Battery Voltage Detection Circuit for Alternator Regulator (1.8L).
P1633 Battery Overcharge.
P1634 Alternator "B" Open (1.8L).
P1693 MIL Circuit Malfunction.
P1743 Torque Converter Clutch Solenoid Valve Open or Short.
P1794 Battery or Circuit Failure.
P1795 4WD Switch Signal Malfunction.
P1797 P or N Range Signal or Clutch Pedal Position Switch Open or Short.
[b]Land Rover Specific Trouble Codes P0***[/b]
*inclusief P0*** waarschijnlijk andere vertalling maar wat extra is nooit weg :)*
When an OBD-II fault occurs in Land Rover's Generic Engine Management System (GEMS), the Malfunction Indicator Lamp (MIL) is illuminated. GEMS Diagnostic Trouble Codes (DTC ) are stored in the Engine Control Module (ECM ) and may be retrieved by connecting a suitable OBD II Scan Tool or the Land Rover TestBook Electronic Tester to the Data Link Connector (DLC ). DTC's can only be Extracted, Diagnosed and Cleared by the TestBook Diagnostic Unit, a required special tool , or an appropriate after market equivalent.
All information regarding DTC's for this model is contained within the Land Rover TestBook Diagnostic Unit. The manufacturer does not provide any other information on pulling codes, descriptions, diagnosis, clear codes, etc.
*Codes* are used to identify the 4 Oxygen Sensors.
A = Bank A of the engine. Cylinder #1 is located on Engine Bank A.
B = Bank B of the engine.
U = Upstream of the Catalytic Converter.
D = Downstream of the Catalytic Converter.
Example: A D = Oxygen Sensor Engine Bank A, Downstream of Catalytic Converter.
P0101 Mass Air Flow Sensor Signal Error Fault
P0102 Mass Air Flow Sensor Low Out of Range Fault
P0103 Mass Air Flow Sensor High Out of Range Fault
P0111 Air Temperature Sensor Signal Error Fault
P0112 Air Temperature Sensor Low Out of Range Fault
P0113 Air Temperature Sensor High Out of Range Fault
P0116 Engine Coolant Temperature Sensor Falling Temp Fault
P0117 Engine Coolant Temperature Sensor Low Out of Range Fault
P0118 Engine Coolant Temperature Sensor High Out of Range Fault
P0121 Throttle Position Sensor Output Signal Error Fault
P0122 Throttle Position Sensor Low Out of Range Fault
P0123 Throttle Position Sensor High Out of Range Fault
P0125 Engine Coolant Temp Sensor Warm Up Fault
P0130 Oxygen Sensor Cycle Fault *Codes* A U
P0131 Oxygen Sensor Low Voltage *Codes* A U
P0132 Oxygen Sensor High Voltage *Codes* A U
P0133 Oxygen Sensor Slow Response *Codes* A U
P0136 Oxygen Sensor Cycle Fault *Codes* A D
P0137 Oxygen Sensor Low Voltage *Codes* A D
P0138 Oxygen Sensor High Voltage *Codes* A D
P0139 Oxygen Sensor Slow Response *Codes* A D
P0150 Oxygen Sensor Cycle Fault *Codes* B U
P0151 Oxygen Sensor Low Voltage *Codes* B U
P0152 Oxygen Sensor High Voltage *Codes* B U
P0153 Oxygen Sensor Slow Response *Codes* B U
P0156 Oxygen Sensor Cycle Fault *Codes* B D
P0157 Oxygen Sensor Low Voltage *Codes* B D
P0158 Oxygen Sensor High Voltage *Codes* B D
P0159 Oxygen Sensor Slow Response *Codes* B D
P0171 Oxygen Sensor System Too Lean Fault Bank A
P0172 Oxygen Sensor System Too Rich Fault Bank A
P0174 Oxygen Sensor System Too Lean Fault Bank B
P0175 Oxygen Sensor System Too Rich Fault Bank B
P0181 Fuel Temperature Sensor Signal Error Fault
P0182 Fuel Temperature Sensor Low Out of Range Fault
P0183 Fuel Temperature Sensor High Out of Range Fault
P0201 Injector 1 Circuit Fault
P0202 Injector 2 Circuit Fault
P0203 Injector 3 Circuit Fault
P0204 Injector 4 Circuit Fault
P0205 Injector 5 Circuit Fault
P0206 Injector 6 Circuit Fault
P0207 Injector 7 Circuit Fault
P0208 Injector 8 Circuit Fault
P0300 Misfire On Multiple Cylinder
P0301 Misfire Cylinder 1
P03O2 Misfire Cylinder 2
P03O3 Misfire Cylinder 3
P0304 Misfire Cylinder 4
P0305 Misfire Cylinder 5
P0306 Misfire Cylinder 6
P0307 Misfire Cylinder 7
P0308 Misfire Cylinder 8
P0326 Continuous Knock Fault Bank A
P0327 Background Noise Low Fault Bank A
P0328 Background Noise High Fault Bank A
P0331 Continuous Knock Fault Bank B
P0332 Background Noise Low Fault Bank B
P0333 Background Noise High Fault Bank B
P0335 Crankshaft Position Sensor Signal Error Fault
P0336 Crankshaft Position Sensor Out of Range Fault
P0340 Camshaft Position Sensor Signal Error Fault
P0420 Catalyst Efficiency Low Fault Bank A
P0430 Catalyst Efficiency Low Fault Bank B
P0441 Evap Purge Valve Incorrect Flow Fault
P0442 Evap System Small Leak Detected Fault
P0443 Evap Purge Valve Open or Short Circuit Fault
P0451 Fuel Tank Pressure Sensor Signal Error Fault
P0452 Fuel Tank Pressure Sensor Low out of Range Fault
P0453 Fuel Tank Pressure Sensor High Out of Range Fault
P0461 Fuel Tank Level Measurement Not Valid Fault
P0500 Vehicle Speed Sensor Signal Error Fault
P0506 Idle Speed Control Engine Speed Low Fault
P0507 Idle Speed Control Engine Speed High Fault
P0560 Battery Voltage Below Minimum Fault
P0562 Measurement Circuit OK Battery Voltage Low Fault
P0563 Battery Voltage Above Maximum Fault
P0605 ECM Self Test Fault
[b]Land Rover Specific Trouble Codes[/b]
P1130 Oxygen Sensor Fuel Trim at Limit *Codes* A U
P1131 Oxygen Sensor Engine Lean *Codes* A U
P1132 Oxygen Sensor Engine Rich *Codes* A U
P1137 Oxygen Sensor Engine Lean *Codes* A D
P1138 Oxygen Sensor Engine Rich *Codes* A D
P1150 Oxygen Sensor Fuel Trim at Limit *Codes* B U
P1151 Oxygen Sensor Engine Lean *Codes* B U
P1152 Oxygen Sensor Engine Rich *Codes* B U
P1157 Oxygen Sensor Engine Lean *Codes* B D
P1158 Oxygen Sensor Engine Rich *Codes* B D
P1171 Oxygen Sensor System Too Lean Fault Banks A & B
P1172 Oxygen Sensor System Too Rich Fault Banks A & B
P1176 Maximum Positive FMFR Correction Fault
P1177 Maximum Negative FMFR Correction Fault
P1178 Maximum Positive AMFR Correction Fault
P1179 Maximum Negative AMFR Correction Fault
P1185 Oxygen Sensor Heater Circuit Open Upstream
P1186 Oxygen Sensor Heater Circuit Short Upstream
P1187 Oxygen Sensor Heater Circuit Short Upstream
P1188 Oxygen Sensor Heater High Resistance Upstream
P1189 Oxygen Sensor Heater Type 1 Low Resistance Upstream
P1190 Oxygen Sensor Heater Type 2 Low Resistance Upstream
P1191 Oxygen Sensor Heater Circuit Open Downstream
P1192 Oxygen Sensor Heater Circuit Short Downstream
P1193 Oxygen Sensor Heater Circuit Open Downstream
P1194 Oxygen Sensor Heater High Resistance Downstream
P1195 Oxygen Sensor Heater Type 1 Low Resistance Downstream
P1196 Oxygen Sensor Heater Type 2 Low Resistance Downstream
P1199 Fuel Level Sensor Circuit Fault
P1201 Injector 1 Open Circuit or Ground Short Fault
P1202 Injector 2 Open Circuit or Ground Short Fault
P1203 Injector 3 Open Circuit or Ground Short Fault
P1204 Injector 4 Open Circuit or Ground Short Fault
P1205 Injector 5 Open Circuit or Ground Short Fault
P1206 Injector 6 Open Circuit or Ground Short Fault
P1207 Injector 7 Open Circuit or Ground Short Fault
P1208 Injector 8 Open Circuit or Ground Short Fault
P1313 Misfire Catalyst Damage Fault Bank A
P1314 Misfire Catalyst Damage Fault Bank B
P1315 Misfire Persistent Fault
P1316 Misfire Excessive Emissions Fault
P1317 ABS Rough Road Line Low Fault
P1318 ABS Rough Road Line High Fault
P1361 No Ignition Coil Activation Fault Coil 1
P1362 No Ignition Coil Activation Fault Coil 2
P1363 No Ignition Coil Activation Fault Coil 3
P1364 No Ignition Coil Activation Fault Coil 4
P1371 Early Ignition Coil Activation Fault Coil 1
P1372 Early Ignition Coil Activation Fault Coil 2
P1373 Early Ignition Coil Activation Fault Coil 3
P1374 Early Ignition Coil Activation Fault Coil 4
P1440 Evap System Purge Valve Stuck Open Fault
P1441 Evap System Purge Valve Flow 1 Fault
P1442 Evap System Purge Valve Blocked Fault
P1447 Evap System Purge Valve Open or Short Circuit Fault
P1448 Evap System Purge Valve Flow 2 Fault
P1508 Idle Speed Control Open Circuit Fault
P15O9 Idle Speed Control Short Circuit Fault
P1514 Neutral Drive Load Fault
P1516 Neutral Drive Gear Change Fault
P1517 Neutral Drive Cranking Fault
P1607 Malfunction Indicator Lamp Short Circuit Fault
P1608 Malfunction Indicator Lamp Open Circuit Fault
P1620 Reprogramming Code Learn Fault
P1621 Serial Data Link Dead Fault
P1622 Repeated Wrong ECM Security Code Fault
P1623 ECM Security Code Fault
P1701 Transfer Box Line Fault
P1703 Transfer Box Line Open Circuit Fault
P1708 Transfer Box Line Short Circuit Fault
P1775 Gearbox Fault
P1776 Gearbox Ignition Retard Request Timeout Fault
P1777 Gearbox Ignition Retard Request Line Fault
[b]Lexus Specific Trouble Codes [/b]
P1100 BARO Sensor Circuit Malfunction
P1120 Accelerator Pedal Position Sensor Circuit Malfunction
P1121 Accelerator Pedal Position Sensor Range/Performance Problem
P1125 Throttle Control Motor Circuit Malfunction
P1126 Magnetic Clutch Circuit Malfunction
P1127 ECTS Actuator Power Source Circuit Malfunction
P1128 Throttle Control Motor Lock Malfunction
P1129 Electronic Throttle Control System
P1130 Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1)
P1133 Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 1 Sensor 1)
P1135 Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P1150 Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1)
P1153 Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 2 Sensor 1)
P1155 Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P1200 Fuel Pump Relay/ECU Circuit Malfunction
P1300 Igniter Circuit Malfunction (Bank 1 Or No. 1)
P1305 Igniter Circuit Malfunction, (Bank 2 Or No. 2)
P1310 Igniter Circuit Malfunction (No. 3)
P1315 Igniter Circuit Malfunction (No. 4)
P1320 Igniter Circuit Malfunction (No. 5)
P1325 Igniter Circuit Malfunction (No. 6)
P1330 Igniter Circuit Malfunction (No. 7)
P1335 CKP Sensor Circuit Malfunction During Engine Running
P1340 Igniter Circuit Malfunction (No. 8)
P1345 VVT Sensor Circuit Malfunction (Bank 1)
P1346 VVT Sensor Rang/Performance Problem (Bank 1)
P1349 VVT System Malfunction (Bank 1)
P1350 VVT Sensor Circuit Malfunction (Bank 2)
P1351 VVT Sensor Range/Performance Problem (Bank 2)
P1354 VVT System Malfunction (Bank 2)
P1400 Sub-TP Sensor Malfunction
P1401 Sub-TP Sensor Range/Performance
P1410 EGR Valve Position Sensor Circuit Malfunction
P1411 EGR Valve Position Sensor Circuit Range/Performance Malfunction
P1500 Starter Signal Circuit Malfunction
P1520 Stop Lamp Switch Malfunction
P1565 Cruise Control Main Switch Circuit Malfunction
P1566 Cruise Control Main Switch Circuit Malfunction
P1600 ECM BATT Malfunction
P1605 Knock Control CPU Malfunction
P1633 ECM Malfunction (ETCS Circuit)
P1645 Body ECU Malfunction
P1656 OCV Circuit Malfunction (Bank 1)
P1663 OCV Circuit Malfunction (Bank 2)
P1780 PNP Switch Malfunction
[b] B**** codes [/b]
B2785 Ignition Switch On Malfunction (Immobilizer System)
B2786 Ignition Switch Off Malfunction (Immobilizer System)
B2791 Key Unlock Warning Switch Malfunction (Immobilizer System)
B2795 Unmatch Key Code (Immobilizer System)
B2796 No Communication In Immobilizer System
B2797 Communication Malfunction No. 1 (Immobilizer System)
B2798 Communication Malfunction No. 2 (Immobilizer System)
[b]Mazda Specific Codes[/b]
P1000 OBD II Monitor Testing Not Completed
P1001 Unable to Achieve Self-Test Function or SCP Error
P1100 Mass Airflow Sensor Circuit Intermittent
P1101 Mass Airflow Sensor Circuit out of Self-Test Range
P1102 Mass Airflow Sensor Signal Inconsistent with Throttle Position Sensor
P1103 Mass Airflow Sensor Signal Inconsistent with Engine Speed
P1110 Intake Air Temperature Sensor Signal (Dynamic Chamber) Circuit
P1112 Intake Air Temperature Sensor Circuit Intermittent
P1113 Intake Air Temperature Sensor Signal (Dynamic Chamber) Circuit
P1114 Intake Air Temperature Sensor Circuit Low Input
P1116 ECT Sensor Circuit Out of Self Test Range
P1117 ECT Sensor Signal Intermittent
P1120 Throttle Position Sensor out of Range Low
P1121 Throttle Position Sensor Signal Not Consistent with Mass Airflow Signal
P1122 Throttle Position Stuck Closed
P1123 Throttle Position Stuck Open
P1124 Throttle Position Sensor Signal Out of Self Test Range
P1125 Throttle Position Sensor Signal Intermittent
P1127 HO2S Bank 1 Sensor 2 Heater Not On During Key On Engine Running Self Test
P1128 HO2S Bank 1 Sensor 1 Signals Swapped in Key On Engine Running Self Test
P1130 HO2S Bank 1 Sensor 1 Not Switching (Fuel Control Limit Reached)
P1131 HO2S Bank 1 Sensor 1 Signal Below 0.45v (A/F Ratio Too Lean)
P1132 HO2S Bank 1 Sensor 1 Signal Above 0.45v (A/F Ratio Too Rich)
P1135 HO2S Bank 1 Sensor 1 Heater Circuit Low Input
P1136 HO2S Bank 1 Sensor 1 Heater Circuit High Input
P1137 HO2S Bank 1 Sensor 2 Not Switching (Fuel Control Limit Reached)
P1138 HO2S Bank 1 Sensor 2 Signal Above 0.45v (A/F Ratio Too Rich)
P1141 HO2S Bank 1 Sensor 2 Heater Circuit Low Input
P1142 HO2S Bank 1 Sensor 2 Heater Circuit High Input
P1143 HO2S Bank 1 Sensor 3 Signal Below 0.45v (A/F Ratio Too Lean)
P1144 HO2S Bank 1 Sensor 3 Signal Above 0.45v (A/F Ratio Too Rich)
P1150 HO2S Bank 2 Sensor 1 Not Switching (Fuel Control Limit Reached)
P1151 HO2S Bank 2 Sensor 1 Signal Below 0.45v (A/F Ratio Too Lean)
P1152 HO2S Bank 2 Sensor 1 Signal Above 0.45v (A/F Ratio Too Rich)
P1169 HO2S Bank 1 Sensor 1 Circuit Fixed (Bank 1 Sensor 1)
P1170 HO2S Bank 1 Sensor 1 Circuit Fixed (Bank 1 Sensor 1)
P1173 HO2S Bank 2 Sensor 1 Circuit Fixed (Bank 2 Sensor 1)
P1195 EGR Boost Sensor Circuit
P1196 Ignition Switch Start Circuit
P1235 Fuel Pump Control Circuit
P1236 Fuel Pump Control Out Range
P1250 Pressure Regulator Control Solenoid Circuit
P1252 Pressure Regulator Control Solenoid '2' Circuit
P1260 Anti-Theft System Signal Detected - Engine Disabled
P1270 Engine RPM or Vehicle Speed Limit Reached
P1345 No CMP or SGC Signal
P1351 Ignition Diagnostic Monitor Signal Lost to PCM or Out Of Range
P1352 Ignition Coil 'A' Primary Circuit
P1353 Ignition Coil 'B' Primary Circuit
P1354 Ignition Coil 'C' Primary Circuit
P1358 Ignition Diagnostic Monitor Signal Out Of Self Test Range
P1359 SPOUT Signal Lost To Powertrain Control Module Or Out Of Range
P1360 Ignition Coil 'A' Secondary Circuit
P1361 Ignition Coil 'B' Secondary Circuit
P1362 Ignition Coil 'C' Secondary Circuit
P1364 Ignition Coil Primary Circuit
P1365 Ignition Coil Secondary Circuit
P1390 Octane Adjust Shorting Bar Out or Circuit Open
P1400 DPFE Sensor Circuit Low Input
P1401 DPFE Sensor Circuit High Input
P1402 EGR Valve Position Sensor Circuit
P1405 DPFE Sensor Upstream Hose Off Or Plugged
P1406 DPFE Sensor Downstream Hose Off or Plugged
P1407 No EGR Flow Detected
P1408 EGR System Flow Out of Key On Engine Running Self Test Range
P1409 EGR Vacuum Regulator Solenoid Circuit
P1410 EGR Boost Solenoid Valve Stuck
P1443 EVAP System Purge Flow Fault
P1444 EVAP Purge Flow Sensor Circuit Low Voltage
P1446 EVAP Purge Flow Sensor Circuit High Voltage
P1449 CDCV or Throttle PositionCV Circuit
P1450 EVAP Control System Fault
P1451 Canister Vent Solenoid Circuit
P1455 Fuel Tank Level Sensor Circuit
P1460 Wide Open Throttle A/C Cut-Off Relay Circuit
P1464 Air Conditioning Control Signal Circuit
P1474 Fan Control (Primary Winding) Circuit
P1479 Fan Control (Condenser Primary) Circuit
P1485 EGR Vacuum Solenoid Circuit
P1486 EGR Vent Solenoid Circuit
P1487 EGR-CHK (Boost) Solenoid Circuit
P1496 EGR Valve Motor Coil '1' Open or Shorted
P1497 EGR Valve Motor Coil '2' Open or Shorted
P1498 EGR Valve Motor Coil '3 Open or Shorted
P1499 EGR Valve Motor Coil '4' Open or Shorted
P1500 Vehicle Speed Sensor Intermittent Signal
P1501 Vehicle Speed Sensor Out of Self Test Range
P1502 Vehicle Speed Sensor Circuit Error
P1504 Idle Air Control Solenoid Circuit Intermittent
P1506 Idle Air Control System Overspeed Detected
P1507 Idle Air Control System Underspeed Detected
P1508 Bypass Air Solenoid '1' Circuit
P1509 Bypass Air Solenoid '2 Circuit
P1512 VTCS Fault
P1521 VRIS Solenoid '1' Circuit
P1522 VRIS Solenoid '2 Circuit
P1523 VICS Solenoid Circuit
P1524 Charge Air Cooler Bypass Solenoid Circuit
P1525 ABV Vacuum Solenoid Circuit
P1526 ABV Vent Solenoid Circuit
P1529 L/C Atmospheric Balance Air Control Valve Circuit
P1540 ABV System Fault
P1562 Powertrain Control Module +BB Voltage Low
P1569 VTCS Circuit Low Input
P1570 VTCS Circuit High Input
P1601 Powertrain Control Module Communication Line to TCM Error
P1602 Powertrain Control Module Communication Line to TCM Error
P1602 Immobilizer System Communication Error with Powertrain Control Module
P1603 Immobilizer System Fault
P1604 Immobilizer System Fault
P1605 Powertrain Control Module Keep Alive Memory Test Error
P1608 Powertrain Control Module (ECM CPU) DTC Test Fault
P1609 Powertrain Control Module (ECM CPU) Knock Sensor Circuit
P1621 lmmobilizer System Fault
P1622 lmmobilizer System Fault
P1623 lmmobilizer System Fault
P1624 lmmobilizer System Fault
P1627 Powertrain Control Module (ECM/TCS) Line Communication Error
P1628 Powertrain Control Module (ECM/TCS) Any Line Communication Error
P1631 Generator Output Voltage Signal (No Output)
P1632 Battery Voltage Monitor Circuit
P1633 Battery Overcharge Fault
P1634 Generator Terminal 'B' Circuit Open
P1650 Power Steering Pressure Switch Out of Range Fault
P1651 Power Steering Pressure Switch Circuit
P1652 Power Steering Pressure Switch Circuit
P1701 Transmission Range Sensor Reverse Engagement Error
P1702 Transmission Range Sensor Circuit Intermittent
P1703 Brake On/Off Switch Out of Self Test Range
P1705 Transmission Range Sensor out of Self Test Range
P1709 Clutch Pedal Position Switch Circuit
P1711 Transmission Fluid Temperature Sensor Circuit out of Self Test Range
P1713 Transmission Fluid Temperature Sensor Circuit
P1714 Shift Solenoid '1' Mechanical Fault
P1715 Shift Solenoid '2' Mechanical Fault
P1716 Shift Solenoid '3' Mechanical Fault
P1717 Shift Solenoid '4' Mechanical Fault
P1718 Transmission Fluid Temperature Sensor Circuit
P1720 Vehicle Speed Sensor '2' Signal Error
P1729 Transmission 4x4 Low Switch Error
P1740 Torque Converter Clutch Solenoid Mechanical Fault
P1741 Torque Converter Clutch Control Electrical Fault
P1742 Torque Converter Clutch Solenoid Shorted
P1743 Torque Converter Clutch Failed On - TCIL is On
P1744 Torque Converter Clutch Solenoid Mechanical Fault
P1746 Electronic Pressure Control Solenoid Circuit Open
P1747 Electronic Pressure Control Solenoid Circuit
P1749 Electronic Pressure Control Solenoid Circuit Low
P1751 Transmission Shift Solenoid 'A' Mechanical Fault
P1752 Transmission Shift Solenoid 'A' Circuit Shorted
P1754 Transmission Coast Clutch Solenoid Electrical Fault
P1756 Transmission Shift Solenoid 'B' Mechanical Fault
P1757 Transmission Shift Solenoid 'B' Circuit Shorted
P1761 Transmission Shift Solenoid '3' Mechanical Fault
P1762 Transmission SS3/SS4/OD Band Fault
P1765 Transmission 3-2 Timing Solenoid Valve
P1767 Torque Converter Clutch Solenoid Circuit
P1771 Throttle Position Sensor Circuit Open to Transmission Control Module
P1772 Throttle Position Sensor Circuit Shorted to Transmission Control Module
P1780 Transmission Control Switch Circuit
P1780 Overdrive Off Switch not Cycled during the Self Test
P1781 Transmission 4x4 Low Switch out of Range Fault
P1783 Transmission Fluid Temperature High Input
P1788 3-2T/CCS Circuit Open
P1789 3-2T/CCS Circuit Shorted
P1794 Powertrain Control Module Battery Direct Power Circuit
P1797 P/N Switch Open or Short Circuit
P1900 Turbine Speed Sensor Circuit Intermittent
P1901 Torque Converter Clutch Circuit Intermittent
[b]Mitsubishi Specific Trouble Codes [/b]
P1103 Turbocharger Wastegate Actuator.
P1104 Turbocharger Wastegate Solenoid.
P1105 Fuel Pressure Solenoid.
P1300 Ignition Timing Adjustment circuit.
P1400 Manifold Differential Pressure Sensor circuit.
P1500 Alternator FR Terminal circuit.
P1600 Serial Communication Link.
P1715 Pulse Generator Assembly.
P1750 Solenoid Assembly.
P1751 A/T Control Relay.
P1791 Engine Coolant Temperature Level Input circuit.
P1795 Throttle Position Input circuit to TCM.
[b]Nissan Specific Trouble Codes[/b]
P1105 MAP/BARO Pressure Switch Solenoid Valve
P1126 Thermostat Function
P1165 Swirl Control Valve Control Vacuum Switch
P1211 ABS/TCS Control Unit
P1212 ABS/TCS Communication Line
P1217 Engine Over Temperature (Overheat)
P1335 Crankshaft Position Sensor (REF)
P1402 EGR System
P1440 EVAP Control System Small Leak
P1441 Vacuum Cut Valve Bypass Valve
P1445 EVAP Canister Purge Volume Control Valve
P1446 EVAP Canister Vent Control Valve (Closed)
P1464 Fuel Level Sensor Circuit (Ground Signal)
P1550 TCC Solenoid Valve
P1605 A/T Diagnostic Communication Line
P1705 Throttle Position Sensor Circuit A/T
P1706 Park/Neutral Position (PNP) Switch
P1760 Overrun Clutch Solenoid Valve (Circuit)
[b] Subaru Specific Codes OBD-II OBD2 (1996 & newer) [/b]
P1086 Tumble generator valve #2 (LH) position sensor circuit low input
P1087 Tumble generator valve #2 (LH) position sensor circuit high input
P1088 Tumble generator valve #1 (RH) position sensor circuit low input
P1089 Tumble generator valve #1 (RH) position sensor circuit high input
P1090 Tumble generator valve #1 (RH) malfunction (stuck open)
P1091 Tumble generator valve #1 (RH) malfunction (stuck close)
P1092 Tumble generator valve #2 (LH) malfunction (stuck open)
P1093 Tumble generator valve #2 (LH) malfunction (stuck close)
P1094 Tumble generator valve circuit #1 (open circuit)
P1095 Tumble generator valve circuit #1 (over current)
P1096 Tumble generator valve circuit #2 (open circuit)
P1097 Tumble generator valve circuit #2 (over current)
P1100 Starter Switch Circuit Malfunction
P1101 Neutral Position Switch Circuit High Input (A/T)
P1101 Neutral Position Switch Circuit Malfunction (M/T)
P1102 Pressure Sources Solenoid Valve Circuit Malfunction
P1103 Pressure Sources Switching Solenoid Valve Circuit
P1104 Engine Torque Control Signal Circuit Malfunction
P1106 Engine Torque Control Signal 2 Circuit Malfunction
P1110 Atmospheric pressure sensor low input
P1111 Atmospheric pressure sensor high input
P1112 Atmospheric pressure sensor range/performance problem
P1115 Engine Torque Control Cut Signal Circuit High Input
P1116 Engine Torque Control Cut Signal Circuit Low Input
P1120 Starter Switch High Input
P1121 Neutral Position Switch Circuit High Input [MT Vehicles]
P1121 Neutral Position Switch Circuit Low Input [AT Vehicles]
P1122 Pressure Sources Switching Valve Circuit High Input
P1124 TCS Signal Circuit High Input
P1130 Front oxygen sensor circuit malfunction (open circuit)
P1131 Front oxygen sensor circuit malfunction (short circuit)
P1134 Front oxygen (A/F) sensor microcomputer problem
P1137 Front oxygen (A/F) sensor circuit range/performance problem
P1139 Front oxygen (A/F) sensor #1 heater circuit performance/range problem
P1141 Mass Air Flow Sensor Circuit High Input
P1142 Mass Air Flow Sensor Circuit Low Input
P1143 Pressure Sensor Circuit Low Input
P1144 Pressure Sensor Circuit High Input
P1146 Pressure sensor circuit range/performance problem (high input)
P1150 Front Oxygen Sensor Heater Circuit High Input
P1151 Rear Oxygen Sensor Heater Circuit High Input
P1230 Fuel pump control unit malfunction
P1244 Wastegate control solenoid valve malfunction (low input)
P1245 Wastegate control solenoid valve malfunction (fail-safe)
P1301 Fire due to increased exhaust temperature
P1312 Exhaust temperature sensor malfunction
P1325 Knock Sensor Circuit Low Input
P1400 Fuel Tank Pressure Control Solenoid Low Input
P1420 Fuel Tank Pressure Control Solenoid High Input
P1421 Exhaust Gas Recirculation Circuit High Input
P1422 EVAP Purge Control Valve Circuit High Input
P1423 EVAP Vent Control High Input
P1440 Fuel Tank Pressure Control System Low Input
P1441 Fuel Tank Pressure Control System High Input
P1442 Fuel Level Sensor Circuit Range/Perf
P1443 EVAP Control System Vent Control Function Problem
P1480 Cooling fan relay 1 circuit high input
P1500 Radiator Fan Relay 1 Circuit Malfunction
P1501 Idle Control System Malfunction (Fail Safe)
P1502 Radiator Fan Function Problem
P1507 Idle Control System Malfunction (Fail Safe)
P1510 Idle Air Control Solenoid Signal 1 Circuit Low Input
P1511 Idle Air Control Solenoid Signal 1 Circuit High Input
P1512 Idle Air Control Solenoid Signal 2 Circuit Low Input
P1513 Idle Air Control Solenoid Signal 2 Circuit High Input
P1514 Idle Air Control Solenoid Signal 3 Circuit Low Input
P1515 Idle Air Control Solenoid Signal 3 Circuit High Input
P1516 Idle Air Control Solenoid Signal 4 Circuit Low Input
P1517 Idle Air Control Solenoid Signal 4 Circuit High Input
P1518 Starter switch circuit low input
P1520 Radiator Fan Relay 1 Circuit High Input
P1540 Vehicle Speed Sensor Malfunction 2
P1544 High exhaust temperature detected
P1560 Back-Up Voltage Circuit Malfunction
P1590 Neutral position switch circuit high input
P1591 Neutral position switch circuit low input
P1592 Neutral position switch circuit (MT model)
P1594 Automatic transmission diagnosis input signal circuit malfunction
P1595 Automatic transmission diagnosis input signal circuit low input
P1596 Automatic transmission diagnosis input signal circuit high input
P1698 Engine torque control cut signal circuit low input
P1699 Engine torque control cut signal circuit high input
P1700 Throttle Position Sensor Circuit Malfunction (A/T)
P1701 Cruise Control Set Signal Circuit Malfunction (A/T)
P1702 Auto Trans Diagnosis Input Signal Circuit
P1703 Low clutch timing control solenoid valve circuit malfunction
P1704 2-4 Brake Timing Solenoid Valve Circuit Malfunction
P1705 2-4 Brake Pressure Solenoid Valve (Solenoid D) Circuit
P1711 Engine torque control signal 1 circuit malfunction
P1712 Engine torque control signal 2 circuit malfunction
P1722 Auto Trans Diagnosis Input Signal High Input
P1742 Auto Trans Diagnosis Input Signal Malfunction
Renaultmonteurtje Topicstarter 33.765 km Reageer
[b]Toyota Specific Trouble Codes [/b]
P1100 BARO Sensor Circuit.
P1120 Accelerator Pedal Position Sensor Circuit.
P1121 Accelerator Pedal Position Sensor Range/Performance Problem.
P1125 Throttle Control Motor Circuit.
P1126 Magnetic Clutch Circuit.
P1127 ETCS Actuator Power Source Circuit.
P1128 Throttle Control Motor Lock.
P1129 Electric Throttle Control System.
P1130 Air/Fuel Sensor Circuit Range/Performance. (Bank 1 Sensor 1)
P1133 Air/Fuel Sensor Circuit Response. (Bank 1 Sensor 1)
P1135 Air/Fuel Sensor Heater Circuit Response. (Bank 1 Sensor 1)
P1150 Air/Fuel Sensor Circuit Range/Performance. (Bank 1 Sensor 2)
P1153 Air/Fuel Sensor Circuit Response. (Bank 1 Sensor 2)
P1155 Air/Fuel Sensor Heater Circuit. (Bank 1 Sensor 2)
P1200 Fuel Pump Relay Circuit.
P1300 Igniter Circuit Malfunction - No. 1.
P1310 Igniter Circuit Malfunction - No. 2.
P1335 No Crankshaft Position Sensor Signal - Engine Running.
P1349 VVT System.
P1400 Sub-Throttle Position Sensor.
P1401 Sub-Throttle Position Sensor Range/Performance Problem.
P1405 Turbo Pressure Sensor Circuit.
P1406 Turbo Pressure Sensor Range/Performance Problem.
P1410 EGR Valve Position Sensor Circuit Malfunction.
P1411 EGR Valve Position Sensor Circuit Range/Performance.
P1500 Starter Signal Circuit.
P1510 Boost Pressure Control Circuit.
P1511 Boost Pressure Low.
P1512 Boost Pressure High.
P1520 Stop Lamp Switch Signal Malfunction.
P1565 Cruise Control Main Switch Circuit.
P1605 Knock Control CPU.
P1630 Traction Control System.
P1633 ECM.
P1652 Idle Air Control Valve Control Circuit.
P1656 OCV Circuit.
P1658 Wastegate Valve Control Circuit.
P1661 EGR Circuit.
P1662 EGR by-pass Valve Control Circuit.
P1780 Park/Neutral Position Switch Malfunction (Only For A/T)
[b]VW Specific Trouble Codes [/b]
P1102 O2S Heating Circuit Bank 1 Sensor 1 Voltage Too Low/Air Leak
P1105 O2S Heating Circuit Bank 1 Sensor 2 Short To Positive
P1107 O2S Heating Circuit Bank 2 Sensor 1 Short To Positive
P1110 O2S Heating Circuit Bank 2 Sensor 2 Short To Positive
P1113 O2S Sensor Heater Resistance Too High Bank 1 Sensor 1
P1115 O2S Sensor Heater Circuit Short To Ground Bank 1 Sensor 1
P1116 O2S Sensor Heater Circuit Open Bank 1 Sensor 1
P1117 O2S Sensor Heater Circuit Short To Ground Bank 1 Sensor 2
P1118 O2S Sensor Heater Circuit Open Bank 1 Sensor 2
P1127 Long Term Fuel Trim B1 System Too Rich
P1128 Long Term Fuel Trim B1 System Too Lean
P1129 Long Term Fuel Trim B2 System Too Rich
P1130 Long Term Fuel Trim B2 System Too Lean
P1136 Long Term Fuel Trim Add. Fuel B1 System Too Lean
P1137 Long Term Fuel Trim Add. Fuel B1 System Too Rich
P1138 Long Term Fuel Trim Add. Fuel B2 System Too Lean
P1139 Long Term Fuel Trim Add. Fuel B2 System Too Rich
P1141 Load Calculation Cross Check Range/Performance
P1144 Mass Air Flow Sensor Open/Short To Ground.
P1145 Mass Air Flow Sensor Short To Positive.
P1146 Mass Air Flow Sensor Supply Voltage.
P1155 Manifold Absolute Pressure Sensor Short To Positive.
P1156 Manifold Absolute Pressure Sensor Open/Short To Ground.
P1157 Manifold Absolute Pressure Sensor Supply Voltage.
P1160 Intake Air Temperature Sensor Short To Ground.
P1161 Intake Air Temperature Sensor Open/Short To Positive.
P1162 Intake Air Temperature Sensor Short To Ground.
P1163 Fuel Temperature Sensor Open/Short To Positive.
P1164 Fuel Temperature Sensor Implausible Signal.
P1171 Throttle Actuation Potentiometer Sign. 2 Range/Performance
P1172 Throttle Actuation Potentiometer Sign. 2 Signal Too Low
P1173 Throttle Actuation Potentiometer Sign. 2 Signal Too High
P1176 Rear O2S Correction
P1177 O2 Correction Behind Catalyst B1 Limit Attained
P1196 O2S Heater Circuit Bank 1 Sensor 1 Electrical Malfunction
P1197 O2S Heater Circuit Bank 2 Sensor 1 Electrical Malfunction
P1198 O2S Heater Circuit Bank 1 Sensor 2 Electrical Malfunction
P1199 O2S Heater Circuit Bank 2 Sensor 2 Electrical Malfunction
P1213 Injector Circuit Cylinder 1 Short To Positive
P1214 Injector Circuit Cylinder 2 Short To Positive
P1215 Injector Circuit Cylinder 3 Short To Positive
P1216 Injector Circuit Cylinder 4 Short To Positive
P1217 Injector Circuit Cylinder 5 Short To Positive
P1218 Injector Circuit Cylinder 6 Short To Positive
P1225 Injector Circuit Cylinder 1 Short To Ground
P1226 Injector Circuit Cylinder 2 Short To Ground
P1227 Injector Circuit Cylinder 3 Short To Ground
P1228 Injector Circuit Cylinder 4 Short To Ground
P1229 Injector Circuit Cylinder 5 Short To Ground
P1230 Injector Circuit Cylinder 6 Short To Ground
P1237 Injector Circuit Open Cylinder 1
P1238 Injector Circuit Open Cylinder 2
P1239 Injector Circuit Open Cylinder 3
P1240 Injector Circuit Open Cylinder 4
P1241 Injector Circuit Open Cylinder 5
P1242 Injector Circuit Open Cylinder 6
P1245 Needle Lift Sensor Short To Ground
P1246 Needle Lift Implausible Signal
P1247 Needle Lift Sensor Open/Short To Positive
P1248 Start Of Cold Start Injector Control Difference
P1251 Start Of Cold Start Injector Short To Positive
P1252 Start Of Cold Start Injector Open/Short To Ground
P1255 Engine Coolant Temperature Sensor Short To Ground
P1256 Engine Coolant Temperature Sensor Open/Short To Positive
P1300 Misfire Detected, Fuel Level Too Low
P1250 Fuel Level Too Low
P1325 Cyl. 1 Knock Control Limit Attained
P1326 Cyl. 2 Knock Control Limit Attained
P1327 Cyl. 3 Knock Control Limit Attained
P1328 Cyl. 4 Knock Control Limit Attained
P1329 Cyl. 5 Knock Control Limit Attained
P1330 Cyl. 6 Knock Control Limit Attained
P1336 Engine Torque Adaption At Limit
P1337 CMP Sensor Bank 1 Short To Ground
P1338 CMP Sensor Bank 1 Open Circuit Or Short To Positive
P1340 CKP/CMP Sensor Signals Out Of Sequence
P1341 Ignition Coil Output Stage 1 Short To Ground
P1343 Ignition Coil Output Stage 2 Short To Ground
P1345 Ignition Coil Output Stage 3 Short To Ground
P1354 Modulating Piston Displacement Sensor Electrial Circuit Malfunction
P1386 Internal Control Module Knock Control Error
P1387 Control Unit Internal Altitude Sensor
P1391 CMP Sensor Bank 2 Short To Ground
P1392 CMP Sensor Bank 2 Open Circuit/Short To Positive
P1393 Ignition Coil Power Output Stage 1 Malfunction
P1394 Ignition Coil Power Output Stage 2 Malfunction
P1395 Ignition Coil Power Output Stage 3 Malfunction
P1401 EGR Valve Power Stage Short To Ground
P1402 EGR Vacuum Regulator Solenoid Valve Short To Positive
P1403 EGR System Control Difference
P1407 EGR Temperature Sensor Signal Too Low
P1408 EGR Temperature Sensor Signal Too High
P1410 Tank Ventilation Valve Circuit Short To B+
P1420 Secondary Air Injection Control Module Electrical Malfunction
P1421 Secondary Air Injection Valve Circuit Short To Ground
P1422 Secondary Air Injection Valve Circuit Short To B+
P1424 Secondary Air Injection System Bank 1 Leak Detected
P1425 Tank Ventilation Valve Short To Ground
P1426 Tank Ventilation Valve Open Circuit
P1432 Secondary Air Injection Valve Open
P1433 Secondary Air Injection Pump Relay Circuit Open
P1434 Secondary Air Injection Pump Relay Circuit Short To Positive
P1435 Secondary Air Injection Pump Relay Circuit Short To Ground
P1436 Secondary Air Injection Pump Relay Circuit Electrical Malfunction
P1440 EGR Valve Power Stage Open
P1441 EGR Vacuum Regulator Solenoid Valve Open/Short To Ground
P1450 Secondary Air Injection System Circuit Short To Positive
P1451 Secondary Air Injection Circuit Short To Ground
P1452 Secondary Air Injection System Circuit Open
P1471 EVAP Control System LDP Circuit Short to Positive
P1472 EVAP Control System LDP Circuit Short To Ground
P1473 EVAP Control System LDP Open Circuit
P1475 EVAP Control System LDP Malfunction/Signal Circuit Open
P1476 EVAP Control System LDP Malfunction/Insufficient Vacuum
P1477 EVAP Control System LDP Malfunction
P1478 EVAP Control System LDP Clamped Tube Detected
P1500 Fuel Pump Relay Electrical Circuit Malfunction
P1501 Fuel Pump Relay Circuit Short To Ground
P1502 Fuel Pump Relay Circuit Short To Positive
P1505 Closed Throttle Position Does Not Close/Open Circuit
P1506 Closed Throttle Position Switch Does Not Open./Short To Ground
P1512 Intake Manifold Changeover Valve Circuit Short To Positive
P1515 Intake Manifold Changeover Valve Circuit Short To Ground
P1516 Intake Manifold Changeover Valve Circuit Open
P1519 Intake Camshaft Control Bank 1 Malfunction
P1522 Intake Camshaft Control Bank 2 Malfunction
P1537 Fuel Cut-off Valve Incorrect Function
P1538 Fuel Cut-off Valve Open/Short To Ground
P1539 Clutch Pedal Switch Signal Fault
P1540 VSS Signal Too High
P1541 Fuel Pump Relay Circuit Open
P1542 Throttle Actuation Potentiometer Range/Performance
P1543 Throttle Actuation Potentiometer Signal Too Low
P1544 Throttle Actuation Potentiometer Signal Too High
P1545 Throttle Position Control Malfunction
P1546 Wastegate Bypass Regulator Valve Short To Positive
P1547 Wastegate Bypass Regulator Valve Short To Ground
P1548 Wastegate Bypass Regulator Valve Open
P1549 Wastegate Bypass Regulator Valve Open/Short To Ground
P1550 Charge Pressure Control Difference
P1555 Charge Pressure Upper Limit Exceeded
P1556 Charge Pressure Negative Deviation
P1557 Charge Pressure Positive Deviation
P1558 Throttle Actuator Electrical Malfunction
P1559 Idle Speed Control Throttle Position Adaption Malfunction
P1560 Maximum Engine Speed Exceeded
P1561 Quantity Adjuster Control Difference
P1562 Quantity Adjuster Upper Stop Value
P1563 Quantity Adjuster Lower Stop Value
P1564 Idle Speed Control Throttle Position Low Voltage During Adaption
P1565 Idle Speed Control Throttle Position Lower Limit Not Obtained
P1568 Idle Speed Control Throttle Position Mechanical Malfunction
P1569 Switch For CCS Signal Faulty
P1580 Throttle Actuator B1 Malfunction
P1582 Idle Adaptation At Limit
P1600 Power Supply Terminal No. 15 Low Voltage
P1602 Power Supply Terminal No. 30 Low Voltage
P1603 Internal Control Module Self Check
P1606 Rough Road Spec. Engine Torque ABS-ECU Electrical Malfunction
P1611 MIL Call-Up Circuit/TCM Short To Ground
P1612 Engine Control Module Incorrect Coding
P1613 MIL Call-Up Circuit Open/Short To Positive
P1616 Glow Plug Indicator Lamp Short To Positive
P1617 Glow Plug Indicator Lamp Open/Short To Ground
P1618 Glow Plug Relay Short To Positive
P1619 Glow Plug Relay Open/Short To Ground
P1624 MIL Request Signal Active
P1626 Data Bus Drive Missing Command From M/T
P1630 Accelerator Pedal Position Sensor 1 Signal Too Low
P1631 Accelerator Pedal Position Sensor 1 Signal Too High
P1632 Accelerator Pedal Position Sensor 1/2 Supply Voltage
P1633 Accelerator Pedal Position Sensor 2 Signal Too Low
P1634 Accelerator Pedal Position Sensor 2 Signal Too High
P1639 Accelerator Pedal Position Sensor 1/2 Range Performance
P1640 Internal Control Module (EEPROM) Error
P1648 CAN-Bus System Component Failure
P1649 Data Bus Powertrain Missing Message From Brake Controller
P1676 Drive By Wire MIL Circuit Electrical Malfunction
P1677 Drive By Wire MIL Circuit Short To Positive
P1678 Drive By Wire MIL Circuit Short To Ground
P1679 Drive By Wire MIL Circuit Open Circuit
P1681 Control Module Programming Not Finished
P1686 Control Unit Error, Programming Error
P1690 MIL Malfunction
P1691 MIL Open Circuit
P1692 MIL Short To Ground
P1693 MIL Short To Positive
P1778 Solenoid EV7 Electrical Malfunction
P1780 Engine Intervention Readable
P1851 Data Bus Drive Missing Command From ABS
P1854 Drive Train CAN-Bus Inoperative
Op verzoek van citroënmonteurtje
Professional
[b]PSA Specific Trouble Codes[b]
(Peugeot - Citroen)
P1100 MAF Sensor Intermittent/ Check of all OBDII Systems Not Complete
P1101 MAF Sensor Out Of Self Test Range
P1102 MAF Sensor In Range But Lower Than Expected
P1103 MAF Sensor In Range But Higher Than Expected
P1104 MAF Ground Malfunction
P1105 Dual Alternator Upper Fault
P1106 Dual Alternator Lower Fault/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1107 Dual Alternator Lower Circuit Malfunction/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
P1108 Dual Alternator Battery Lamp Circuit Malfunction
P1109 IAT - B Sensor Intermittent
P1110 IAT Sensor (D/C) Open/Short
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1113 IAT Sensor Open/Short
P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input
P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage/IAT - B Circuit High Input
P1116 Engine Coolant sensor out of range/ECT Sensor Out Of Self Test Range
P1117 Engine Coolant Sensor intermittent/ECT Sensor Intermittent
P1118 Manifold Absolute Temperature Circuit Low Input
P1119 Manifold Absolute Temperature Circuit High Input
P1120 Throttle position sensor out of range
P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
P1123 Throttle Position Sensor In Range But Higher Than Expected
P1124 Throttle Position Sensor Out Of Self Test Range
P1125 Throttle position sensor intermittent
P1126 Throttle Position (Narrow Range) Sensor Circuit Malfunction
P1127 Exhaust Not Warm, Downstream O2 Sensor
P1128 Upstream Heated O2 Sensors Swapped
P1129 Downstream Heated O2 Sensors Swapped
P1130 Lack Of HO2S Switch - Adaptive Fuel At Limit
P1131 Lack Of HO2S Switch - Sensor Indicates Lean
P1132 Lack Of HO2S Switch - Sensor Indicates Rich
P1133 HO2S Insufficient Switching Sensor 1
P1134 HO2S Transition Time Ratio Sensor 1
P1135 Pedal Position Sensor A Circuit Intermittent
P1136 Fan Control Circuit Malfunction
P1137 Lack Of HO2S Switch - Sensor Indicates Lean
P1138 Lack Of HO2S12 Switch - Sensor Indicates Rich
P1139 Water In Fuel Indicator Circuit Malfunction
P1140 Water In Fuel Condition
P1141 Fuel Restriction Indicator Circuit Malfunction
P1142 Fuel Restriction Condition
P1143 Air Assist Control Valve Range/Performance
P1144 Air Assist Control Valve Circuit Malfunction
P1150 Lack Of HO2S21 Switch - Adaptive Fuel At Limit
P1151 Lack Of HO2S21 Switch - Sensor Indicates Lean
P1152 Lack Of HO2S21 Switch - Sensor Indicates Rich
P1153 Bank 2 Fuel Control Shifted Lean
P1154 Bank 2 Fuel Control Shifted Rich
P1155 Alternative Fuel Controller
P1156 Fuel Select Switch Malfunction
P1157 Lack Of HO2S22 Switch - Sensor Indicates Lean
P1158 Lack Of HO2S22 Switch - Sensor Indicates Rich
P1159 Fuel Stepper Motor Malfunction
P1167 Invalid Test,throttle not depressed
P1168 Fuel Rail Sensor In-Range Low Failure
P1169 Fuel Rail Sensor In-Range High Failure
P1170 ESO - Engine Shut Off Solenoid Fault
P1171 Rotor Sensor Fault
P1172 Rotor Control Fault
P1173 Rotor Calibration Fault
P1174 Cam Sensor Fault
P1175 Cam Control Fault
P1176 Cam Calibration Fault
P1177 Synchronization Fault
P1178 ( open )
P1180 Fuel Delivery System Malfunction - Low
P1181 Fuel Delivery System Malfunction - High
P1182 Fuel Shut Off Solenoid Malfunction
P1183 Engine Oil Temperature Circuit Malfunction
P1184 Engine Oil Temperature Out Of Self Test Range
P1185 FTS High - Fuel Pump Temperature Sensor High
P1186 FTS Low - Fuel Pump Temperature Sensor Low
P1187 Variant Selection
P1188 Calibration Memory Fault
P1189 Pump Speed Signal Fault
P1190 Calibration Resistor Out Of Range
P1191 Key Line Voltage
P1192 Voltage External
P1193 EGR Drive Overcurrent
P1194 ECU A/D Converter
P1195 SCP HBCC Failed To Initialize
P1196 Key Off Voltage High
P1197 Key Off Voltage Low
P1198 Pump Rotor Control Underfueling
P1199 Fuel Level Input Circuit Low
P1200 Injector Control Circuit
P1201 Injector Circuit Open / Shorted - Cylinder #1
P1202 Injector Circuit Open / Shorted - Cylinder #2
P1203 Injector Circuit Open / Shorted - Cylinder #3
P1204 Injector Circuit Open / Shorted - Cylinder #4
P1205 Injector Circuit Open / Shorted - Cylinder #5
P1206 Injector Circuit Open / Shorted - Cylinder #6
P1209 Injector Control Pressure System Fault
P1210 Injector Control Pressure Above Expected Level
P1211 Injector Control Pressure Sensor Above / Below Desired
P1212 Injector Control Pressure Not Detected During Crank
P1213 Start Injector Circuit Malfunction
P1214 Pedal Position Sensor B Circuit Intermittent
P1215 Pedal Position Sensor C Circuit Low Input
P1216 Pedal Position Sensor C Circuit High Input
P1217 Pedal Position Sensor C Circuit Intermittent
P1218 CID High
P1219 CID Low
P1220 Series Throttle Control System Malfunction
P1221 Traction Control System Malfunction
P1222 Traction Control Output Circuit Malfunction
P1223 Pedal Demand Sensor B Circuit High Input
P1224 Throttle Position Sensor B Out Of Self Test Range
P1225 Needle Lift Sensor Malfunction
P1226 Control Sleeve Sensor Malfunction
P1227 Wastegate Failed Closed (Over Pressure)
P1228 Wastegate Failed Open (Under Pressure)
P1229 Intercooler Pump Driver Fault
P1230 Fuel Pump Low Speed Malfunction
P1231 Fuel Pump Secondary Circuit Low, High Speed
P1232 Fuel Pump Speed Primary Circuit Malfunction
P1233 Fuel Pump Driver Module Off Line
P1234 Fuel Pump Driver Module Off Line
P1235 Fuel Pump Control Out Of Range
P1236 Fuel Pump Control Out Of Range
P1237 Fuel Pump Secondary Circuit Malfunction
P1238 Fuel Pump Secondary Circuit Malfunction
P1239 Speed Fuel Pump Positive Feed Fault
P1240 Sensor Power Supply Malfunction
P1241 Sensor Power Supply Low Input
P1242 Sensor Power Supply High Input
P1243 Second Fuel Pump Faulty or Ground Fault
P1244 Alternator Load Input Failed High
P1245 Alternator Load Input Failed Low
P1246 Alternator Load Input Failed
P1247 Turbo Boost Pressure Low
P1248 Turbo Boost Pressure Not Detected
P1249 Wastegate Control Valve Performance
P1250 PRC Solenoid Circuit Malfunction
P1251 Air Mixture Solenoid Circuit Malfunction
P1252 Pedal Correlation PDS1 and LPDS High
P1253 Pedal Correlation PDS1 and LPDS Low
P1254 Pedal Correlation PDS2 and LPDS High
P1255 Pedal Correlation PDS2 and LPDS Low
P1256 Pedal Correlation PDS1 and HPDS
P1257 Pedal Correlation PDS2 and HPDS
P1258 Pedal Correlation PDS1 and PDS2
P1259 Immobilizer to PCM Signal Error
P1260 THEFT Detected, Vehicle Immobilzed
P1261 Cylinder #1 High To Low Side Short
P1262 Cylinder #2 High To Low Side Short
P1263 Cylinder #3 High To Low Side Short
P1264 Cylinder #4 High To Low Side Short
P1265 Cylinder #5 High To Low Side Short
P1266 Cylinder #6 High To Low Side Short
P1267 Cylinder #7 High To Low Side Short
P1268 Cylinder #8 High To Low Side Short
P1269 Immobilizer Code Not Programmed
P1270 Engine RPM Or Speed Limiter Reached
P1271 Cylinder #1 High To Low Side Open
P1272 Cylinder #2 High To Low Side Open
P1273 Cylinder #3 High To Low Side Open
P1274 Cylinder #4 High To Low Side Open
P1275 Cylinder #5 High To Low Side Open
P1276 Cylinder #6 High To Low Side Open
P1277 Cylinder #7 High To Low Side Open
P1278 Cylinder #8 High To Low Side Open
P1280 Injection Control Pressure Out Of Range Low
P1281 Injection Control Pressure Out Of Range High
P1282 Excessive Injection Control Pressure
P1283 IPR Circuit Failure
P1284 Aborted KOER - ICP Failure
P1285 Cylinder head over temp sensed
P1286 Fuel Pulse In Range But Lower Than Expected
P1287 Fuel Pulse In Range But Higher Than Expected
P1288 Cylinder Head Temp Sensor Out Of Self Test Range
P1289 Cylinder Head Temp Sensor High Input
P1290 Cylinder Head Temp Sensor Low Input
P1291 Injector High Side Short To GND Or VBATT - Bank 1
P1292 Injector High Side Short To GND Or VBATT - Bank 2
P1293 Injector High Side Open - Bank 1
P1294 Injector High Side Open - Bank 2/Target idle not reached
P1295 Multi-faults - Bank 1 - With Low Side Shorts
P1296 Multi-faults - Bank 2 - With Low Side Shorts
P1297 Injector High Sides Shorted Together
P1298 IDM Failure
P1299 Cylinder Head Overtemperature Protection Active
P1300 Boost Calibration Fault
P1301 Boost Calibration High
P1302 Boost Calibration Low
P1303 EGR Calibration Fault
P1304 EGR Calibration High
P1305 EGR Calibration Low
P1306 Kickdown Relay Pull - In Circuit Fault
P1307 Kickdown Relay Hold Circuit Fault
P1308 A/C Clutch Circuit Fault
P1309 Misfire Monitor AICE Chip Fault
P1313 Misfire Rate Catalyst Damage Fault - Bank 1
P1314 Misfire Rate Catalyst Damage Fault - Bank 2
P1315 Persistent Misfire
P1316 Injector Circuit / IDM Codes Detected
P1317 Injector Circuit / IDM Codes Not Updated
P1336 Crank / Cam Sensor Range / Performance
P1340 Camshaft Position Sensor B Circuit Malfunction
P1341 Camshaft Position Sensor B Range / Performance
P1345 SGC (Cam Position) Sensor Circuit Malfunction/ Crankshaft Position - Camshaft Position Correlation
P1346 Fuel Level Sensor B Circuit Malfunction
P1347 Fuel Level Sensor B Range / Performance
P1348 Fuel Level Sensor B Circuit Low
P1349 Fuel Level Sensor B Circuit High
P1350 Fuel Level Sensor B Intermittent/Bypass Line Monitor
P1351 IDM Input Circuit Malfunction/ Ignition Coil Control Circuit High Voltage
P1352 Ignition Coil A Primary Circuit Malfunction
P1353 Ignition Coil B Primary Circuit Malfunction
P1354 Ignition Coil C Primary Circuit Malfunction
P1355 Ignition Coil D Primary Circuit Malfunction
P1360 Ignition Coil A Secondary Circuit Malfunction
P1361 Ignition Control (IC) Circuit Low Voltage
P1362 Ignition Coil C Secondary Circuit Malfunction
P1363 Ignition Coil D Secondary Circuit Malfunction
P1364 Ignition Coil Primary Circuit Failure
P1365 Ignition Coil Secondary Circuit Failure
P1366 Ignition Spare
P1367 Ignition Spare
P1368 Ignition Spare
P1369 Engine Temperature Light Monitor Failure
P1370 Insufficient RMP Increase During Spark Test
P1371 Ignition Coil - Cylinder 1 - Early Activation Fault
P1372 Ignition Coil - Cylinder 2 - Early Activation Fault
P1373 Ignition Coil - Cylinder 3 - Early Activation Fault
P1374 Crankshaft Position (CKP)/Ignition Coil - Cylinder 4 - Early Activation Fault
P1375 Ignition Coil - Cylinder 5 - Early Activation Fault
P1376 Ignition Coil - Cylinder 6 - Early Activation Fault
P1380 Misfire Detected - Rough Road Data Not Available
P1381 Variable Cam Timing Overadvanced (Bank #1)/ Misfire Detected - No Communication with BCM
P1382 Variable Cam Timing Solenoid #1 Circuit Malfunction
P1383 Variable Cam Timing Overretarded (Bank #1)
P1384 VVT Solenoid A Malfunction
P1385 Variable Cam Timing Solenoid B Malfunction
P1386 Variable Cam Timing Overadvanced (Bank #2)
P1387 Variable Cam Timing Solenoid #2 Circuit Malfunction
P1388 Variable Cam Timing Overretarded (Bank #2)
P1389 Glow Plug Circuit High Side Low Input
P1390 Octane Adjust Pin Out Of Self Test Range
P1391 Glow Plug Circuit Low Input (Bank #1)
P1392 Glow Plug Circuit High Input (Bank #1)
P1393 Glow Plug Circuit Low Input (Bank #2)
P1394 Glow Plug Circuit High Input (Bank #2)
P1395 Glow Plug Monitor Fault (Bank #1)
P1396 Glow Plug Monitor Fault (Bank #2)
P1397 System Voltage Out Of Self Test Range
P1398 VVT Solenoid B Circuit High Input
P1399 Glow Plug Circuit High Side, High Input
P1400 DPFE Circuit Low Input
P1401 DPFE Circuit High Input
P1402 EGR Metering Orifice Restricted
P1403 DPFE Sensor Hoses Reversed
P1404 IAT - B Circuit Malfunction/ Exhaust Gas Recirculation Closed Position Performance
P1406 Exhaust Gas Recirculation (EGR) Position Sensor Performance
P1407 EGR No Flow Detected
P1408 EGR Flow Out Of Self Test Range
P1409 EVR Control Circuit Malfunction
P1411 SAI System Incorrect Downstream Flow Detected
P1413 SAI System Monitor Circuit Low Input
P1414 SAI System Monitor Circuit High Input
P1415 Air Pump Circuit Malfunction/ (AIR) System Bank 1
P1416 Port Air Circuit Malfunction/ (AIR) System Bank 2
P1417 Port Air Relief Circuit Malfunction
P1418 Split Air #1 Circuit Malfunction
P1419 Split Air #2 Circuit Malfunction
P1420 Catalyst Temperature Sensor Failure
P1421 Catalyst Damage
P1422 EGI Temperature Sensor Failure
P1423 EGI Functionality Test Failed
P1424 EGI Glow Plug Primary Failure
P1425 EGI Glow Plug Secondary Failure
P1426 EGI Mini - MAF Failed Out Of Range
P1427 EGI Mini - MAF Failed Short Circuit
P1428 EGI Mini - MAF Failed Open Circuit
P1429 Electric Air Pump Primary Failure
P1430 Electric Air Pump Secondary Failure
P1433 A/C Refrigerant Temperature Circuit Low
P1434 A/C Refrigerant Temperature Circuit High
P1435 A/C Refrigerant Temperature Circuit Range/Performance
P1436 A/C Evaporator Air Temperature Circuit Low
P1437 A/C Evaporator Air Temperature Circuit High
P1438 A/C Evaporator Air Temperature Circuit Range/Performance
P1439 Floor Temperature Switch Circuit Malfunction
P1440 Purge Valve Stuck Open
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Chevrolet Only
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Oldsmobile Only
P1442 Evaporative Emission Control System Leak Detected
P1443 Evaporative Emission Control System Control Valve
P1444 Purge Flow Sensor Circuit Low Input
P1445 Purge Flow Sensor Circuit High Input
P1446 Evaporative Vac Solenoid Circuit Malfunction
P1447 ELC System Closure Valve Flow Fault
P1448 ELC System 2 Fault
P1449 Evaporative Check Solenoid Circuit Malfunction
P1450 Unable To Bleed Up Fuel Tank Vacuum
P1451 Evap Emission Control Sys Vent Control Valve Circuit
P1452 Unable To Bleed - Up Vacuum in Tank
P1453 Fuel Tank Pressure Relief Valve Malfunction
P1454 Evaporative System Vacuum Test Malfunction
P1455 Evap Emission Control Sys Leak Detected (Gross Leak/No Flow)
P1456 Fuel Tank Temperature Sensor Circuit Malfunction
P1457 Unable To Pull Vacuum In Tank
P1460 Wide open throttle A/C cutoff relay circuit
P1461 A/C pressure sensor circuit voltage low
P1462 A/C pressure sensor circuit voltage high
P1463 A/C Pressure Sensor Insufficient Pressure Change
P1464 A/C Demand Out of Self Test Range
P1465 A/C Relay Circuit Malfunction
P1466 A/C Refrigerant Temperature Sensor/Circuit Malfunction
P1467 A/C Compressor Temperature Sensor Malfunction
P1468 SSPOD Open Circuit or Closed Circuit Fault
P1469 Low A/C Cycling Period
P1470 A/C Cycling Period Too Short
P1471 Electrodrive Fan 1 Operational Failure (Driver Side)
P1472 Electrodrive Fan 2 Operational Failure (Passenger Side)
P1473 Fan Secondary High With Fan(s) Off
P1474 Low Fan Control Primary Circuit Malfunction
P1475 Fan Relay (Low) Circuit Malfunction
P1476 Fan Relay (High) Circuit Malfunction
P1477 Additional Fan Relay Circuit Malfunction
P1478 Cooling Fan Driver Fault
P1479 High Fan Control Primary Circuit Malfunction
P1480 Fan Secondary Low with Low Fan On
P1481 Fan Secondary Low With High Fan On
P1482 SCP
P1483 Power To Fan Circuit Overcurrent
P1484 Open Power To Ground VCRM
P1485 EGRV Circuit Malfunction
P1486 EGRA Circuit Malfunction
P1487 EGRCHK Solenoid Circuit Malfunction
P1490 Secondary Air Relief Solenoid Circuit Malfunction
P1491 Secondary Switch Solenoid Circuit Malfunction
P1492 APLSOL Solenoid Circuit Malfunction
P1493 RCNT Solenoid Circuit Malfunction
P1494 SPCUT Solenoid Circuit Malfunction
P1495 TCSPL Solenoid Circuit Malfunction
P1501 Vehicle Speed Sensor Out Of Self Test Range
P1502 Vehicle Speed Sensor Intermittent Malfunction
P1503 Auxillary Speed Sensor Fault
P1504 Idle Air Control Circuit Malfunction
P1505 Idle Air Control System At Adaptive Clip
P1506 Idle Air Control Overspeed Error
P1507 Idle Air Control Underspeed Error
P1508 Idle Control System Circuit Open
P1509 Idle Control System Circuit Shorted
P1510 Idle Signal Circuit Malfunction
P1511 Idle Switch (Electric Control Throttle) Circuit Malfunction
P1512 Intake Manifold Runner Control (Bank 1) Stuck Closed
P1513 Intake Manifold Runner Control (Bank 2) Stuck Closed
P1514 High Load Neutral/Drive Fault
P1515 Electric Current Circuit Malfunction
P1516 IMRC Input Error (Bank 1)
P1517 IMRC Input Error (Bank 2)
P1518 Intake Manifold Runner Control (Stuck Open)
P1519 Intake Manifold Runner Control (Stuck Closed)
P1520 Intake Manifold Runner Control Circuit Malfunction
P1521 Variable Intake Solenoid #1 Circuit Malfunction
P1522 Variable Intake Solenoid #2 Circuit Malfunction
P1523 IVC Solenoid Circuit Malfunction
P1524 Variable Intake Solenoid System
P1525 Air Bypass Valve System
P1526 Air Bypass System
P1527 Accelerate Warmup Solenoid Circuit Malfunction
P1528 Subsidiary Throttle Valve Solenoid Circuit Malfunction
P1529 SCAIR Solenoid Circuit Malfunction
P1530 A/C Clutch Circuit Malfunction
P1531 Invalid Test - Accelerator Pedal Movement
P1532 IMCC Circuit Malfunction, Bank B
P1533 AAI Circuit Malfunction
P1534 Inertia Switch Activated
P1535 Blower Fan Speed Circuit Range/Performance
P1536 Parking Brake Switch Circuit Failure
P1537 Intake Manifold Runner Control (Bank 1) Stuck Open
P1538 Intake Manifold Runner Control (Bank 2) Stuck Open
P1539 Power To A/C Clutch Circuit Overcurrent
P1540 Air Bypass Valve Circuit Malfunction
P1549 IMCC Circuit Malfunction, Bank B
P1550 PSPS Out Of Self Test Range
P1565 Speed Control Command Switch Out of Range High
P1566 Speed Control Command Switch Out of Range Low
P1567 Speed Control Output Circuit Continuity
P1568 Speed Control Unable to Hold Speed
P1571 Brake Switch Malfunction
P1572 Brake Pedal Switch Circuit Malfunction
P1573 Throttle Position Not Available
P1574 Throttle Position Sensor Disagreement btwn Sensors
P1575 Pedal Position Out of Self Test Range
P1576 Pedal Position Not Available
P1577 Pedal Position Sensor Disagreement btwn Sensors
P1578 ETC Power Less Than Demand
P1579 ETC In Power Limiting Mode
P1580 Electronic Throttle Monitor PCM Override
P1581 Electronic Throttle Monitor Malfunction
P1582 Electronic Throttle Monitor Data Available
P1583 Electronic Throttle Monitor Cruise Disable
P1584 TCU Detected IPE Circuit Malfunction
P1585 Throttle Control Unit Malfunction
P1586 Throttle Control Unit Throttle Position Malfunction
P1587 Throttle Control Unit Modulated Command Malfunction
P1588 Throttle Control Unit Detected Loss of Return Spring
P1589 TCU Unable To Control Desired Throttle Angle
P1600 Loss of KAM Power; Open Circuit
P1601 ECM/TCM Serial Communication Error
P1602 Immobilizer/ECM Communication Error
P1603 EEPROM Malfunction
P1604 Code Word Unregestered
P1605 Keep Alive Memory Test Failure
P1606 ECM Control Relay O/P Circuit Malfunction
P1607 MIL O/P Circuit Malfunction
P1608 Internal ECM Malfunction
P1609 Diagnostic Lamp Driver Fault
P1610 SBDS Interactive Codes
P1611 SBDS Interactive Codes
P1612 SBDS Interactive Codes
P1613 SBDS Interactive Codes
P1614 SBDS Interactive Codes
P1615 SBDS Interactive Codes
P1616 SBDS Interactive Codes
P1617 SBDS Interactive Codes
P1618 SBDS Interactive Codes
P1619 SBDS Interactive Codes
P1620 SBDS Interactive Codes
P1621 Control Module Long Term Memory Performance/ Immobilizer Code Words Do Not Match
P1622 Immobilizer ID Does Not Match
P1623 Immobilizer Code Word/ID Number Write Failure
P1624 Anti Theft System
P1625 B+ Supply To VCRM Fan Circuit Malfunction
P1626 Theft Deterrent Fuel Enable Signal Not Received/ B+ Supply To VCRM A/C Circuit Malfunction
P1627 Module Supply Voltage Out Of Range
P1628 Module Ignition Supply Input Malfunction
P1629 Internal Voltage Regulator Malfunction
P1630 Internal Vref Malfunction
P1631 Theft Deterrent Start Enable Signal Not Correct/ Main Relay Malfunction (Power Hold)
P1632 Smart Alternator Faults Sensor/Circuit Malfunction
P1633 KAM Voltage Too Low
P1634 Data Output Link Circuit Failure
P1635 Tire / Axle Ratio Out of Acceptable Range
P1636 Inductive Signature Chip Communication Error
P1637 Can Link ECM/ABSCM Circuit / Network Malfunction
P1638 Can Link ECM/INSTM Circuit / Network Malfunction
P1639 Vehicle ID Block Corrupted or Not Programmed
P1640 Powertrain DTCs Available in Another Module
P1641 Fuel Pump Primary Circuit Failure
P1642 Fuel Pump Monitor Circuit High Input
P1643 Fuel Pump Monitor Circuit Low Input
P1644 Fuel Pump Speed Control Circuit Malfunction
P1645 Fuel Pump Resistor Switch Circuit Malfunction
P1650 PSP Switch Out of Self Test Range
P1651 PSP Switch Input Malfunction
P1652 IAC Monitor Disabled by PSP Switch Failed On
P1653 Power Steering Output Circuit Malfunction
P1654 Recirculation Override Circuit Malfunction
P1655 Starter Disable Circuit Malfunction
P1660 Output Circuit Check Signal High
P1661 Output Circuit Check Signal Low
P1662 IDM_EN Circuit Failure
P1663 Fuel Demand Command Signal Circuit Malfunction
P1667 CI Circuit Malfunction
P1668 PCM - IDM Communications Error
P1670 Electronic Feedback Signal Not Detected
P1680 Metering Oil Pump Malfunction
P1681 Metering Oil Pump Malfunction
P1682 Metering Oil Pump Malfunction
P1683 Metering Oil Pump Temperature Sensor Circuit Malfunction
P1684 Metering Oil Pump Position Sensor Circuit Malfunction
P1685 Metering Oil Pump Stepping Motor Circuit Malfunction
P1686 Metering Oil Pump Stepping Motor Circuit Malfunction
P1687 Metering Oil Pump Stepping Motor Circuit Malfunction
P1688 Metering Oil Pump Stepping Motor Circuit Malfunction
P1689 Oil Pressure Control Solenoid Circuit Malfunction
P1690 Wastegate Solenoid Circuit Malfunction
P1691 Turbo Pressure Control Solenoid Circuit Malfunction
P1692 Turbo Control Solenoid Circuit Malfunction
P1693 Turbo Charge Control Circuit Malfunction
P1694 Turbo Charge Relief Circuit Malfunction
P1700 Transmission Indeterminate Failure (Failed to Neutral)
P1701 Reverse Engagement Error
P1702 TRS Circuit Intermittent Malfunction
P1703 Brake Switch Out Of Self Test Range
P1704 Digital TRS Failed to Transition States in KOEO / KOER
P1705 Not in P or N During KOEO / KOER
P1706 High Vehicle Speed Observed in Park
P1707 Transfer Case Neutral Indicator Hard Fault Present
P1708 Clutch Switch Circuit Malfunction
P1709 PNP Switch Out Of Self Test Range
P1711 TFT Sensor Out Of Self Test Range
P1712 Trans Torque Reduction Request Signal Malfunction
P1713 TFT Sensor In Range Failure Low Value
P1714 SSA Inductive Signature Malfunction
P1715 SSB Inductive Signature Malfunction
P1716 SSC Inductive Signature Malfunction
P1717 SSD Inductive Signature Malfunction
P1718 TFT Sensor In Range Failure High
P1720 Vehicle Speed (Meter) Circuit Malfunction
P1721 Gear 1 Incorrect Ratio
P1722 Gear 2 Incorrect Ratio
P1723 Gear 3 incorrect Ratio
P1724 Gear 4 Incorrect Ratio
P1725 Insufficient Engine Speed Increase During Self Test
P1726 Insufficient Engine Speed Decrease During Self Test
P1727 Coast Clutch Solenoid Inductive Signature Malfunction
P1728 Transmission Slip Error
P1729 4x4 Low Switch Error
P1730 Gear Control Malfunction 2,3,5
P1731 1-2 Shift Malfunction
P1732 2-3 Shift Malfunction
P1733 3-4 Shift Malfunction
P1734 Gear Control Malfunction
P1735 First Gear Switch Circuit Malfunction
P1736 Second Gear Switch Circuit Malfunction
P1737 Lockup Solenoid System
P1738 Shift Time Error
P1739 Slip Solenoid System
P1740 Torque Converter Clutch Inductive Signature Malfunction
P1741 Torque Converter Clutch Control Error
P1742 Torque Converter Clutch Solenoid Failed On
P1743 Torque Converter Clutch Solenoid Failied On
P1744 Torque Converter Clutch System Performance
P1745 Line Pressure Solenoid System
P1746 Pressure Control Solenoid "A" Open Circuit
P1747 Pressure Control Solenoid "A" Short Circuit
P1748 EPC Malfunction
P1749 Pressure Control Solenoid Failed Low
P1751 Shift Solenoid A Performance
P1754 Coast Clutch Solenoid Circuit Malfunction
P1755 Intermediate Speed Sensor (ISS) Malfunction
P1756 Shift Solenoid B Performance
P1760 Pressure Control Solenoid "A" Short Circuit
P1761 Shift Solenoid C Performance
P1762 Overdrive Band Failed Off
P1765 Timing Solenoid Circuit Malfunction
P1767 Torque Converter Clutch Circuit Malfunction
P1768 Performance / Normal / Winter Mode Input Malfunction
P1769 AG4 Transmission Torque Modulation Fault
P1770 Clutch Solenoid Circuit Malfunction
P1775 Transmission System MIL Fault
P1776 Ignition Retard Request Duration Fault
P1777 Ignition Retard Request Circuit Fault
P1778 Transmission Reverse I/P Circuit Malfunction
P1779 TCIL Circuit Malfunction
P1780 Trans Control Switch (O/D Cancel) Out of Self Test Range
P1781 4X4 Switch Out of Self Test Range
P1782 P/ES Circuit Out Of Self Test Range
P1783 Transmission Overtemperature Condition
P1784 Transmission Mechanical Failure - First And Reverse
P1785 Transmission Mechanical Failure - First And Second
P1786 3-2 Downshift Error
P1787 2-1 Downshift Error
P1788 Pressure Control Solenoid "B" Open Circuit
P1789 Pressure Control Solenoid "B" Short Circuit
P1790 TP (Mechanical) Circuit Malfunction
P1791 TP (Electric) Circuit Malfunction
P1792 Barometer Pressure Circuit Malfunction
P1793 Intake Air Volume Circuit Malfunction
P1794 Battery Voltage Circuit Malfunction
P1795 Idle Switch Circuit Malfunction
P1796 Kick Down Switch Circuit Malfunction
P1797 Neutral Switch Circuit Malfunction
P1798 Coolant Temperature Circuit Malfunction
P1799 Hold Switch Circuit Malfunction
P1800 Transmission Clutch Interlock Safety Switch Circuit Failure
P1801 Transmission Clutch Interlock Safety Switch Open Circuit
P1802 Transmission Clutch Interlock Safety Switch Short Circuit To Battery
P1803 Transmission Clutch Interlock Safety Switch Short Circuit To Ground
P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure
P1805 Transmission 4-Wheel Drive High Indicator Open Circuit
P1806 Transmission 4-Wheel Drive High Indicator Short Circuit To Battery
P1807 Transmission 4-Wheel Drive High Indicator Short Circuit To Ground
P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure
P1809 Transmission 4-Wheel Drive Low Indicator Open Circuit
P1810 TFP Valve Position Switch Circuit/ Transmission 4-Wheel Drive Low Indicator Short Circuit To Battery
P1811 Transmission 4-Wheel Drive Low Indicator Short Circuit To Ground
P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure
P1813 Transmission 4-Wheel Drive Mode Select Open Circuit
P1814 Transmission 4-Wheel Drive Mode Select Short Circuit To Battery
P1815 Transmission 4-Wheel Drive Mode Select Short Circuit To Ground
P1816 Transmission Neutral Safety Switch Circuit Failure
P1817 Transmission Neutral Safety Switch Open Circuit
P1818 Transmission Neutral Safety Switch Short Circuit To Battery
P1819 Transmission Neutral Safety Switch Short Circuit To Ground
P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure
P1821 Transmission Transfer Case Clockwise Shift Relay Coil Open Circuit
P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery
P1823 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Ground
P1824 Transmission 4-Wheel Drive Clutch Relay Circuit Failure
P1825 Transmission 4-Wheel Drive Clutch Relay Open Circuit
P1826 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery
P1827 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Ground
P1828 Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure
P1829 Transmission Transfer Case Counter Clockwise Shift Relay Coil Open Circuit
P1830 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery
P1831 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Ground
P1832 Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
P1833 Transmission Transfer Case Differential Lock-Up Solenoid Open Circuit
P1834 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Battery
P1835 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Ground
P1836 Transmission Transfer Case Front Shaft Speed Sensor Circuit Failure
P1837 Transmission Transfer Case Rear Shaft Speed Sensor Circuit Failure
P1838 Transmission Transfer Case Shift Motor Circuit Failure
P1839 Transmission Transfer Case Shift Motor Open Circuit
P1840 Transmission Transfer Case Shift Motor Short Circuit To Battery
P1841 Transmission Transfer Case Shift Motor Short Circuit To Ground
P1842 Transmission Transfer Case Differential Lock-Up Feedback Switch Circuit Failure
P1843 Transmission Transfer Case Differential Lock-Up Feedback Switch Open Circuit
P1844 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Battery
P1845 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Ground
P1846 Transmission Transfer Case Contact Plate 'A' Circuit Failure
P1847 Transmission Transfer Case Contact Plate 'A' Open Circuit
P1848 Transmission Transfer Case Contact Plate 'A' Short Circuit To Battery
P1849 Transmission Transfer Case Contact Plate 'A' Short Circuit To Ground
P1850 Transmission Transfer Case Contact Plate 'B' Circuit Failure
P1851 Transmission Transfer Case Contact Plate 'B' Open Circuit
P1852 Transmission Transfer Case Contact Plate 'B' Short Circuit To Battery
P1853 Transmission Transfer Case Contact Plate 'B' Short Circuit To Ground
P1854 Transmission Transfer Case Contact Plate 'C' Circuit Failure
P1855 Transmission Transfer Case Contact Plate 'C' Open Circuit
P1856 Transmission Transfer Case Contact Plate 'C' Short Circuit To Battery
P1857 Transmission Transfer Case Contact Plate 'C' Short Circuit To Ground
P1858 Transmission Transfer Case Contact Plate 'D' Circuit Failure
P1859 Transmission Transfer Case Contact Plate 'D' Open Circuit
P1860 TCC PWM Solenoid Circuit Electrical/ Transmission Transfer Case Contact Plate 'D' Short Circuit To Battery
P1861 Transmission Transfer Case Contact Plate 'D' Short Circuit To Ground
P1862 Transmission Transfer Case Contact Plate Power Circuit Failure
P1863 Transmission Transfer Case Contact Plate Power Open Circuit
P1864 Transmission Transfer Case Contact Plate Power Short To Battery
P1865 Transmission Transfer Case Contact Plate Power Short To Ground
P1866 Transmission Transfer Case System Concern - Servicing Required
P1867 Transmission Transfer Case Contact Plate General Circuit Failure
P1868 Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Failure
P1869 Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Short To Battery
P1870 Transmission Component Slipping/ Transmission Mechanical Transfer Case 4x4 Switch Circuit Failure
P1871 Transmission Mechanical Transfer Case 4x4 Switch Circuit Short To Battery
P1872 Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Failure
P1873 Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Short To Battery
P1874 Transmission Automatic Hall Effect Sensor Power Circuit Failure
P1875 Transmission Automatic Hall Effect Sensor Power Circuit Short To Battery / 4WD Low Switch Circuit Electrical
P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure
P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short To Battery
P1878 Transmission Transfer Case Disengaged Solenoid Circuit Failure
P1879 Transmission Transfer Case Disengaged Solenoid Open Circuit
P1880 Transmission Transfer Case Disengaged Solenoid Short to Battery
P1881 Engine Coolant Level Switch Circuit Failure, GEM
P1882 Engine Coolant Level Switch Circuit Short to Ground
P1883 Engine Coolant Level Switch Circuit Failure, GEM
P1884 Engine Coolant Level Lamp Circuit Short to Ground
P1885 Transmission Transfer Case Disengaged Solenoid Short to Ground
P1886 4X4 Initialization Failure
P1890 Transmission 4WD Mode Select Return Input Circuit Failure
P1891 Transmission Transfer Case Contact Plate Ground Return Open Circuit
P1900 OSS Circuit Intermittent Malfunction
P1901 TSS Circuit Intermittent Malfunction
P1902 Pressure Control Solenoid "B" Intermittent Short
P1903 Pressure Control Solenoid "C" Short Circuit
P1904 Pressure Control Solenoid "C" Open Circuit
P1905 Pressure Control Solenoid "C" Intermittent Short
P1906 Kickdown Pull Relay Open or Short Circuit to Ground
P1907 Kickdown Hold Relay Open or Short Circuit to Ground
P1908 Transmission Pressure Circuit Solenoid Open or Short to Ground
P1909 Trans Temp Sensor Circuit Open or Shorted to Pwr or Gnd
P1910 VFS A Pressure Output Failed Low
P1911 VFS B Pressure Output Failed Low
P1912 VFS C Pressure Output Failed Low
P1913 Pressure Switch A Circuit Malfunction
P1914 Manually Shifted Automatic (MSA) Sw Circuit Malf
P1915 Reverse Switch Circuit Malfunction
P1916 High Clutch Drum Speed Sensor Malfunction
P1917 High Clutch Drum Speed Sensor Intermittent
P1918 Transmission Range Display Circuit Malfunction
Hans4040 123.030 km Reageer
Op verzoek van citroenmonteurtje
professional
Mercedes-Benz Diagnostic Trouble Codes (DTC) [color=red]for 1996+ models[/color] And BCU Codes
Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfucntion
P0656 Fuel Level Output Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque Converter Clutch Circuit Malfuction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stuck Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P0805 Clutch Position Sensor Circuit Malfunction
P0806 Clutch Position Sensor Circuit Range/Performance
P0807 Clutch Position Sensor Circuit Low
P0808 Clutch Position Sensor Circuit High
P0809 Clutch Position Sensor Circuit Intermittent Ckt
P0810 Clutch Position Control Malfunction
P0811 Clutch Slippage Excessive
P0812 Reverse Input Circuit Malfunction
P0813 Reverse Output Circuit Malfunction
P0814 Trans Range Display Circuit Malfunction
P0815 Upshift Switch Circuit Malfunction
P0816 Downshift Switch Circuit Malfunction
P0817 Starter Disable Circuit
P0818 Driveline Disconn. Switch Input
P0820 Gear Lever X-Y Sensor Circuit
P0821 Gear Lever X Sensor Circuit
P0822 Gear Lever Y Sensor Circuit
P0823 Gear Lever X Sensor Circuit Intermittent Ckt
P0824 Gear Lever Y Sensor Circuit Intermittent Ckt
P0830 Clutch Position Switch A Circuit Malfunction
P0831 Clutch Position Switch A Circuit Low
P0832 Clutch Position Switch A Circuit High
P0833 Clutch Position Switch B Circuit Malfunction
P0834 Clutch Position Switch B Circuit Low
P0835 Clutch Position Switch B Circuit High
P0836 4 Wheel Drive Switch Circuit Malfunction
P0837 4 Wheel Drive Switch CKT Range/Perf
P0838 4 Wheel Drive Switch Circuit Low
P0839 4 Wheel Drive Switch Circuit High
P0840 Trans Fluid Press Sensor/Switch A Circuit Malfunction
P0841 Trans Fluid Press Sensor/Switch A CKT Range/Perf
P0842 Trans Fluid Press Sensor/Switch A Circuit Low
P0843 Trans Fluid Press Sensor/Switch A Circuit High
P0844 Trans Fluid Press Sensor/Switch A CKT Intermittent
P0845 Trans Fluid Press Sensor/Switch B Circuit Malfunction
P0846 Trans Fluid Press Sensor/Switch B CKT Range/Perf
P0847 Trans Fluid Press Sensor/Switch B Circuit Low
P0848 Trans Fluid Press Sensor/Switch B Circuit High
P0849 Trans Fluid Press Sensor/Switch B CKT Intermittent
P1000 Electronic Gear Selector Module: Defective N15/5
P1228 yet unknown code on 1997 C 220 CDI
P1386 knock control
P1570 Intermittant No-Start Immobiliser Module
P1581 ?
P1747 Electronic Gear Selector Module: Defective Interaction of CAN
with control unit A1(instrument cluster)
P1750 Electronic Gear Selector Module: Very low control unit supply
voltage
P1832 Electronic Gear Selector Module: SHORT in circuit N15/5 output
stage
P1910 Electronic Gear Selector Module: Control Unit over voltage
P1912 Electronic Gear Selector Module: Weak touch push button voltage
P2000 NOx Trap Efficiency Below Threshold (Bank 1)
P2001 NOx Trap Efficiency Below Threshold (Bank 2)
P2003 Particulate Trap Efficiency Below Threshold (Bank 1)
P2004 Particulate Trap Efficiency Below Threshold (Bank 2)
P2031 Exhaust Gas Temperature Sensor Circuit (Bank 1 Sensor 2)
P2032 Exhaust Gas Temperature Sensor Circuit Low (Bank 1 Sensor 2)
P2033 Exhaust Gas Temperature Sensor Circuit High (Bank 1 Sensor 2)
P2080 Exhaust Gas Temperature Sensor Circuit Range/Performance (Bank 1 Sensor 1)
P2081 Exhaust Gas Temperature Sensor Circuit intermittant (Bank 1 Sensor 1)
P2100 Throttle Actuator Control Motor Circuit/Open
P2101 Throttle Actuator Control Motor Circuit Range/Performance
P2208 transmission: The speed of Y3/6n2 to Y3/6n3 is excessive
Body
B1000 HRA Headlamp range adjustment: Supply voltage of the control unit is too low (undervoltage)
B1004 LCP Lower Control Panel: Control unit does not match vehicle type
B1056 Automatic Air Conditioning: Problem in CAN communication with control unit DCM-RL
B1201 Electric seat adjustment front left: Hall sensor front height
M27m3
B1213 If seat memory installed: ext left rearview mirror voltage faulty
B1214 If seat memory installed: ext right rearview mirror voltage faulty
B1226 In-car temperature sensor (B10/4)
B1227 Outside temperature indicator temp sensor (014)
B1128 Heater core temperature (B10/1)
B1229 Heater core temperature (B10/1)
B1230 Evaporator temperature sensor (B10/6)
B1231 ECT sensor (B11/4)
B1232 Refrigerant pressure sensor (B12)
B1233 Refrigerant temperature sensor (B12/1)
B1234 Sun sensor (B32)
B1235 Emissions sensor (B31)
B1241 Refrigerant Fill
B1246 PTS Parktronic: A42b1 (left outer sensor, front bumper) The plug connection has poor contact or is loose, or the sensor or cable is faulty
B1310 Left/Window airbag sensor is defective
B1315 Problem in Front passenger child seat recognition
B1416 Coolant circulation pump (M13)
B1417 Duovalve (Y21y1), left
B1418 Duovalve (Y21y2), right
B1419 Electromagnetic clutch (A9k1)
B1420 Idle speed increase
B1421 Pulse module (N05)
B1422 Series interface (K1) connection to instrument cluster (A1)
B1423 Switchover valve block (Y11)
B1424 Activated charcoal filler actuator (A32m2) open
B1425 Activated charcoal filler actuator (A32m2) closed
B1432 Non-USA DTC
B1459 Series interface (K2) connection to instrument cluster (A1)
B1462 Wide open throttle (WOT) position signal diesel engines
B1476 Airbag malfunction indicator and warning lamp is defective
B1481 HRA: Part E2m1 (Right headlamp range adjustment motor) has short to ground
B1489 HRA: Part E2m1 (Right headlamp range adjustment motor) has open or short to positive
B1492 HRA: Part E1m1 (Left headlamp range adjustement motor) has
short to positive
B1617 Part E19/1 (Left license plate lamp) is defective
B1618 Part E19/2 (Right license plate lamp) is defective
B1628 Part E2e5 (Turn signal lamp) in module E2 (Right front headlamp unit) is defective.
B1703 Intermittant No Start in AAM Immobiliser Module
B1729 PSE Pneumatic system doorlock Control Module A37
B1736 Navigation system's CD Player: Check General CD, Check CD data block, Flimsy CD data
B1768 Faulty open data flap limit switch (0025) Front flap
B1773 HRA: Zero position programming has not yet been carried out or is not possible
B1850 Electric seat adjustment front right: CAN communication interrupted with DCM
Chassis
C1000 Traction System Control Module
C1010 Battery Voltage Low
C1011 ASR/ETS/ESP Circuit Open or Shorted
C1012 Battery Voltage High
C1020 CAN Communication Fault
C1021 CAN Communication With EA/CC/ISC Control Module Interrupted
C1024 CAN Communication With Engine Control Module Interrupted
C1025 CAN Communication BAS communication with ESP control unit faulty
C1100 Left Front Axle VSS Circuit Fault
C1101 Right Front Axle VSS Circuit Fault
C1102 ETS/ASR, ABS Left Axle VSS Circuit Fault
C1103 Right Rear Axle VSS Circuit Fault
C1121 AIRmatic: fault in component B24/3 (acceler. sensor)
C1122 AIRmatic: fault in component B24/4 (acceler. sensor)
C1123 AIRmatic: fault in component B24/6 (acceler. sensor)
C1132 AIRmatic: fault in component B22/8 (level sensor)
C1133 AIRmatic: fault in component B22/9 (level sensor)
C1135 AIRmatic: fault in component B22/3 (level sensor)
C1140 BAS light, play in steering column causes steering angle sensor to lose memory(?)
C1142 ABS Lateral Acceleration Sensor Open/Shorted
C1144 AIRmatic: fault in component B7 (pressure sensor)
C1200 Stop Light Switch Open/Shorted/Implausible
C1300 Left Front Axle Solenoid Valve (Hold) (A7/3y6) Open/Shorted
C1303 Right Front Axle Solenoid Valve (Hold) Open/Shorted
C1311 Switchover Solenoid Valve (Release) Open/Shorted
C1312 Master Cylinder Switchover Valve
C1401 High Pressure Return Pump Circuit Open/Shorted; Will Not Shut Off
C1501 SPS P-Valve
C1504 BAS light, play in steering column causes steering angle sensor to lose memory(?)
C1512 Brakes Overheated
C1600 Temperature After Engine Is Turned Off
New Systems
U0001 High Speed CAN Communication Bus
U0002 High Speed CAN Communication Bus Performance
U0003 High Speed CAN Communication Bus (+) open
U0004 High Speed CAN Communication Bus (+) low
U0005 High Speed CAN Communication Bus (+) high
U0006 High Speed CAN Communication Bus (-) open
U0007 High Speed CAN Communication Bus (-) low
U0008 High Speed CAN Communication Bus (-) high
U0009 High Speed CAN Communication Bus (-) shorted to Bus (+)
U0010 Medium Speed CAN Communication Bus
U0011 Medium Speed CAN Communication Bus Performance
U0012 Medium Speed CAN Communication Bus (+) open
U0013 Medium Speed CAN Communication Bus (+) low
U0014 Medium Speed CAN Communication Bus (+) high
U0015 Medium Speed CAN Communication Bus (-) open
U0016 Medium Speed CAN Communication Bus (-) low
U0017 Medium Speed CAN Communication Bus (-) high
U0018 Medium Speed CAN Communication Bus (-) shorted to Bus (+)
U0019 Low Speed CAN Communication Bus
U0020 Low Speed CAN Communication Bus Performance
U0021 Low Speed CAN Communication Bus (+) open
U0022 Low Speed CAN Communication Bus (+) low
U0023 Low Speed CAN Communication Bus (+) high
U0024 Low Speed CAN Communication Bus (-) open
U0025 Low Speed CAN Communication Bus (-) low
U0026 Low Speed CAN Communication Bus (-) high
U0027 Low Speed CAN Communication Bus (-) shorted to Bus (+)
U0028 Vehicle Communication Bus A
U0029 Vehicle Communication Bus A Performance
U0030 Vehicle Communication Bus A (+) open
U0031 Vehicle Communication Bus A (+) low
U0032 Vehicle Communication Bus A (+) high
U0033 Vehicle Communication Bus A (-) open
U0034 Vehicle Communication Bus A (-) low
U0035 Vehicle Communication Bus A (-) high
U0036 Vehicle Communication Bus A (-) shorted to Bus (+)
U0037 Vehicle Communication Bus B
U0038 Vehicle Communication Bus B Performance
U0039 Vehicle Communication Bus B (+) open
U0040 Vehicle Communication Bus B (+) low
U0041 Vehicle Communication Bus B (+) high
U0042 Vehicle Communication Bus B (-) open
U0043 Vehicle Communication Bus B (-) low
U0044 Vehicle Communication Bus B (-) high
U0045 Vehicle Communication Bus B (-) shorted to Bus (+)
U0046 Vehicle Communication Bus C
U0047 Vehicle Communication Bus C Performance
U0048 Vehicle Communication Bus C (+) open
U0049 Vehicle Communication Bus C (+) low
U0050 Vehicle Communication Bus C (+) high
U0051 Vehicle Communication Bus C (-) open
U0052 Vehicle Communication Bus C (-) low
U0053 Vehicle Communication Bus C (-) high
U0054 Vehicle Communication Bus C (-) shorted to Bus (+)
U0055 Vehicle Communication Bus D
U0056 Vehicle Communication Bus D Performance
U0057 Vehicle Communication Bus D (+) open
U0058 Vehicle Communication Bus D (+) low
U0059 Vehicle Communication Bus D (+) high
U0060 Vehicle Communication Bus D (-) open
U0061 Vehicle Communication Bus D (-) low
U0062 Vehicle Communication Bus D (-) high
U0063 Vehicle Communication Bus D (-) shorted to Bus (+)
U0064 Vehicle Communication Bus E
U0065 Vehicle Communication Bus E Performance
U0066 Vehicle Communication Bus E (+) open
U0067 Vehicle Communication Bus E (+) low
U0068 Vehicle Communication Bus E (+) high
U0069 Vehicle Communication Bus E (-) open
U0070 Vehicle Communication Bus E (-) low
U0071 Vehicle Communication Bus E (-) high
U0072 Vehicle Communication Bus E (-) shorted to Bus (+)
U0073 Control Module Communications Bus Off
U0100 Lost Communication with ECM/PCM A
U0101 Lost Communication with TCM
U0102 Lost Communication with Transfer Case Control Module
U0103 Lost Communication with Gear Shift Module
U0104 Lost Communication with Cruise Control Module
U0105 Lost Communication with Fuel Injector Control Module
U0192 Lost Communication with Television
U0197 Lost Communication with Telephone Control Module
U0198 Lost Communication with Telematic Control Module
U0222 Lost Communication with Door Window Motor A
U0235 Lost Communications with Cruise Control Front Distance Range Sensor
U0301 Software Incompatibility with ECM/PCM
U0302 Software Incompatibility with TCM (Transmission Control Module)
U0303 Software Incompatibility with Transfer Case Control Module
U0321 Software Incompatibility with Ride Level Control Module
U0326 Software Incompatibility with Vehicle Immobilizer Control Module
U0327 Software Incompatibility with Vehicle Security Control Module
Niet gevonden wat je zocht? Misschien is je vraag al eens beantwoord voor je Algemeen Overig of stel zelf een nieuwe vraag.
