Hyundai Coupe: motor 2.0i
Bouwjaar: 1998, Brandstof: LPG, Motorcode: 2.0i
Goedemorgen medeforumgebruikers. Ik heb een Hyundai Coupe 2.0i Fx uit 1998. De motor die in deze auto zit,is die ook geleverd in een andere Hyundai ? Graag een reactie. Gr.Van Henk.
henkie4437
730 km
Ja , in de Lantra.
Hans4040 123.030 km Reageer
Het volgende nog even :
Applies to: Elantra 1998-2000 and Tiburon 2000 ( De Tiburon is in Europa de Coupe)
Engine Mechanical System General
SPECIFICATIONS
General
Description Specification
Type
In-line, Double Over Head Camshaft
Number of cylinders
4
Bore
82 mm (3.228 in.)
Stroke
85 mm (3.346 in.)
Total displacement
1795 CC (109.54 cu.in.)
Compression ratio
10.0
Firing order
1-3-4-2
Idle R.P.M
800± 100
Ignition timing at idling speed
BTDC 10°±5°/800 rpm
Cylinder block
Cylinder bore
82.00-82.03 mm (3.2283-3.2295 in.)
Out-of-roundness and taper of cylinder bore
Less than 0.01 mm (0.0004 in.)
Clearance with piston
0.02- 0.04 mm (0.0008- 0.0016 in.)
Piston
O.D.
81.97-82.00 mm (3.2271-3.2283 in.)
Service size
0.25, 0.50, 0.75, 1.00 mm (0.010, 0.020, 0.030, 0.039 in.) oversize
Piston ring
Description Specification Limit
Side clearance: No. 1
0.04-0.085 mm (0.0015-0.0031 in.)
1 mm (0.004 in.)
Side clearance: No. 2
0.03-0.07 mm (0.0012-0.0027 in.)
1 mm (0.004 in.)
End gap: No. 1
0.23-0.38 mm (0.0090-0.0149 in.)
1 mm (0.0394 in.)
End gap: No. 2
0.45-0.60 mm (0.0177-0.0236 in.)
1 mm (0.0394 in.)
End gap: Oil ring side rail
0.20-0.60 mm (0.0078- No. 20.0236 in.)
1 mm (0.0394 in.)
Service size
Connecting rod
Bend
0.05 mm (0.0020 in.) or less
Twist
0.1 mm (0.004 in.) or less
Connecting rod big end to crankshaft side clearance
0.100-0.250 mm (0.0039-0.0098 in.)
0.4 mm (0.0157 in.)
Connecting rod bearing
Oil clearance
0.024-0.044 mm (0.0009-0.0017 in.)
Undersize
0.25 mm, 0.50 mm, 0.75 mm (0.01 in., 0.02 in., 0.03 in.)
Camshaft
Description
Specification
Limit
Cam height: Intake
44.449 mm (1.7499 in.)
43.349 mm (1.7460 in.)
Cam height: Exhaust
45.049 mm (1.7736 in.)
44.949 mm (1.7696 in.)
Journal O.D.
28 mm (1.1023 in.)
Bearing oil clearance
0-0.025 mm (0-0.0009 in.)
End play
0.1-0.2 mm (0.004-0.008 in.)
Crankshaft
Pin O.D.
45 mm (1.77 in.)
Journal O.D.
57 mm (2.244 in.)
Bend
0.03 mm (0.0012) or less
Out-of-roundness, taper of journal and pin
0.01 mm (0.0004 in.) or less
End play
0.06-0.260 mm (0.0023-0.010 in.)
Undersize rework dimension of pin: 0.25 mm (0.010 in.)
44.725- 44.740 mm (1.7608- 1.7614 in.)
Undersize rework dimension of pin: 0.50 mm (0.020 in.)
44.475- 44.490 mm (1.7509- 1.7516 in.)
Undersize rework dimension of pin: 0.75 mm (0.030 in.)
44.225- 44.240 mm (1.7411- 1.7417 in.)
Undersize rework dimension of journal: 0.25 mm (0.010 in.)
56.727-56.742 mm (2.2333-2.2339 in.)
Undersize rework dimension of journal: 0.50 mm (0.020 in.)
56.477-56.492 mm (2.2235-2.2240 in.)
Undersize rework dimension of journal: 0.75 mm (0.030 in.)
56.227-56.242 mm (2.2136-2.2142 in.)
Flywheel
Runout
0.1 mm (0.0039 in.)
0.13 mm (0.0051 in.)
Cooling method
Cooling method
Water-cooled, Pressurized, Forced circulation with electrical fan
Coolant
Item Specification Specification
Coolant
Quantity
6 lit (6.3 U.S. qts., 5.2 Imp. qts.)
Radiator
Radiator
Type
Pressurized corrugated fin type
Performance
43,250 Kcal/h
Radiator Cap
Item Description Specification
Radiator Cap
Main valve opening pressure
81.4-110 kPa (11.8-15.6 psi., 0.83-1.1 kg/cm2)
Vacuum valve opening pressure
-6.86 kPa (-1.00 psi, -0.07 kg/cm2) or less
Coolant Pump
Coolant Pump
Centrifugal type impeller
Thermostat
Thermostat
Type
Wax pellet type with jiggle valve
Valve opening temperature
82°C (177°F)
Full-opening temperature
95°C (201°F)
Drive belt
Drive belt
Type
V-ribbed belt
Engine coolant temperature sender
Type
Thermistor type
Resistance
90.5-117.5Ω at 70°C (158°F)
21.3-26.3Ω at 115°C (239°F)
Engine coolant temperature sensor
Type
Heat-sensitive thermistor type
Resistance
2.27-2.273 kΩ at 20°C (68°F)
290-354Ω at 80°C (176°F)
Automatic transaxle oil cooler
Performance
1,200 Kcal/h
Oil pump
Description | Specification
Clearance between outer circumference and front case
0.12- 0.18 mm (90.0047- 0.0070 in.)
Front case tip clearance
Side clearance
Inner gear
0.02-0.065 mm (0.0008-0.0025 in.)
Outer gear
0.02-0.07 mm (0.0008-0.0027 in.)
Engine oil pressure
At engine idle speed (Oil temperature is 90 to 100°C [194 to 215°F])
166 KPa (1.7 kg/cm2 24.2 psi)
Relief spring: Free height
43.8 mm (1.742 in.)
Relief spring: Load
3.7 kg at 40.1 mm (8.15 lb/1.578 in.)
Air cleaner
Air cleaner
Type
Dry type
Element
Unwoven cloth type
Exhaust pipe
Exhaust pipe
Muffler
Expansion resonance type
Suspension system
Rubber hangers
Valve
Valve length: Intake
102.34 mm (4.029 in.)
Valve length: Exhaust
104.8 mm (4.1259 in.)
Stem O.D.: Intake
5.965-5.98 mm (0.2348-0.2354 in.)
Stem O.D.: Exhaust
5.93-5.95 mm (0.2334-0.2342 in.)
Face Angle Thickness of valve head (margin)
Face angle thickness of valve head (margin): Intake
1.15 mm (0.0452 in.)
0.8 mm (0.031 in.)
Face angle thickness of valve head (margin): Exhaust
1.35 mm (0.0531 in.)
1.0 mm (0.039 in.)
Valve stem to valve guide clearance
Valve stem to valve guide clearance: Intake
0.02-0.05 mm (0.0008-0.0019 in.)
0.10 mm (0.0039 in.)
Valve stem to valve guide clearance: Exhaust
0.05-0.085 mm (0.0019-0.0033 in.)
0.15 mm (0.059 in.)
Valve guide
Installed dimension O.D.: Intake
11 mm (0.433 in.)
Installed dimension O.D.: Exhaust
11 mm (0.433 in.)
Service size
0.05, 0.25, 0.50 mm (0.002, 0.010, 0.020 in.) oversize
Valve seat
Width of seat contact: Intake
1.1- 1.5 mm (0.043- 0.059 in.)
Width of seat contact: Exhaust
1.3- 1.7 mm (0.051- 0.066 in.)
Seat angle
45°
Oversize
0.3, 0.6 mm (0.012, 0.024 in.) oversize
Valve spring
Free length
46.07 mm (1.8137 in.)
Load
25.5 kg/37 mm
57.3 kg/28 mm
Installed height
37 mm (1.456 in.)
Squareness
1.5° or less
Valve Timing
Intake valve
Opens (BTDC)
6°
Closes (ABDC)
46°
Exhaust valve
Opens (BBDC)
50°
Closes (ATDC)
10°
Cylinder Head
Flatness of gasket surface
Max. 0.05 mm (0.0020 in.)
0.1 mm (0.0039 in.)
Flatness of manifold mounting surface
Max. 0.15 mm (0.0059 in.)
0.3 mm (0.0118 in.)
Oversize rework dimensions of valve seat hole: Intake
0.3 mm (0.012 in.) O.S.
28.8-28.825 mm (1.134-1.135 in.)
0.6 mm (0.024 in.) O.S
29.1-29.125 mm 1.146-1.1467in.)
Oversize rework dimensions of valve seat hole: Exhaust
34.3-34.325 mm (1.350-1.351 in.)
0.6 mm (0.024 in.) O.S.
34.6-34.625 mm (1.362-1.363 in.)
Oversize rework dimensions of valve guide hole (both intake and exhaust)
0.05 mm (0.002 in.) O.S.
11.05-11.068 mm (0.435-0.4357 in.)
0.25 mm (0.010 in.) O.S.
11.25-11.268 mm (0.443-0.4436 in.)
0.50 mm (0.020 in.) O.S.
11.50-11.518 mm (0.453-0.4535 in.)
Bedankt voor je reactie. Ik wist nooit dat de Coupe buiten Europa Tiburon heette. Dit verklaard een hoop voor mij. Toppie.
henkie4437 Topicstarter 730 km Reageer
Niet gevonden wat je zocht? Misschien is je vraag al eens beantwoord voor je Hyundai Coupe of stel zelf een nieuwe vraag.
