WIELLAGER GILT EROP LOS, MOET VERVANGEN. SCHIJVEN NOG WEL OKE MAAR WEL INGESLETEN. REMBLOKKEN MOETEN UITELKAAR, MAAR MET DE HAND ONMOGELIJK. OP REMKLAUW ZIT 5-KANTBOUT (ALLEEN SPECIALE MET DOP TE BEREIKEN)WELKE DENK IK DE ZUIGERS NAAR BINNEN TREKT. IS DIE DOP OVERAL TE KOOP (KOST IE) EN HOE KAN WEET JE WELKE LAGER KAPOT IS (IS BINNEN NIET TE HOREN)
WAAR KAN IK ONLINE ONDERDELEN KOPEN
IS HET EENVOUDIG DE VOORWIEL STABILISATORSTANGETJES (RECHTOPSTAANDE) TE VERVANGEN?
KAN IK MIJN ASTRA UITRUSTEN MET CRUISECONTROL(LIGT DIE KABEL ER AL)
HANS
