Wie weet wat deze foutcode's betekenen?
VAG-COM Version: Release 311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 AP
Component: 1,9l R4 EDC G000SG 2807
Coding: 00002
Shop #: WSC 00046
1 Fault Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-00 - -
Readiness: N/A
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 00046
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal to Low - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 825 B
Component: KOMBI+WEGFAHRS. BOO V01
Coding: 03112
Shop #: WSC 00046
Ident.-Nr. WEGFAHRS.:VWZ6Z0Y2027425
No fault code found.
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00046
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 4E Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00046
3 Faults Found:
01389 - Tailgate Open Switch (F124)
29-10 - Short to Ground - Intermittent
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
- Wat Dutch al zei: De Climatronic heeft een keer te weinig stroom gehad (af en toe)
- De schakelaar van je achterklep maakt af en toe kortsluiting en je beide verwarmde spiegels zijn stuk.
Groet,
Guido Priemus
