Uit de handleiding (boekje van de auto) pagina 2-30
If you cannot shift out of P (Park) while holding the
brake pedal down, try this:
1. Set the parking brake.
2. Turn the ignition off and remove the key.
3. Remove the hole cover from the shift lock slot by
prying it off using a small, flat object. The shift
lock release slot is located at the top of the
shift lever.
4. Insert the key into the shift lock slot and press and
hold the key.
5. Shift to N (Neutral).
6. Remove the key from the slot, insert the key into
the ignition and start the engine.
7. Replace the shift-lock release slot cover.
8. Apply and hold the brake pedal fully and release
the parking brake.
9. Shift to the gear you want.
10. Have the vehicle fixed as soon as you can
Auto afgekeurd op auto keuring , dus probleem moest opgelost worden .
Elektro klep aan hendel automaat is de oorzaak en is vervangen !
Dit was blijkbaar alles wat nog te verkrijgen was van de aut. versnellings hendel ??
shift lever.
hold the key.
the parking brake.
Succes.
