BMW Overig : Lijst van alle foutcodes BMW
Hier een lijst met BMW Foutcodes. Dit is geen probleemstelling, maar misschien zijn er wel mensen die hier wat aan hebben.
Groetjes,
Freddy
P0001
Fuel Volume Regulator Control Circuit/Open
P0002
Range/Performance
P0003
Fuel Volume Regulator Control Circuit Low
P0004
Fuel Volume Regulator Control Circuit High
P0005
Fuel Shutoff Valve C ontrol Circuit/Open
P0006
Fuel Shutoff Valve C ontrol Circuit Low
P0007
Fuel Shutoff Valve C ontrol Circuit H igh
P0008
Engine Position System Performance (Bank
1)
P0009
2)
P0010
A Camshaft Position Actuator Circuit (Bank
1)
P0011
A Camshaft Position - Timing
Over-Advanced or System Performance
(Bank 1)
P0012
A Camshaft Position - Timing O ver-Retarded
(Bank 1)
P0013
B Camshaft Position - Actuator Circuit (Bank
1)
P0014
B Camshaft Position - Timing
(Bank 1)
P0015
B Camshaft Position - Timing O ver-Retarded
(Bank 1)
P0016
Crankshaft Position Camshaft Position
Correlation (Bank 1 Sensor A)
P0017
Correlation (Bank 1 Sensor B)
P0018
Correlation (Bank 2 Sensor A)
P0019
Correlation (Bank 2 Sensor B)
P0020
2)
This section contains the J2012 Recommended Powertrain Diagnostic Trouble
Codes. These codes are recommendations not a requirement. Manufacturers
may not follow these, but most do. Check your vehicles service manual for DTC
meaning if you think the codes you are getting do not make sense.
Remember:
1) Visual inspections are important!
2) Problems with wiring and connectors are common, especially for intermittent
faults.
3) Mechanical problems (vacuum leaks, binding or sticking linkages, etc.) can
make a good sensor look bad to the computer.
4) Incorrect information from a sensor may cause the computer to control the
engine in the wrong way. Faulty engine operation might even make the
computer show a known good sensor as being bad!
P0021
(Bank 2)
P0022
(Bank 2)
P0023
2)
P0024
(Bank 2)
P0025
(Bank 2)
P0026
Intake Valve Control Solenoid Circuit
Range/Performance (Bank 1)
P0027
Exhaust Valve Control Solenoid Circuit
P0028
Range/Performance (Bank 2)
P0029
P0030
HO2S Heater Control Circuit (Bank 1
Sensor 1)
P0031
HO2S Heater Control Circuit Low (Bank 1
Sensor 1)
P0032
HO2S Heater Control Circuit High (Bank 1
Sensor 1)
P0033
Turbo Charger Bypass Valve Control Circuit
P0034
Low
P0035
High
P0036
HO2S Heater Control C ircuit (Bank 1 Sensor
2)
P0037
Sensor 2)
P0038
Sensor 2)
P0039
Turbo/Super Charger Bypass Valve Control
Circuit Range/Performance
P0040
O2 Sensor Signals Swapped Bank 1 Sensor
1/ Bank 2 Sensor 1
P0041
2/ Bank 2 Sensor 2
P0042
HO2S Heater Control Circuit (Bank 1 Sensor
3)
P0043
Sensor 3)
P0044
Sensor 3)
P0045
Turbo/Super Charger Boost Control
Solenoid Circuit/Open
P0046
Solenoid Circuit Range/Performance
P0047
Solenoid Circuit Low
P0048
Solenoid Circuit High
P0049
Turbo/Super Charger Turbine Overspeed
P0050
HO2S Heater Control Circuit (Bank 2 Sensor
1)
P0051
HO2S Heater Control Circuit Low (Bank 2
Sensor 1)
P0052
HO2S Heater Control Circuit High (Bank 2
Sensor 1)
P0053
HO2S Heater Resistance (Bank 1 Sensor 1)
P0054
HO2S Heater Resistance (Bank 1 Sensor 2)
P0055
HO2S Heater Resistance (Bank 1 Sensor 3)
P0056
2)
P0057
Sensor 2)
P0058
Sensor 2)
P0059
HO2S Heater Resistance (Bank 2 Sensor 1)
P0060
HO2S Heater Resistance (Bank 2 Sensor 2)
P0061
HO2S Heater Resistance (Bank 2 Sensor 3)
P0062
HO2S Heater Control C ircuit (Bank 2 Sensor
3)
P0063
Sensor 3)
P0064
Sensor 3)
P0065
Air Assisted Injector Control
Range/Performance
P0066
Air Assisted Injector Control Circuit or Circuit
Low
P0067
Air Assisted Injector Control Circuit High
P0068
MAP/MAF Throttle Position Correlation
P0069
Manifold Absolute Pressure Barometric
Pressure Correlation
P0070
Ambient Air Temperature Sensor Circuit
P0071
Range/Performance
P0072
Ambient Air Temperature Sensor C ircuit Low
P0073
High
P0074
Intermittent
P0075
Intake Valve Control Solenoid Circuit (Bank
1)
P0076
Intake Valve Control Solenoid Circuit Low
(Bank 1)
P0077
Intake Valve Control Solenoid Circuit High
(Bank 1)
P0078
(Bank 1)
P0079
Exhaust Valve Control Solenoid Circuit Low
(Bank 1)
P0080
Exhaust Valve C ontrol Solenoid C ircuit High
(Bank 1)
P0081
2)
P0082
(Bank 2)
P0083
(Bank 2)
P0084
(Bank 2)
P0085
(Bank 2)
P0086
(Bank 2)
P0087
Fuel Rail/System Pressure - Too Low
P0088
Fuel Rail/System Pressure - Too High
P0089
Fuel Pressure Regulator 1 Performance
P0090
Fuel Pressure Regulator 1 C ontrol Circuit
P0091
Low
P0092
High
P0093
Fuel System Leak Detected Large Leak
P0094
Fuel System Leak Detected Small Leak
P0095
Intake Air Temperature Sensor 2 C ircuit
P0096
Range/Performance
P0097
Intake Air Temperature Sensor 2 C ircuit Low
P0098
Intake Air Temperature Sensor 2 Circuit High
P0099
Intermittent/Erratic
P0100
Mass or Volume Air Flow Circuit
P0101
Range/Performance
P0102
Mass or Volume Air Flow Circuit Low Input
P0103
Mass or Volume Air Flow Circuit High Input
P0104
Mass or Volume Air Flow Circuit Interm ittent
P0105
Manifold Absolute Pressure/Barometric
Pressure Circuit
P0106
Pressure Circuit Range/Performance
P0107
Pressure Circuit Low Input
P0108
Pressure Circuit H igh Input
P0109
Pressure Circuit Interm ittent
P0110
Intake Air Temperature Sensor 1 C ircuit
P0111
Range/Performance
P0112
Intake Air Temperature Sensor 1 Circuit Low
P0113
Intake Air Temperature Sensor 1 C ircuit H igh
P0114
Intermittent
P0115
Engine Coolant Temperature Circuit
P0116
Range/Performance
P0117
Engine Coolant Temperature Circuit Low
P0118
Engine Coolant Temperature Circuit High
P0119
Intermittent
P0120
Throttle/Pedal Position Sensor/Switch "A"
Circuit
P0121
P0122
Circuit Low
P0123
Circuit H igh
P0124
P0125
Insufficient Coolant Temperature for Closed
Loop Fuel Control
P0126
Insufficient Coolant Temperature for Stable
Operation
P0127
Intake Air Temperature Too H igh
P0128
Coolant Thermostat (Coolant Temperature
Below Thermostat Regulating Temperature)
P0129
Barometric Pressure Too Low
P0130
O2 Sensor Circuit (Bank 1 Sensor 1)
P0131
O2 Sensor Circuit Low Voltage (Bank 1
Sensor 1)
P0132
O2 Sensor Circuit High Voltage (Bank 1
Sensor 1)
P0133
O2 Sensor Circuit Slow Response (Bank 1
Sensor 1)
P0134
O2 Sensor Circuit No Activity Detected
(Bank 1 Sensor 1)
P0135
O2 Sensor Heater Circuit (Bank 1 Sensor 1)
P0136
O2 Sensor Circuit (Bank 1 Sensor 2)
P0137
Sensor 2)
P0138
Sensor 2)
P0139
Sensor 2)
P0140
(Bank 1 Sensor 2)
P0141
O2 Sensor Heater Circuit (Bank 1 Sensor 2)
P0142
O2 Sensor Circuit (Bank 1 Sensor 3)
P0143
Sensor 3)
P0144
Sensor 3)
P0145
Sensor 3)
P0146
(Bank 1 Sensor 3)
P0147
O2 Sensor Heater Circuit (Bank 1 Sensor 3)
P0148
Fuel Delivery Error
P0149
Fuel Timing Error
P0150
O2 Sensor Circuit (Bank 2 Sensor 1)
P0151
O2 Sensor Circuit Low Voltage (Bank 2
Sensor 1)
P0152
O2 Sensor Circuit High Voltage (Bank 2
Sensor 1)
P0153
O2 Sensor Circuit Slow Response (Bank 2
Sensor 1)
P0154
(Bank 2 Sensor 1)
P0155
O2 Sensor Heater Circuit (Bank 2 Sensor 1)
P0156
O2 Sensor Circuit (Bank 2 Sensor 2)
P0157
Sensor 2)
P0158
Sensor 2)
P0159
Sensor 2)
P0160
(Bank 2 Sensor 2)
P0161
O2 Sensor Heater Circuit (Bank 2 Sensor 2)
P0162
O2 Sensor Circuit (Bank 2 Sensor 3)
P0163
Sensor 3)
P0164
Sensor 3)
P0165
Sensor 3)
P0166
(Bank 2 Sensor 3)
P0167
O2 Sensor Heater Circuit (Bank 2 Sensor 3)
P0168
Fuel Temperature Too High
P0169
Incorrect Fuel Composition
P0170
Fuel Trim (Bank 1)
P0171
System Too Lean (Bank 1)
P0172
System Too Rich (Bank 1)
P0173
Fuel Trim (Bank 2)
P0174
System Too Lean (Bank 2)
P0175
System Too Rich (Bank 2)
P0176
Fuel Composition Sensor Circuit
P0177
Range/Performance
P0178
Fuel Composition Sensor Circuit Low
P0179
Fuel Composition Sensor Circuit High
P0180
Fuel Temperature Sensor A Circuit
P0181
Range/Performance
P0182
Fuel Temperature Sensor A Circuit Low
P0183
Fuel Temperature Sensor A Circuit High
P0184
Intermittent
P0185
Fuel Temperature Sensor B Circuit
P0186
Range/Performance
P0187
Fuel Temperature Sensor B Circuit Low
P0188
Fuel Temperature Sensor B Circuit High
P0189
Intermittent
P0190
Fuel Rail Pressure Sensor Circuit
P0191
Range/Performance
P0192
Fuel Rail Pressure Sensor Circuit Low
P0193
Fuel Rail Pressure Sensor Circuit High
P0194
Intermittent
P0195
Engine Oil Temperature Sensor
P0196
Range/Performance
P0197
Engine Oil Temperature Sensor Low
P0198
Engine Oil Temperature Sensor High
P0199
Engine Oil Temperature Sensor Intermittent
P0200
Injector Circuit/Open
P0201
Injector Circuit/Open C ylinder 1
P0202
Injector Circuit/Open C ylinder 2
P0203
Injector Circuit/Open C ylinder 3
P0204
Injector Circuit/Open C ylinder 4
P0205
Injector Circuit/Open C ylinder 5
P0206
Injector Circuit/Open C ylinder 6
P0207
Injector Circuit/Open C ylinder 7
P0208
Injector Circuit/Open C ylinder 8
P0209
Injector Circuit/Open C ylinder 9
P0210
Injector Circuit/Open C ylinder 10
P0211
Injector Circuit/Open C ylinder 11
P0212
Injector Circuit/Open C ylinder 12
P0213
Cold Start Injector 1
P0214
Cold Start Injector 2
P0215
Engine Shutoff Solenoid
P0216
Injector/Injection Timing Control Circuit
P0217
Engine Coolant O ver Temperature Condition
P0218
Transmission Fluid Over Temperature
Condition
P0219
Engine O verspeed Condition
P0220
Throttle/Pedal Position Sensor/Switch "B"
Circuit
P0221
P0222
Circuit Low
P0223
Circuit H igh
P0224
P0225
Throttle/Pedal Position Sensor/Switch "C"
Circuit
P0226
P0227
Circuit Low
P0228
Circuit H igh
P0229
P0230
Fuel Pump Primary Circuit
P0231
Fuel Pump Secondary Circuit Low
P0232
Fuel Pump Secondary Circuit High
P0233
Fuel Pump Secondary Circuit Interm ittent
P0234
Turbo/Super Charger O verboost Condition
P0235
Turbo/Super Charger Boost Sensor "A"
Circuit
P0236
P0237
Circuit Low
P0238
Circuit H igh
P0239
Turbo/Super Charger Boost Sensor "B"
Circuit
P0240
P0241
Circuit Low
P0242
Circuit H igh
P0243
Turbo/Super Charger Wastegate Solenoid
"A"
P0244
"A" Range/Performance
P0245
"A" Low
P0246
"A" H igh
P0247
"B"
P0248
"B" Range/Performance
P0249
"B" Low
P0250
"B" H igh
P0251
Injection Pump Fuel M etering C ontrol "A"
(Cam/Rotor/Injector)
P0252
Range/Performance (Cam/Rotor/Injector)
P0253
Low (Cam/Rotor/Injector)
P0254
High (Cam/Rotor/Injector)
P0255
Intermittent (Cam/Rotor/Injector)
P0256
Injection Pump Fuel M etering C ontrol "B"
P0257
P0258
P0259
P0260
Injection Pump Fuel M etering Control "B"
P0261
Cylinder 1 Injector Circuit Low
P0262
Cylinder 1 Injector Circuit High
P0263
Cylinder 1 Contribution/Balance
P0264
Cylinder 2 Injector Circuit Low
P0265
Cylinder 2 Injector Circuit High
P0266
Cylinder 2 Contribution/Balance
P0267
Cylinder 3 Injector Circuit Low
P0268
Cylinder 3 Injector Circuit High
P0269
Cylinder 3 Contribution/Balance
P0270
Cylinder 4 Injector Circuit Low
P0271
Cylinder 4 Injector Circuit High
P0272
Cylinder 4 Contribution/Balance
P0273
Cylinder 5 Injector Circuit Low
P0274
Cylinder 5 Injector Circuit High
P0275
Cylinder 5 Contribution/Balance
P0276
Cylinder 6 Injector Circuit Low
P0277
Cylinder 6 Injector Circuit High
P0278
Cylinder 6 Contribution/Balance
P0279
Cylinder 7 Injector Circuit Low
P0280
Cylinder 7 Injector Circuit High
P0281
Cylinder 7 Contribution/Balance
P0282
Cylinder 8 Injector Circuit Low
P0283
Cylinder 8 Injector Circuit High
P0284
Cylinder 8 Contribution/Balance
P0285
Cylinder 9 Injector Circuit Low
P0286
Cylinder 9 Injector Circuit High
P0287
Cylinder 9 Contribution/Balance
P0288
Cylinder 10 Injector C ircuit Low
P0289
Cylinder 10 Injector C ircuit High
P0290
Cylinder 10 Contribution/Balance
P0291
Cylinder 11 Injector Circuit Low
P0292
Cylinder 11 Injector Circuit High
P0293
Cylinder 11 Contribution/Balance
P0294
Cylinder 12 Injector C ircuit Low
P0295
Cylinder 12 Injector C ircuit High
P0296
Cylinder 12 Contribution/Balance
P0297
Vehicle Overspeed Condition
P0298
Engine O il Over Temperature
P0299
Turbo/Super Charger Underboost
P0300
Random/Multiple Cylinder M isfire Detected
P0301
Cylinder 1 M isfire Detected
P0302
Cylinder 2 M isfire Detected
P0303
Cylinder 3 M isfire Detected
P0304
Cylinder 4 M isfire Detected
P0305
Cylinder 5 M isfire Detected
P0306
Cylinder 6 M isfire Detected
P0307
Cylinder 7 M isfire Detected
P0308
Cylinder 8 M isfire Detected
P0309
Cylinder 9 M isfire Detected
P0310
Cylinder 10 M isfire Detected
P0311
Cylinder 11 M isfire Detected
P0312
Cylinder 12 M isfire Detected
P0313
Misfire Detected with Low Fuel
P0314
Single C ylinder M isfire (Cylinder not
Specified)
P0315
Crankshaft Position S ystem Variation Not
Learned
P0316
Engine Misfire Detected on Startup (First
1000 Revolutions)
P0317
Rough Road Hardware Not Present
P0318
Rough Road Sensor A Signal Circuit
P0319
Rough Road Sensor B
P0320
Ignition/Distributor Engine Speed Input
Circuit
P0321
P0322
Circuit No Signal
P0323
P0324
Knock Control System Error
P0325
Knock Sensor 1 Circuit (Bank 1 or Single
Sensor)
P0326
Knock Sensor 1 Circuit Range/Performance
(Bank 1 or Single Sensor)
P0327
Knock Sensor 1 Circuit Low (Bank 1 or
Single Sensor )
P0328
Knock Sensor 1 Circuit High (Bank 1 or
Single Sensor)
P0329
Knock Sensor 1 Circuit Input Interm ittent
P0330
Knock Sensor 2 Circuit (Bank 2)
P0331
Knock Sensor 2 Circuit Range/Performance
(Bank 2)
P0332
Knock Sensor 2 Circuit Low (Bank 2)
P0333
Knock Sensor 2 Circuit High (Bank 2)
P0334
Knock Sensor 2 Circuit Input Intermittent
(Bank 2)
P0335
Crankshaft Position Sensor "A" Circuit
P0336
Range/Performance
P0337
Crankshaft Position Sensor "A" Circuit Low
P0338
Crankshaft Position Sensor "A" Circuit High
P0339
Intermittent
P0340
Camshaft Position Sensor "A" Circuit (Bank
1 or Single Sensor)
P0341
Range/Performance (Bank 1 or Single
Sensor)
P0342
Camshaft Position Sensor "A" Circuit Low
P0343
Camshaft Position Sensor "A" Circuit High
P0344
Intermittent (Bank 1 or Single Sensor)
P0345
2 )
P0346
Range/Performance (Bank 2 )
P0347
(Bank 2 )
P0348
(Bank 2 )
P0349
Intermittent (Bank 2 )
P0350
Ignition Coil Primary/Secondary Circuit
P0351
Ignition Coil "A" Primary/Secondary C ircuit
P0352
Ignition Coil "B" Primary/Secondary C ircuit
P0353
Ignition Coil "C" Primary/Secondary Circuit
P0354
Ignition Coil "D" Primary/Secondary Circuit
P0355
Ignition Coil "E" Primary/Secondary C ircuit
P0356
Ignition Coil "F" Primary/Secondary Circuit
P0357
Ignition Coil "G" Primary/Secondary Circuit
P0358
Ignition Coil "H" Primary/Secondary Circuit
P0359
Ignition Coil "I" Primary/Secondary Circuit
P0360
Ignition Coil "J" Primary/Secondary C ircuit
P0361
Ignition Coil "K" Primary/Secondary C ircuit
P0362
Ignition Coil "L" Primary/Secondary Circuit
P0363
Misfire Detected Fueling Disabled
P0364
Reserved
P0365
Camshaft Position Sensor "B" Circuit (Bank
1 )
P0366
Range/Performance (Bank 1 )
P0367
Camshaft Position Sensor "B" Circuit Low
(Bank 1 )
P0368
Camshaft Position Sensor "B" Circuit High
(Bank 1 )
P0369
Intermittent (Bank 1 )
P0370
Timing Reference H igh Resolution Signal "A"
P0371
Timing Reference High Resolution Signal "A"
Too M any Pulses
P0372
Too Few Pulses
P0373
Interm ittent/Erratic Pulses
P0374
No Pulse
P0375
Timing Reference High Resolution Signal "B"
P0376
Too M any Pulses
P0377
Too Few Pulses
P0378
P0379
No Pulses
P0380
Glow Plug/Heater Circuit "A"
P0381
Glow Plug/Heater Indicator Circuit
P0382
Glow Plug/Heater Circuit "B"
P0385
Crankshaft Position Sensor "B" Circuit
P0386
Range/Performance
P0387
Crankshaft Position Sensor "B" Circuit Low
P0388
Crankshaft Position Sensor "B" Circuit High
P0389
Intermittent
P0390
2)
P0391
P0392
(Bank 2)
P0393
(Bank 2)
P0394
Intermittent (Bank 2)
P0400
Exhaust Gas Recirculation Flow
P0401
Exhaust Gas Recirculation Flow Insufficient
Detected
P0402
Exhaust Gas Recirculation Flow Excessive
Detected
P0403
Exhaust Gas Recirculation Control Circuit
P0404
Range/Performance
P0405
Exhaust Gas Recirculation Sensor "A"
Circuit Low
P0406
Circuit High
P0407
Exhaust Gas Recirculation Sensor "B"
Circuit Low
P0408
Circuit High
P0409
Circuit
P0410
Secondary Air Injection System
P0411
Secondary Air Injection System Incorrect
Flow Detected
P0412
Secondary Air Injection System Switching
Valve "A " C ircuit
P0413
Valve "A" Circuit Open
P0414
Valve "A " C ircuit Shorted
P0415
Valve "B " C ircuit
P0416
Valve "B" Circuit Open
P0417
Valve "B" Circuit Shorted
P0418
Secondary Air Injection System Control "A"
Circuit
P0419
Secondary Air Injection System Control "B"
Circuit
P0420
Catalyst System Efficiency Below Threshold
(Bank 1)
P0421
Warm Up Catalyst Efficiency Below
Threshold (Bank 1)
P0422
Main Catalyst E fficiency Below Threshold
(Bank 1)
P0423
Heated Catalyst Efficiency Below Threshold
(Bank 1)
P0424
Heated Catalyst Temperature Below
Threshold (Bank 1)
P0425
Catalyst Temperature Sensor (Bank 1)
P0426
P0427
Catalyst Temperature Sensor Low (Bank 1)
P0428
Catalyst Temperature Sensor High (Bank 1)
P0429
Catalyst Heater Control Circuit (Bank 1)
P0430
(Bank 2)
P0431
Threshold (Bank 2)
P0432
(Bank 2)
P0433
(Bank 2)
P0434
Threshold (Bank 2)
P0435
Catalyst Temperature Sensor (Bank 2)
P0436
P0437
Catalyst Temperature Sensor Low (Bank 2)
P0438
Catalyst Temperature Sensor High (Bank 2)
P0439
Catalyst Heater Control C ircuit (Bank 2)
P0440
Evaporative Emission System
P0441
Evaporative Emission System Incorrect
Purge F low
P0442
Evaporative Emission System Leak
Detected (small leak)
P0443
Evaporative Emission System Purge Control
Valve Circuit
P0444
Valve Circuit Open
P0445
Valve Circuit Shorted
P0446
Evaporative Emission System Vent Control
Circuit
P0447
Circuit Open
P0448
Circuit Shorted
P0449
Valve/Solenoid C ircuit
P0450
Evaporative Emission System Pressure
Sensor/Switch
P0451
Sensor/Switch Range/Performance
P0452
Sensor/Switch Low
P0453
Sensor/Switch High
P0454
Sensor/Switch Interm ittent
P0455
Detected (large leak)
P0456
Detected (very small leak)
P0457
Detected (fuel cap loose/off)
P0458
Valve Circuit Low
P0459
Valve Circuit High
P0460
Fuel Level Sensor "A" Circuit
P0461
Range/Performance
P0462
Fuel Level Sensor "A" Circuit Low
P0463
Fuel Level Sensor "A" Circuit High
P0464
Fuel Level Sensor "A" Circuit Intermittent
P0465
EVAP Purge F low Sensor Circuit
P0466
Range/Performance
P0467
EVAP Purge Flow Sensor Circuit Low
P0468
EVAP Purge Flow Sensor Circuit High
P0469
EVAP Purge Flow Sensor C ircuit Intermittent
P0470
Exhaust Pressure Sensor
P0471
Range/Performance
P0472
Exhaust Pressure Sensor Low
P0473
Exhaust Pressure Sensor High
P0474
Exhaust Pressure Sensor Intermittent
P0475
Exhaust Pressure Control Valve
P0476
Range/Performance
P0477
Exhaust Pressure Control Valve Low
P0478
Exhaust Pressure Control Valve High
P0479
Exhaust Pressure Control Valve Intermittent
P0480
Fan 1 Control Circuit
P0481
Fan 2 Control Circuit
P0482
Fan 3 Control Circuit
P0483
Fan Rationality Check
P0484
Fan Circuit O ver Current
P0485
Fan Power/Ground Circuit
P0486
Circuit
P0487
Exhaust Gas Recirculation Throttle Position
Control C ircuit
P0488
Control Range/Performance
P0489
Low
P0490
High
P0491
Secondary Air Injection System (Bank 1)
P0492
Secondary Air Injection System (Bank 2)
P0493
Fan Overspeed
P0494
Fan Speed Low
P0495
Fan Speed High
P0496
Evaporative Emission System High Purge
Flow
P0497
Evaporative Emission System Low Purge
Flow
P0498
Evaporative Emission System Vent Valve
Control C ircuit Low
P0499
Control C ircuit High
P0500
Vehicle Speed Sensor "A"
P0501
Range/Performance
P0502
Vehicle Speed Sensor "A" Circuit Low Input
P0503
Interm ittent/Erratic/High
P0504
Brake Switch A/B Correlation
P0505
Idle Air Control System
P0506
Idle Air Control System RPM Lower Than
Expected
P0507
Idle Air Control System RPM Higher Than
Expected
P0508
Idle Air Control System Circuit Low
P0509
Idle Air Control System Circuit High
P0510
Closed Throttle Position Switch
P0511
Idle Air Control Circuit
P0512
Starter Request Circuit
P0513
Incorrect Immobilizer Key
P0514
Battery Temperature Sensor C ircuit
Range/Performance
P0515
P0516
Battery Temperature Sensor C ircuit Low
P0517
Battery Temperature Sensor C ircuit High
P0518
Idle Air Control Circuit Interm ittent
P0519
Idle Air Control System Performance
P0520
Engine Oil Pressure Sensor/Switch Circuit
P0521
Range/Performance
P0522
Engine Oil Pressure Sensor/Switch Low
Voltage
P0523
Engine Oil Pressure Sensor/Switch High
Voltage
P0524
Engine Oil Pressure Too Low
P0525
Cruise C ontrol Servo Control Circuit
Range/Performance
P0526
Fan Speed Sensor Circuit
P0527
Range/Performance
P0528
Fan Speed Sensor Circuit No Signal
P0529
Fan Speed Sensor Circuit Intermittent
P0530
A/C Refrigerant Pressure Sensor A C ircuit
P0531
Range/Performance
P0532
Low
P0533
High
P0534
Air Conditioner Refrigerant C harge Loss
P0535
A/C Evaporator Temperature Sensor Circuit
P0536
Range/Performance
P0537
Low
P0538
High
P0539
Intermittent
P0540
Intake Air Heater A C ircuit
P0541
Intake Air Heater A C ircuit Low
P0542
Intake Air Heater A C ircuit High
P0543
Intake Air Heater A C ircuit Open
P0544
Exhaust Gas Temperature Sensor Circuit
(Bank 1 Sensor 1)
P0545
Low (Bank 1 Sensor 1)
P0546
High (Bank 1 Sensor 1)
P0547
(Bank 2 Sensor 1)
P0548
Low (Bank 2 Sensor 1)
P0549
High (Bank 2 Sensor 1)
P0550
Power Steering Pressure Sensor/Switch
Circuit
P0551
P0552
Circuit Low Input
P0553
Circuit High Input
P0554
P0555
Brake Booster Pressure Sensor Circuit
P0556
Range/Performance
P0557
Brake Booster Pressure Sensor Circuit Low
Input
P0558
Brake Booster Pressure Sensor Circuit High
Input
P0559
Intermittent
P0560
System Voltage
P0561
System Voltage Unstable
P0562
System Voltage Low
P0563
System Voltage High
P0564
Cruise Control M ulti-Function Input "A"
Circuit
P0565
Cruise Control On Signal
P0566
Cruise Control O ff Signal
P0567
Cruise Control Resume Signal
P0568
Cruise Control Set Signal
P0569
Cruise C ontrol Coast Signal
P0570
Cruise Control Accelerate Signal
P0571
Brake Switch "A" Circuit
P0572
Brake Switch "A" Circuit Low
P0573
Brake Switch "A" Circuit High
P0574
Cruise Control System - Vehicle Speed Too
High
P0575
Cruise Control Input Circuit
P0576
Cruise Control Input Circuit Low
P0577
Cruise Control Input Circuit High
P0578
Cruise Control M ulti-Function Input A
Circuit Stuck
P0579
P0580
Circuit Low
P0581
Cruise C ontrol M ulti-Function Input A
Circuit H igh
P0582
Cruise Control Vacuum Control Circuit/Open
P0583
Cruise Control Vacuum Control Circuit Low
P0584
Cruise Control Vacuum Control Circuit High
P0585
Cruise C ontrol M ulti-Function Input A/B
Correlation
P0586
Cruise C ontrol Vent Control C ircuit/Open
P0587
Cruise C ontrol Vent Control C ircuit Low
P0588
Cruise C ontrol Vent Control C ircuit High
P0589
Cruise C ontrol M ulti-Function Input B
Circuit
P0590
Circuit Stuck
P0591
P0592
Circuit Low
P0593
Circuit H igh
P0594
Cruise C ontrol Servo C ontrol Circuit/Open
P0595
Cruise C ontrol Servo C ontrol Circuit Low
P0596
Cruise C ontrol Servo C ontrol Circuit H igh
P0597
Thermostat H eater Control C ircuit/Open
P0598
Thermostat H eater Control C ircuit Low
P0599
Thermostat H eater Control C ircuit High
P0600
Serial Communication Link
P0601
Internal Control M odule M emory Check Sum
Error
P0602
Control Module Programming Error
P0603
Internal Control M odule Keep Alive M emory
(KAM) E rror
P0604
Internal Control M odule Random Access
Memory (RAM) Error
P0605
Internal Control M odule Read Only Memory
(ROM) E rror
P0606
ECM/PCM P rocessor
P0607
Control M odule Performance
P0608
Control Module VSS Output "A"
P0609
Control Module VSS Output "B"
P0610
Control M odule Vehicle Options Error
P0611
Fuel Injector Control M odule Performance
P0612
Fuel Injector Control M odule Relay Control
P0613
TCM Processor
P0614
ECM / TCM Incompatible
P0615
Starter Relay C ircuit
P0616
Starter Relay Circuit Low
P0617
Starter Relay C ircuit High
P0618
Alternative Fuel Control Module KAM Error
P0619
Alternative Fuel C ontrol M odule RAM/ROM
Error
P0620
Generator Control Circuit
P0621
Generator Lamp/L Terminal C ircuit
P0622
Generator Field/F Terminal Circuit
P0623
Generator Lamp C ontrol Circuit
P0624
Fuel Cap Lamp Control Circuit
P0625
Generator Field/F Terminal Circuit Low
P0626
Generator Field/F Terminal Circuit High
P0627
Fuel Pump A Control Circuit /Open
P0628
Fuel Pump A Control Circuit Low
P0629
Fuel Pump A Control Circuit High
P0630
VIN Not Programmed or Incompatible
ECM/PCM
P0631
VIN Not P rogrammed or Incompatible TCM
P0632
Odometer Not Programmed ECM/PCM
P0633
Immobilizer Key Not Programmed
ECM/PCM
P0634
PCM/ECM/TCM Internal Temperature Too
High
P0635
Power Steering Control Circuit
P0636
Power Steering Control Circuit Low
P0637
Power Steering Control Circuit High
P0638
Throttle Actuator Control
P0639
P0640
Intake Air Heater Control Circuit
P0641
Sensor Reference Voltage A Circuit/Open
P0642
Sensor Reference Voltage A C ircuit Low
P0643
Sensor Reference Voltage A Circuit High
P0644
Driver Display Serial Communication Circuit
P0645
A/C C lutch Relay C ontrol Circuit
P0646
A/C C lutch Relay C ontrol Circuit Low
P0647
A/C C lutch Relay C ontrol Circuit H igh
P0648
Immobilizer Lam p Control Circuit
P0649
Speed Control Lamp Control Circuit
P0650
Malfunction Indicator Lamp (M IL) Control
Circuit
P0651
Sensor Reference Voltage B Circuit/Open
P0652
Sensor Reference Voltage B Circuit Low
P0653
Sensor Reference Voltage B Circuit High
P0654
Engine RPM Output Circuit
P0655
Engine Hot Lam p Output Control Circuit
P0656
Fuel Level Output Circuit
P0657
Actuator Supply Voltage Circuit/Open
P0658
Actuator Supply Voltage Circuit Low
P0659
Actuator Supply Voltage Circuit High
P0660
Intake Manifold Tuning Valve Control
Circuit/Open (Bank 1)
P0661
Intake Manifold Tuning Valve Control Circuit
Low (Bank 1)
P0662
High (Bank 1)
P0663
Circuit/Open (Bank 2)
P0664
Low (Bank 2)
P0665
High (Bank 2)
P0666
Sensor Circuit
P0667
Sensor Range/Performance
P0668
Sensor Circuit Low
P0669
Sensor Circuit H igh
P0670
Glow Plug M odule C ontrol Circuit
P0671
Cylinder 1 G low Plug Circuit
P0672
Cylinder 2 G low Plug Circuit
P0673
Cylinder 3 G low Plug Circuit
P0674
Cylinder 4 G low Plug Circuit
P0675
Cylinder 5 G low Plug Circuit
P0676
Cylinder 6 G low Plug Circuit
P0677
Cylinder 7 G low Plug Circuit
P0678
Cylinder 8 G low Plug Circuit
P0683
Glow Plug Control M odule to PCM
Communication C ircuit
P0684
Communication C ircuit Range/Performance
P0685
ECM/PCM Power Relay Control Circuit
/Open
P0686
ECM/PCM Power Relay Control Circuit Low
P0687
ECM/PCM Power Relay Control Circuit H igh
P0688
ECM/PCM Power Relay Sense Circuit /Open
P0689
ECM/PCM Power Relay Sense Circuit Low
P0690
ECM/PCM Power Relay Sense Circuit H igh
P0691
Fan 1 Control Circuit Low
P0692
Fan 1 Control Circuit High
P0693
Fan 2 Control Circuit Low
P0694
Fan 2 Control Circuit High
P0695
Fan 3 Control Circuit Low
P0696
Fan 3 Control Circuit High
P0697
Sensor Reference Voltage C C ircuit/Open
P0698
Sensor Reference Voltage C C ircuit Low
P0699
Sensor Reference Voltage C C ircuit High
P0700
Transmission Control System (MIL Request)
P0701
Range/Performance
P0702
Transmission Control System Electrical
P0703
Brake Switch "B" Circuit
P0704
Clutch Switch Input Circuit Malfunction
P0705
Transmission Range Sensor Circuit
Malfunction (PRNDL Input)
P0706
Range/Performance
P0707
Transmission Range Sensor Circuit Low
P0708
Transmission Range Sensor Circuit High
P0709
Intermittent
P0710
Transmission Fluid Temperature Sensor A
Circuit
P0711
P0712
Circuit Low
P0713
Circuit High
P0714
P0715
Input/Turbine Speed Sensor "A" Circuit
P0716
Range/Performance
P0717
Input/Turbine Speed Sensor "A" Circuit No
Signal
P0718
Intermittent
P0719
Brake Switch "B" Circuit Low
P0720
Output Speed Sensor C ircuit
P0721
Range/Performance
P0722
Output Speed Sensor Circuit No Signal
P0723
Output Speed Sensor C ircuit Intermittent
P0724
Brake Switch "B" Circuit High
P0725
Engine Speed Input Circuit
P0726
Range/Performance
P0727
Engine Speed Input Circuit No Signal
P0728
Engine Speed Input Circuit Intermittent
P0729
Gear 6 Incorrect Ratio
P0730
Incorrect G ear Ratio
P0731
Gear 1 Incorrect Ratio
P0732
Gear 2 Incorrect Ratio
P0733
Gear 3 Incorrect Ratio
P0734
Gear 4 Incorrect Ratio
P0735
Gear 5 Incorrect Ratio
P0736
Reverse Incorrect Ratio
P0737
TCM Engine Speed Output Circuit
P0738
TCM Engine Speed Output Circuit Low
P0739
TCM Engine Speed Output Circuit High
P0740
Torque Converter Clutch Circuit/Open
P0741
Performance or Stuck Off
P0742
Torque Converter Clutch Circuit Stuck On
P0743
Torque Converter Clutch Circuit Electrical
P0744
Torque Converter C lutch Circuit Interm ittent
P0745
Pressure Control Solenoid "A"
P0746
Pressure Control Solenoid "A" Performance
or Stuck O ff
P0747
Pressure Control Solenoid "A" Stuck On
P0748
Pressure Control Solenoid "A" Electrical
P0749
Pressure Control Solenoid "A" Intermittent
P0750
Shift Solenoid "A"
P0751
Shift Solenoid "A" Performance or Stuck Off
P0752
Shift Solenoid "A" S tuck On
P0753
Shift Solenoid "A" E lectrical
P0754
Shift Solenoid "A " Interm ittent
P0755
Shift Solenoid "B"
P0756
Shift Solenoid "B" Performance or Stuck Off
P0757
Shift Solenoid "B" S tuck On
P0758
Shift Solenoid "B" E lectrical
P0759
Shift Solenoid "B " Interm ittent
P0760
Shift Solenoid "C"
P0761
Shift Solenoid "C" Performance or Stuck Off
P0762
Shift Solenoid "C" S tuck On
P0763
Shift Solenoid "C" Electrical
P0764
Shift Solenoid "C" Interm ittent
P0765
Shift Solenoid "D"
P0766
Shift Solenoid "D" Performance or Stuck Off
P0767
Shift Solenoid "D" S tuck On
P0768
Shift Solenoid "D" Electrical
P0769
Shift Solenoid "D " Interm ittent
P0770
Shift Solenoid "E"
P0771
Shift Solenoid "E" Performance or Stuck O ff
P0772
Shift Solenoid "E" S tuck On
P0773
Shift Solenoid "E" E lectrical
P0774
Shift Solenoid "E " Interm ittent
P0775
Pressure Control Solenoid "B"
P0776
Pressure Control Solenoid "B" Performance
or Stuck off
P0777
Pressure Control Solenoid "B" Stuck On
P0778
Pressure Control Solenoid "B" Electrical
P0779
Pressure Control Solenoid "B" Intermittent
P0780
Shift E rror
P0781
1-2 Shift
P0782
2-3 Shift
P0783
3-4 Shift
P0784
4-5 Shift
P0785
Shift/Timing Solenoid
P0786
Shift/Timing Solenoid Range/Performance
P0787
Shift/Timing Solenoid Low
P0788
Shift/Timing Solenoid High
P0789
Shift/Timing Solenoid Interm ittent
P0790
Normal/Performance Switch Circuit
P0791
Intermediate Shaft Speed Sensor A C ircuit
P0792
Range/Performance
P0793
No Signal
P0794
Intermittent
P0795
Pressure Control Solenoid "C"
P0796
Pressure Control Solenoid "C" Performance
or Stuck off
P0797
Pressure Control Solenoid "C" Stuck On
P0798
Pressure Control Solenoid "C" Electrical
P0799
Pressure Control Solenoid "C" Intermittent
P0800
Transfer Case Control System (MIL
Request)
P0801
Reverse Inhibit Control Circuit
P0802
Transmission Control System M IL Request
Circuit/Open
P0803
1-4 Upshift (Skip Shift) Solenoid Control
Circuit
P0804
1-4 Upshift (Skip Shift) Lam p Control Circuit
P0805
Clutch Position Sensor Circuit
P0806
Range/Performance
P0807
Clutch Position Sensor Circuit Low
P0808
Clutch Position Sensor Circuit High
P0809
Clutch Position Sensor Circuit Intermittent
P0810
Clutch Position Control Error
P0811
Excessive Clutch Slippage
P0812
Reverse Input C ircuit
P0813
Reverse Output Circuit
P0814
Transmission Range D isplay C ircuit
P0815
Upshift Switch C ircuit
P0816
Downshift Switch C ircuit
P0817
Starter Disable Circuit
P0818
Driveline D isconnect Switch Input C ircuit
P0819
Up and Down Shift Switch to Transmission
Range Correlation
P0820
Gear Lever X-Y Position Sensor Circuit
P0821
Gear Lever X Position Circuit
P0822
Gear Lever Y Position Circuit
P0823
Gear Lever X Position Circuit Intermittent
P0824
Gear Lever Y Position Circuit Intermittent
P0825
Gear Lever Push-Pull Switch (Shift
Anticipate)
P0826
Up and Down Shift Switch C ircuit
P0827
Up and Down Shift Switch C ircuit Low
P0828
Up and Down Shift Switch C ircuit High
P0829
5-6 Shift
P0830
Clutch Pedal Switch "A" Circuit
P0831
Clutch Pedal Switch "A" Circuit Low
P0832
Clutch Pedal Switch "A" Circuit H igh
P0833
Clutch Pedal Switch "B" Circuit
P0834
Clutch Pedal Switch "B" Circuit Low
P0835
Clutch Pedal Switch "B" Circuit H igh
P0836
Four W heel D rive (4WD) Switch C ircuit
P0837
Range/Performance
P0838
Four W heel Drive (4WD) Switch Circuit Low
P0839
Four W heel Drive (4WD) Switch Circuit High
P0840
Transmission Fluid Pressure Sensor/Switch
"A" C ircuit
P0841
"A" Circuit Range/Performance
P0842
"A" C ircuit Low
P0843
"A" C ircuit High
P0844
"A" C ircuit Interm ittent
P0845
"B" C ircuit
P0846
"B" Circuit Range/Performance
P0847
"B" C ircuit Low
P0848
"B" C ircuit High
P0849
"B" C ircuit Interm ittent
P0850
Park/Neutral Switch Input Circuit
P0851
Park/Neutral Switch Input Circuit Low
P0852
Park/Neutral Switch Input Circuit H igh
P0853
Drive Switch Input Circuit
P0854
Drive Switch Input C ircuit Low
P0855
Drive Switch Input Circuit High
P0856
Traction Control Input Signal
P0857
Range/Performance
P0858
Traction Control Input Signal Low
P0859
Traction Control Input Signal High
P0860
Gear Shift Module Communication Circuit
P0861
Low
P0862
High
P0863
TCM Communication Circuit
P0864
Range/Performance
P0865
TCM Communication Circuit Low
P0866
TCM Communication Circuit High
P0867
P0868
Transmission Fluid Pressure Low
P0869
Transmission Fluid Pressure High
P0870
C C ircuit
P0871
C Circuit Range/Performance
P0872
C Circuit Low
P0873
C C ircuit H igh
P0874
C Circuit Interm ittent
P0875
D C ircuit
P0876
D Circuit Range/Performance
P0877
D Circuit Low
P0878
D C ircuit H igh
P0879
D C ircuit Intermittent
P0880
TCM Power Input Signal
P0881
Range/Performance
P0882
TCM Power Input Signal Low
P0883
TCM Power Input Signal High
P0884
TCM Power Input Signal Interm ittent
P0885
TCM Power Relay Control Circuit/Open
P0886
TCM Power Relay Control Circuit Low
P0887
TCM Power Relay Control Circuit High
P0888
TCM Power Relay Sense Circuit
P0889
Range/Performance
P0890
TCM Power Relay Sense Circuit Low
P0891
TCM Power Relay Sense Circuit High
P0892
TCM Power Relay Sense C ircuit Intermittent
P0893
Multiple Gears Engaged
P0894
Transmission Component Slipping
P0895
Shift Time Too Short
P0896
Shift Time Too Long
P0897
Transmission Fluid Deteriorated
P0898
Circuit Low
P0899
Transmission C ontrol System M IL Request
Circuit H igh
P0900
Clutch Actuator Circuit/Open
P0901
Clutch Actuator Circuit Range/Performance
P0902
Clutch Actuator Circuit Low
P0903
Clutch Actuator Circuit High
P0904
Gate Select Position Circuit
P0905
Range/Performance
P0906
Gate Select Position Circuit Low
P0907
Gate Select Position Circuit H igh
P0908
Gate Select Position Circuit Interm ittent
P0909
Gate Select C ontrol Error
P0910
Gate Select Actuator Circuit/Open
P0911
Range/Performance
P0912
Gate Select Actuator Circuit Low
P0913
Gate Select Actuator Circuit H igh
P0914
Gear Shift Position C ircuit
P0915
Range/Performance
P0916
Gear Shift Position Circuit Low
P0917
Gear Shift Position Circuit High
P0918
Gear Shift Position C ircuit Intermittent
P0919
Gear Shift Position Control Error
P0920
Gear Shift Forward Actuator Circuit/Open
P0921
Range/Performance
P0922
Gear Shift Forward Actuator Circuit Low
P0923
Gear Shift Forward Actuator Circuit High
P0924
Gear Shift Reverse Actuator Circuit/Open
P0925
Range/Performance
P0926
Gear Shift Reverse Actuator Circuit Low
P0927
Gear Shift Reverse Actuator Circuit High
P0928
Gear Shift Lock Solenoid Control
Circuit/Open
P0929
Gear Shift Lock Solenoid Control Circuit
Range/Performance
P0930
Gear Shift Lock Solenoid C ontrol Circuit Low
P0931
High
P0932
Hydraulic Pressure Sensor Circuit
P0933
Range/Performance
P0934
Hydraulic Pressure Sensor Circuit Low
P0935
Hydraulic Pressure Sensor Circuit High
P0936
Intermittent
P0937
Hydraulic O il Temperature Sensor Circuit
P0938
Range/Performance
P0939
Low
P0940
High
P0941
Intermittent
P0942
Hydraulic Pressure Unit
P0943
Hydraulic Pressure U nit C ycling Period Too
Short
P0944
Hydraulic Pressure Unit Loss of Pressure
P0945
Hydraulic Pump Relay C ircuit/Open
P0946
Range/Performance
P0947
Hydraulic Pump Relay C ircuit Low
P0948
Hydraulic Pump Relay C ircuit High
P0949
Auto Shift Manual Adaptive Learning Not
Complete
P0950
Auto Shift M anual Control Circuit
P0951
Range/Performance
P0952
Auto Shift M anual Control Circuit Low
P0953
Auto Shift M anual Control Circuit H igh
P0954
Auto Shift M anual Control Circuit Intermittent
P0955
Auto Shift M anual M ode Circuit
P0956
Range/Performance
P0957
Auto Shift Manual Mode Circuit Low
P0958
Auto Shift Manual Mode Circuit High
P0959
Auto Shift Manual Mode Circuit Interm ittent
P0960
Pressure Control Solenoid "A" Control
Circuit/Open
P0961
P0962
Circuit Low
P0963
Circuit H igh
P0964
Pressure Control Solenoid "B" Control
Circuit/Open
P0965
P0966
Circuit Low
P0967
Circuit High
P0968
Pressure Control Solenoid "C" Control
Circuit/Open
P0969
P0970
Circuit Low
P0971
Circuit High
P0972
Shift Solenoid "A" Control Circuit
Range/Performance
P0973
Shift Solenoid "A" Control Circuit Low
P0974
Shift Solenoid "A" Control Circuit High
P0975
Shift Solenoid "B" Control Circuit
Range/Performance
P0976
Shift Solenoid "B" Control Circuit Low
P0977
Shift Solenoid "B" Control Circuit High
P0978
Shift Solenoid "C" C ontrol Circuit
Range/Performance
P0979
Shift Solenoid "C" C ontrol Circuit Low
P0980
Shift Solenoid "C" C ontrol Circuit H igh
P0981
Shift Solenoid "D" C ontrol Circuit
Range/Performance
P0982
Shift Solenoid "D" C ontrol Circuit Low
P0983
Shift Solenoid "D" C ontrol Circuit H igh
P0984
Shift Solenoid "E" Control C ircuit
Range/Performance
P0985
Shift Solenoid "E" Control Circuit Low
P0986
Shift Solenoid "E" Control Circuit High
P0987
"E" C ircuit
P0988
"E" Circuit Range/Performance
P0989
"E" C ircuit Low
P0990
"E" C ircuit High
P0991
"E" C ircuit Interm ittent
P0992
"F" C ircuit
P0993
"F" Circuit Range/Performance
P0994
"F" C ircuit Low
P0995
"F" C ircuit High
P0996
"F" C ircuit Interm ittent
P0997
Shift Solenoid "F" Control Circuit
Range/Performance
P0998
Shift Solenoid "F" Control Circuit Low
P0A00
Motor Electronics Coolant Temperature
Sensor Circuit
P0A01
Sensor Circuit Range/Performance
P0A02
Sensor Circuit Low
P0A03
Sensor Circuit High
P0A04
P0A05
Motor Electronics Coolant Pump Control
Circuit/Open
P0A06
Circuit Low
P0A07
Circuit High
P0A08
DC/DC Converter S tatus C ircuit
P0A09
DC/DC Converter Status Circuit Low Input
P0A10
DC/DC Converter Status Circuit High Input
P0A11
DC/DC Converter Enable Circuit/Open
P0A12
DC/DC Converter Enable Circuit Low
P0A13
DC/DC Converter Enable Circuit High
P0A14
Engine M ount Control Circuit/Open
P0A15
Engine M ount Control Circuit Low
P0A16
Engine M ount Control Circuit High
P0A17
Motor Torque Sensor Circuit
P0A18
Range/Performance
P0A19
Motor Torque Sensor Circuit Low
P0A20
Motor Torque Sensor Circuit High
P0A21
Motor Torque Sensor Circuit Intermittent
P0A22
Generator Torque Sensor Circuit
P0A23
Range/Performance
P0A24
Generator Torque Sensor Circuit Low
P0A25
Generator Torque Sensor Circuit High
P0A26
Generator Torque Sensor Circuit Intermittent
P0A27
Battery Power Off C ircuit
P0A28
Battery Power Off Circuit Low
P0A29
Battery Power Off Circuit H igh
P2000
NOx Trap Efficiency Below Threshold (Bank
1)
P2001
2)
P2002
Particulate Trap Efficiency Below Threshold
(Bank 1)
P2003
(Bank 2)
P2004
Intake M anifold Runner Control Stuck O pen
(Bank 1)
P2005
Intake Manifold Runner Control Stuck Open
(Bank 2)
P2006
Closed (Bank 1)
P2007
Closed (Bank 2)
P2008
Intake M anifold Runner C ontrol Circuit/Open
(Bank 1)
P2009
Intake Manifold Runner Control Circuit Low
(Bank 1)
P2010
Intake Manifold Runner Control Circuit High
(Bank 1)
P2011
Intake M anifold Runner Control Circuit/Open
(Bank 2)
P2012
(Bank 2)
P2013
(Bank 2)
P2014
Intake Manifold Runner Position
Sensor/Switch Circuit (Bank 1)
P2015
Sensor/Switch Circuit Range/Performance
(Bank 1)
P2016
Sensor/Switch Circuit Low (Bank 1)
P2017
Sensor/Switch Circuit High (Bank 1)
P2018
Sensor/Switch Circuit Intermittent (Bank 1)
P2019
Sensor/Switch Circuit (Bank 2)
P2020
(Bank 2)
P2021
Sensor/Switch Circuit Low (Bank 2)
P2022
Sensor/Switch Circuit High (Bank 2)
P2023
Sensor/Switch Circuit Intermittent (Bank 2)
P2024
Evaporative Emissions (EVAP) Fuel Vapor
P2025
Temperature Sensor Performance
P2026
Temperature Sensor Circuit Low Voltage
P2027
Temperature Sensor Circuit High Voltage
P2028
Temperature Sensor Circuit Intermittent
P2029
Fuel Fired Heater Disabled
P2030
Fuel Fired Heater Performance
P2031
(Bank 1 Sensor 2)
P2032
Low (Bank 1 Sensor 2)
P2033
High (Bank 1 Sensor 2)
P2034
(Bank 2 Sensor 2)
P2035
Low (Bank 2 Sensor 2)
P2036
High (Bank 2 Sensor 2)
P2037
Reductant Injection Air Pressure Sensor
Circuit
P2038
P2039
Circuit Low Input
P2040
Circuit High Input
P2041
P2042
Reductant Temperature Sensor Circuit
P2043
Range/Performance
P2044
Reductant Temperature Sensor Circuit Low
Input
P2045
Reductant Temperature Sensor Circuit High
Input
P2046
Intermittent
P2047
Reductant Injector Circuit/Open (Bank 1
Unit 1)
P2048
Reductant Injector C ircuit Low (Bank 1 Unit
1)
P2049
Reductant Injector Circuit High (Bank 1 Unit
1)
P2050
Reductant Injector Circuit/Open (Bank 2
Unit 1)
P2051
Reductant Injector C ircuit Low (Bank 2 Unit
1)
P2052
Reductant Injector Circuit High (Bank 2 Unit
1)
P2053
Unit 2)
P2054
2)
P2055
2)
P2056
Unit 2)
P2057
2)
P2058
2)
P2059
Reductant Injection Air Pump Control
Circuit/Open
P2060
Reductant Injection A ir Pump Control C ircuit
Low
P2061
High
P2062
Reductant Supply Control Circuit/Open
P2063
Reductant Supply Control Circuit Low
P2064
Reductant Supply Control Circuit High
P2065
Fuel Level Sensor "B" Circuit
P2066
Fuel Level Sensor "B" Performance
P2067
Fuel Level Sensor "B" Circuit Low
P2068
Fuel Level Sensor "B" Circuit High
P2069
Fuel Level Sensor "B" Circuit Intermittent
P2070
Intake Manifold Tuning (IMT) Valve Stuck
Open
P2071
Closed
P2075
Intake Manifold Tuning (IMT) Valve Position
P2076
P2077
P2078
P2079
Sensor/Switch C ircuit Intermittent
P2080
Range/Performance (Bank 1 Sensor 1)
P2081
Intermittent (Bank 1 Sensor 1)
P2082
Range/Performance (Bank 2 Sensor 1)
P2083
Intermittent (Bank 2 Sensor 1)
P2084
Range/Performance (Bank 1 Sensor 2)
P2085
Intermittent (Bank 1 Sensor 2)
P2086
Range/Performance (Bank 2 Sensor 2)
P2087
Intermittent (Bank 2 Sensor 2)
P2088
A Camshaft Position Actuator Control Circuit
Low (Bank 1)
P2089
High (Bank 1)
P2090
B Camshaft Position Actuator Control Circuit
Low (Bank 1)
P2091
High (Bank 1)
P2092
Low (Bank 2)
P2093
High (Bank 2)
P2094
Low (Bank 2)
P2095
High (Bank 2)
P2096
Post Catalyst Fuel Trim System Too Lean
(Bank 1)
P2097
Post Catalyst Fuel Trim System Too Rich
(Bank 1)
P2098
(Bank 2)
P2099
(Bank 2)
P2100
Throttle Actuator Control M otor C ircuit/Open
P2101
Range/Performance
P2102
Throttle Actuator Control M otor C ircuit Low
P2103
Throttle Actuator Control M otor C ircuit High
P2104
Throttle Actuator Control System - Forced
Idle
P2105
Engine Shutdown
P2106
Limited Power
P2107
Throttle Actuator Control M odule Processor
P2108
Performance
P2109
Throttle/Pedal Position Sensor "A" M inimum
Stop Performance
P2110
Limited RPM
P2111
Throttle Actuator Control System - Stuck
Open
P2112
Closed
P2113
Throttle/Pedal Position Sensor "B" Minimum
Stop Performance
P2114
Throttle/Pedal Position Sensor "C" M inimum
Stop Performance
P2115
Throttle/Pedal Position Sensor "D" M inimum
Stop Performance
P2116
Throttle/Pedal Position Sensor "E" Minimum
Stop Performance
P2117
Throttle/Pedal Position Sensor "F" Minimum
Stop Performance
P2118
Throttle Actuator Control Motor Current
Range/Performance
P2119
Throttle Actuator Control Throttle Body
Range/Performance
P2120
Throttle/Pedal Position Sensor/Switch "D"
Circuit
P2121
P2122
Circuit Low Input
P2123
Circuit High Input
P2124
P2125
Throttle/Pedal Position Sensor/Switch "E"
Circuit
P2126
P2127
Circuit Low Input
P2128
Circuit High Input
P2129
P2130
Throttle/Pedal Position Sensor/Switch F
Circuit
P2131
Circuit Range Performance
P2132
Circuit Low Input
P2133
Circuit High Input
P2134
P2135
Throttle/Pedal Position Sensor/Switch A /
B Voltage Correlation
P2136
C Voltage Correlation
P2137
Throttle/Pedal Position Sensor/Switch B /
P2138
Throttle/Pedal Position Sensor/Switch D /
E Voltage Correlation
P2139
F Voltage Correlation
P2140
Throttle/Pedal Position Sensor/Switch E /
P2141
Exhaust Gas Recirculation Throttle Control
Circuit Low
P2142
Circuit High
P2143
Exhaust Gas Recirculation Vent Control
Circuit/Open
P2144
Circuit Low
P2145
Circuit High
P2146
Fuel Injector G roup A Supply Voltage
Circuit/Open
P2147
Circuit Low
P2148
Circuit H igh
P2149
Fuel Injector G roup B Supply Voltage
Circuit/Open
P2150
Circuit Low
P2151
Circuit H igh
P2152
Fuel Injector G roup C Supply Voltage
Circuit/Open
P2153
Circuit Low
P2154
Circuit H igh
P2155
Fuel Injector G roup D Supply Voltage
Circuit/Open
P2156
Circuit Low
P2157
Circuit H igh
P2158
Vehicle Speed Sensor B
P2159
Range/Performance
P2160
Vehicle Speed Sensor B Circuit Low
P2161
Vehicle Speed Sensor B Interm ittent/Erratic
P2162
Vehicle Speed Sensor A / B Correlation
P2163
Throttle/Pedal Position Sensor A M aximum
Stop Performance
P2164
Throttle/Pedal Position Sensor B M aximum
Stop Performance
P2165
Throttle/Pedal Position Sensor C M aximum
Stop Performance
P2166
Throttle/Pedal Position Sensor D M aximum
Stop Performance
P2167
Throttle/Pedal Position Sensor E M aximum
Stop Performance
P2168
Throttle/Pedal Position Sensor F Maximum
Stop Performance
P2169
Exhaust Pressure Regulator Vent Solenoid
P2170
P2171
P2172
Throttle Actuator Control System Sudden
High Airflow Detected
P2173
Throttle Actuator Control System High
Airflow Detected
P2174
Low Airflow Detected
P2175
Throttle Actuator Control System Low
Airflow Detected
P2176
Throttle Actuator Control System Idle
Position Not Learned
P2177
System Too Lean O ff Idle (Bank 1)
P2178
System
Fredje987
110 km
al 18 jaar lid
Dank voor je bijdrage !
Niet gevonden wat je zocht? Misschien is je vraag al eens beantwoord voor je BMW Overig of stel zelf een nieuwe vraag.
