FORD TRANSIT 2.0 TDCI 2003 OM STAPEL GEK VAN TE WORDEN .
BESTE MENSEN MIJN NAAM IS HARRIE
EN IK BEN EEN JAAR GELEDEN VOOR MEZELF GAAN WERKEN ALS ZZPER TIMMERWERKEN.
EN DUS EEN 2EHANDS BUS GEKOCHT,EEN FORD TRANSIT 2.0 TDCI 125 PK UIT 2003 137500 OP DE TELLER , MET 5 ZIT PLAATSEN .
WAS APPE TROTS MET ME BUSJE.
MAAR DIT WAS VAN KORT DUUR .!!!!!!
OP HET KENTEKEN STONDEN GEEN ZIT PLAATSEN DUS GING IK NA 2 WEKEN TOCH IS KIJKEN OP DE SITE VAN DE RDW , EN WAAREMPEL HET WAS MAAR EEN 2 ZITTER .
DE BANK ACHTERIN MOCHT ER NIET EENS IN STAAN .
DIT PROBLEEM WAS OP TE LOSSEN DOOR EEN DC WAND TE PLAATSEN EN WAT ANDERE AANPASSINGEN ,DIT HEEFT ME xx EURIE GEKOST MAAR WAS MISSCHIEN BEETJE ME EIGEN SCHULD.
2011 OP VAKANTIE NAAR KROATIE ,
NOG SNEL EVEN EEN BEURTJE LATEN DOEN WANT JA JE WEET MAAR NOOIT ,EN HOOR DE EEN FLUITJE ONDER HET RIJDEN .
DAT BLEEK EEN POELIE TE ZIJN MET EEN PAAR RIEMEN ,NA VERVANGING GELUID WEG ,PRIMA DUS TOTAAL xx EURIE .
DUS LEKKER OP VAKANTIE MET DE CARAVAN ,GEWICHT 1500 KG MAX GELADEN .
HEEN WEG GEEN CENTJE PIJN .
PRIMA VAKANTIE GEHAD .
TOEN WEER TERUG NAAR HUIS .
NA 265 KM GING HET GLOEI SPIRAAL BRANDEN EN IN NOOD LOOP ,WIST NIET WAT ME OVERKWAM.
2 KINDEREN ACHTERIN DE BUS EN EEN VROUW IN PANIEK .
BUS OP DE VLUCHTSTROOK GEZET ,EN JA DENK ZET HEM WEL UIT .
NA 5 MIN WEER GESTART EN HIJ WAS WEER OKE ,RIJEN DACHT IK .
NA EEN KM OF 500 WEER HET ZELFDE RITUEEL ,TOCH MAAR EVEN GARAGE GEBELD , EN WE KONDEN DOORRIJDEN WANT ER WERDT NIKS HEET EN GEEN OVERMATE ROOK OF ZO IETS .
NA ONGEVEER 800 KM BERGOP KREEG DE BUS WEER KUUREN BUS GING WEER IN NOODLOOP EN DE TEMPERATUUR METER BEGON TE ZWAAIEN IN HET WILD KOUD HEET KOUD ENZ .
BUS AAN DE KANT GEZET 10 MIN .
DAARNA BUS WEER GESTART EN MAAR WEER PROBEREN TE RIJDEN DIT ING GOED TOT DAT WE NOG 100KM MOESTEN RIJDEN ,MAAR WEER OP DE VLUCHTSTROOK EN WEER STARTEN .
2 DAGEN NA TERUGKOMST NAAR DE GARAGE GEGAAN , 1.STORING VAN HET GASPENDAAL 2. EN EEN TE LAGE RAILDRUK.
GASPENDAAL LATEN VERVANGEN EN DAT WAS DAT WEER xx,=EURO .
2 WEKEN ER NA GING DIE IN NOODLOOP ZONDER CARAVAN ,DIT VOND IK WEL HEEL RAAR .
WEER TERUG NAAR DE GARAGE ,STORING BRANDSTOF DRUKVENTIEL , DUS VENTIEL LATEN VERVANGEN ,KOSTEN 300 EURIE .
WEER 3 WEKEN VERDER GING IE WEER IN NOODLOOP.
HET WAS TOCH OPGELOST ????? DACHT IK .
WEDEROM NAAR DE GARAGE MET ME 10 RITTEN KAART .
UITLATEN LEZEN EN ER WERD ME GEADVISEERD OM MIJN VERSTUIVERS TOCH EENS TE LATEN TESTEN .
HUP IK NAAR EEN REVIESIE BEDRIJF VOOR MOTOREN EN VERSTUIVERS . KOSTEN xx,=
DAAR BLEEK DAT ER 2 VERSTUIVERS VER HEEN WAREN EN NIET MEER VOLDEDEN .
TOCH MAAR ALLE 4 DE VERSTUIVERS LATEN VERVANGEN DOOR GEREVISEERDE VAN DIESEL BUCHLI.
KOSTEN xx,=
TUSSEN DOOR NOG WAT SLIJTAGE ONDERDELEN LATEN VERVANGEN ,WAT BIJ ONDERHOUD HOORT. KOSTEN +/- xx.
HALF JAAR NIKS AAN DE HAND ,ALS EEN RAAR BIJ GELUIDJE TUSSEN DE 2500 TOEREN EN DE 3200 TOEREN HIER NA GELUID WEG .
BIJ EEN GROTE BEURT KM ST 155000 TOCH EENS GEVRAGEN WAT HET GELUID ZOU KUNNE ZIJN .
TERUG NAAR DE FORD .
WEER ADVISEERDE MIJN GARAGE DAT HET TOCH WEL LEEK OP EEN VERSTUIVER KWESTIE .
EN HAD 1 JAAR GARANTIE ,DUS WEER TERUG NAAR DE VERSTUIVER MAN .
ALLE VERSTUIVERS GETEST EN BLEKEN ALLEMAAL GOED TE ZIJN ,ALEEN BRAK ER WEL EEN KOPPELINGETJE AF BIJ DEMONTAGE ,KOSTEN xx,-
JA WAS AL OUD EN DIE DINGEN GEBEUREN . ???? JA HET ZAL WEL.
HET PROBLEEM WAS DUS NOG NIET OPGELOST , MAAR DE VERSTUIVERS DAT ZAT WEL GOED .
VOOR MIJN GEVOEL MOEST IK NAAR DE FORD DEALER ,EN DAAR EENS LATEN KIJKEN .
EEN AFSPRAAK GEMAAKT , EN EEN LEERAAR VAN DE FORD OPLEIDING ZOU MEE RIJDEN ,HIJ WAS DE SPECIALIST .
NOU EEN UUR ROND GEREDEN ,EN AAN DE COMPUTTER GEHANGEN .
ER WAS NIKS AAN DE HAND GEEN STORINGEN EN HET KWAM ER OP NEER DAT IK EEN PIET LEUT WAS ,KOSTEN xx EURO .
IK BEGON EEN BEETJE AAN ME ZELF TE TWIJFELEN .
PAAR MAANDEN VERDER NIKS APARTS MEER AAN DE HAND.
ALS HET RARE BIJ GELUID ,DAT NA ONDERZOEK UIT DE BAK SCHIJNT TE KOMEN ,MASSA VLIEGWIEL ,KOPPELING ENZ ZAL NA DE VAKANTIE TOCH EEN KEER VERVANGEN MOETEN WORDEN
MAAR HIERDOOR VAL JE NIET STIL WERDT ME GEZEGT .
HEB ER EEN POWERBOX OP GEZET EN DAAR KNAPTE DE BUS WEL VAN OP .
INTERCOOLER ZELF LEK GEREDEN (HAAST EN DREMPELS )
INTERCOOLER VEVANGEN DOOR EEN GROTERE INTERCOOLER ,VOOR MEER KOELING IVM VAKANTIES EN BERGEN .
2012 NAAR ITALIE
1268 KM HEEN ZONDER PROBLEMEN HAD VOLDOENDE VERMOGEN .
2 WEKEN VAKANTIE ,ZEER GOED.
WEER NAAR HUIS
TOT 6 KEER OP DE VLUCHTSTROOK IN DE NOODLOOP .
HAD WEL VOLDOENDE VERMOGEN MAAR BERG OP WERDT HET TOCH TE VEEL .
HEB DE HELE VAKANTIE NIET 100 METER IN DE 5E VERSNELLING GEREDEN .,UIT VOOR ZORG .
NU 2 WEKEN VERDER BIJ GELUID IS NIET ERGER GEWORDEN ,MAR
KRIJG IK SOMS LAST VAN SLECHT STARTEN DE EERSTE KEER.
HIJ START LANGZAAM TOT 700 TOEREN EN SLAAT AF .
DE 2 E KEER START HIJ WEL GOED????????
HAD DEZE BUS NOOIT MOETEN KOPEN ,MAAR ER ZIT AL ZOVEEL ZUUR VERDIEND GELD INGEPOMT ,
DAT IK HEM ER NIET GRAAG MEER UIT DOE .
WIE KAN ME HELPEN ??????????
OF WEET MISSCHIEN WAT ER AAN DE HAND IS.
HOOR HET HEEL GRAAG
Niet gevonden wat je zocht? Misschien is je vraag al eens beantwoord voor je Ford Transit of stel zelf een nieuwe vraag.
Volgende keer graag de Caps Lock uitzetten.
