Hierbij de geevens voor de WL-T motor( 2.5td met 109pk)
VALVE CLEARANCE
VALVE CLEARANCE INSPECTION/ADJUSTMENT
1. Remove the cylinder head cover.
2. Turn the crankshaft and align the timing mark so
that the piston of the No.1 or No.4 cylinder is at
TDC of compression.
3. Measure the valve clearances A with the No.1
cylinder at TDC of compression, and those of B
with the No.4 cylinder at TDC of compression.
Valve clearance
IN: 0.050.15 mm {0.00200.0059 in}
[Engine cold]
0.15 mm {0.0059 in}
[Engine hot (Reference)]
EX:0.150.25 mm {0.00600.0098 in}
[Engine cold]
0.25 mm {0.0098 in}
ENGIN
uilaat 0,20
inlaat 0,10
Klopt dit?
