Ford Transit Connect 2012: turbo spills oil
Bouwjaar: 2012, Brandstof: Diesel, Transmissie: Handgeschakeld
Hello!
I have the mentioned above Ford. So the car got into service mode and I left it to a service I know in Zwanenburg. The mechanic told me that the turbo is broken(which was questionable for me, but I trusted him), so I delivered the new turbo to him, but after mounting the new part it was the same - oil in the intercooler. I clearly now at this point that the problem is not with the turbo, and I am suspicious about the oil rails or the oil pump. But I do not trust this service anymore. So I told him to check the pressure of the oils around the turbo and the oil pump itself.
And here is my question, can you recommend me a service where I will have the problem solved? It's my company car and I need it ASAP. :(
ThatFordbrokeagain
al 5 jaar lid
Niet gevonden wat je zocht? Misschien is je vraag al eens beantwoord voor je Ford Transit of stel zelf een nieuwe vraag.
