Zet de wagen op contact.
Binnen 10 sec.
Druk de knop in bij de toerenteller en houd ingedrukt +/- 3 sec.
De serviceindicator knippert.
Druk herhaaldelijk op de knop om de resterende afstand tot de volgende onderhoudsbeurt (1000 - 63000) in te stellen.
Laat de knop los.
Wacht ten minste 5 sec. en zet de wagen van contact af.
Setting Procedure
The distance can be changed manually.
1. Ignition switch ON.
2. By pressing and holding the clock switch (clock switch is RH switch in meter) about 3 seconds while the
maintenance distance and wrench symbol are displayed (about 5 seconds after turning on the ignition).
3. It comes to setting mode. The maintenance distance and wrench symbol will flash.
4. While these are flashing, press the clock switch to display the current maintenance distance.
5. Press the clock switch again to increase the setting distance by 500 miles(1000km) increments.
6. The maximum setting is 31,500 miles(63000 km). Pressing the clock switch one more time after this will
return the setting to 0.
7. When the setting procedure is complete, do not touch the switch for 5 seconds (until odo meter: ON,
wrench symbol: OFF).
Binnen 10 sec.
Laat de knop los.
Suc6 Gr. Harry
