IK ZIT MET EEN GROOT PROBLEEM.
WIJ HEBBEN EEN FOCUS 2.0 UIT 1999 DIE HOOG CQ 1800 TOEREN LOOP BIJ EEN SNELHEID VAN 15 KM/H EN ALS JE DAN STOPT GAAT HET TOERENTAL NAAR 2200 TOEREN SOMS IS HET ZO ERG DAT HIJ 3000 TOEREN DRAAIT.
HET VOLGENDE VERVANGEN (OMGEZET) TOERENTAL SENSOR,MAF SENSOR, GASKLEP POS SENSOR,LUCHT OMLOOP KLEP, GEEN FOUTCODES, IS AL BIJ DE DAELER GEWEEST DAAR NIEUWE SOFTWARE GECONTROLEERD.
GRAAG HULP.
BIJ VOORBAAT DANK.
