BESTE MENSEN,M
MIJN MONDEO 18 TD LEVERD NIET VOLDOENDE VERMOGEN.
BIJ DE FORD GARAGE LATEN UITLEZEN, GEEN FOUTCODE'S
IK HEB AL DE FILTERS VERNIEUWD, HET PIJPJE TUSSEN DE TURBO EN DE BRANDSTOFPOMP INCLUSIEF SLANGETJES (SLANGETJE WAS LEK), HET MEMBRAAM VERVANGEN WAAR DAT SLANGETJE AANVAST ZAT, DIT WAS LEK.
lATER BIJ NAVRAAG DIESEL BUCHLI BLEEK DIT MEMBRAAM NIETS MET MINIMUM EN MAXIMUM VERMOGEN TE MAKEN TE HEBBEN ALLEEN MET DE MANIER VAN ACCELEREREN. IK HEB HEM OP DE GOK INGESTELD MET WEINIG VEERDRUK.
HIJ REED HET ZELFDE MET DE KATALYSATOR VOLDOENDE LOS, MAAR HEB DE KATALYSATOR OM ZEKER TE ZIJN, LEEG GEHAALD.
DE FITZKLEP TIKT ZOALS HIJ HET ALTIJD HEEFT GEDAAN.
IK DENK NIET DAT DE BRANDSTOFPOMP VAN TIJD AF STAAT
OPVOERPOMPJE BIJ BRSTOFFILTER IS NOG NIET ZO OUD, GLOEIKAARSJES ZIJN NOG NIET ZO OUD, DISTRIBUTIE 20000KMR GELEDEN COMPLEET GEDAAN
HET IS EIGENLIJK ZONDER AANWIJSBARE REDEN ONTSTAAN
HEEFT IEMAND EEN IDEE.
