Audi A6 2002: missing messeges from
Bouwjaar: 2002, Brandstof: Benzine, Transmissie: Automaat, Motorcode: ASN, Motorinhoud (cc): 3000, Vermogen (kw): 162
hier mijn vcds log van mijn audi
mijn vraag waarom de missing messeges from XXX
mvg remco
Saturday,03,July,2021,01:48:46:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WAUZZZ4B72N105814 License Plate:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
VIN: WAUZZZ4B72N105814 Mileage: 264520km-164365miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 H HW: 8E0 909 059
Component: 3.0L V6/5V G 0001
Coding: 0011752
Shop #: WSC 02325 785 00200
VCID: 3A7B87EF765F905BCD-515A
5 Faults Found:
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
P1103 - 008 - Performance too Low - Intermittent
16805 - Warm Up Catalyst; Bank 1
P0421 - 001 - Efficiency Below Threshold - Intermittent
16815 - Warm Up Catalyst; Bank 2
P0431 - 001 - Efficiency Below Threshold
16398 - Bank 1: Camshaft B (Exhaust)
P0014 - 001 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 EN
Component: AG5 01V 3.0l5V RdW 0808
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 77FD5EDB05CD4D33F2-5178
No fault code found.
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 H
Component: ABS/ESP allrad 1728
Coding: 06397
Shop #: WSC 00231
VCID: 2643439FC2E704BB99-515A
1 Fault Found:
18031 - Powertrain Data Bus
P1623 - 35-00 - No Communication
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AA
Component: A6-Klimavollautomat 0105
Coding: 00100
Shop #: WSC 02325
VCID: 59B93863C3197B43E4-2592
3 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
01592 - Air Quality Sensor (G238)
57-00 - Electric Circuit Failure
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 M
Component: Airbag 8.4E 5003
Coding: 0000406
VCID: 3A7B87EF765F905BCD-5178
Part No: 4B0 920 933 N
Component: KOMBI+WEGFAHRS. VDO D10
Coding: 00162
Shop #: WSC 00186
VCID: 2E53BBBFEA174CFB61-515A
WAUZZZ4B72N105814 AUZ7Z0B2045004
Address 35: Centr. Locks Labels:. 4B0-962-258.clb
Part No: 4B0 962 258 K
Component: Zentralverrieg.,DWA D35
Coding: 06987
Shop #: WSC 02325
VCID: 3169A0C3FB2953037C-4F02
7 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
01559 - Drivers Door
58-00 - Can't Lock
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
VCID: 2643439FC2E704BB99-5178
1 Fault Found:
01349 - Alarm via Theft Warning System; Front
35-00 - -
audia64b
al 5 jaar lid
Geen zekering defect ?
