BMW 3-Serie: Geheime Functies Bc
Bouwjaar: 1992
hallo
ik ben op zoek naar de geheime functies van de Bc van mijn 3.25i '92
het betreft hier de uitvoering check-control - uhr - datum - buitentemp. ( 11 knoppen )
wat zou je allemaal moeten kunnen zien / uitlezen met deze speciale functies ?
bedankt voor de reacties
Stefan
stefan84
86.660 km
OBC V E36
1.Display test
2.Momentary consumption (L/100Km)
3.Momentary consumption (L/h)
4.Range consumption (L/100Km)
5.Momentary range (Km)
6.Not used
7.Fuel level from inst. cluster (L)
8.Momentary speed (Km)
9.Operating voltage KL-R
10.Language change
11.Units readout
12.Average speed for arrival function
13.Momentary arrival computed
14.Data of mask
15.Readout of fault memory
16.I/O port status
17.Encoding vehicle specific data
18.Alarm mode
19.Lock/unlock function
20.Fuel consumption correction factor (see OBCIV)
21.Software reset The test functions are accessed by pressing "10" and "1000" simultaneously. Test functions (1,10,18,19 and 20) are unlocked and can be called up by inputting the number and pressing "SET/RES". The other test functions are locked out. To unlock test functions select 19. "Lock on" will be displayed. Add the sum of the day and month display in the clock. Input this value followed by "SET/RES". To lock test functions call up test 19 and press "SET/RES" twice.
Groeten Ton
bmw-ton
770 km
MULTIFUNCTION CLOCK E36
0. Display test
1.Language. 5 different language displays are available. The languages are selected by scrolling with the 1 button. The language is stored with set/res.
2.Time mode. Switches from 12 to 24 hour mode. Scroll with 1, store with set/res.
3.Date mode. Switches from month/day to day/month. Scroll and store same as above.
4.Temp. mode. Switches between "C" and "F" degrees. Scroll and store same as above.
5.Quartz compensation factor display
6.Display status shown (hex)
7.Road speed display
8.Display and input of "k" number To access test functions press "10" and "1000". Then the desired test number followed by set/res. The test function will cancel after several seconds or can be canceled by pressing check button.
When values are switched with the test functions they are stored in the EEPROM.
Groeten Ton
bmw-ton
770 km
