WIE HEEFT ERVARINGEN MET D-RIEM FOCUS 16 ZETEC , HET KRUKAS TANDWIEL ZIT NAMELIJK NIET OP EEN SPIE OF CONISCH IS DUS LOSGELOPEN NA VERVANGEN V/D RIEM ALLES VOLGENS BOEKJE GEDAAN BEHALVE BOUT VERNIEUWD ?? KLEPPEN DUS KROM OM DAT DE BOUT WAS LOS GELOPEN
