Hi,
For 2 weeks I have a new Hex-V2 and plying around. Idea was to investigate why I had misfires. Last months, I noticed light shocking engine during driving the first 1-2minutes in the cold morning. Only with dsg in 1st gear and between 1500-2000 rpm. Sometimes it takes effort to get the engine to do this, and when I keep going and hold the throttle steady, sometimes CEL goes on. However, also without CEL, I know when I read DTC I see misfires. And I was right.
Skoda Octavia 1.4TSI CHPA 2014 140 pk/bhp & 250Nm
Engine+DSG7 tuned in September 2018, 190bhp & 340Nm
Address 01: Engine Labels: 04E-907-309-V1.CLB
Control Module Part Number: 04E 906 016 G HW: 04E 907 309 A
Component and/or Version: 1,4l R4 TSI X08 5761
4 Faults Found:
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [039] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 131397 km
Date: 2019.01.30
Time: 07:35:40
Engine speed: 1925.50 /min
Normed load value: 14.9 %
Vehicle speed: 13 km/h
Coolant temperature: 11 °C
Intake air temperature: 2 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.536 V
Unlearning counter according OBD: 80
Oxygen sensor bank 1 sensor 1: specified value: 0.9688
Oxygen sensor 2 bank 1 internal resistance limit value: 131068 Ohm
Long-term fuel trim bank 1 at idle: -0.09 %
10591 - Cylinder 1
P0301 00 [039] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 131397 km
Date: 2019.01.30
Time: 07:35:51
Engine speed: 1956.50 /min
Normed load value: 14.1 %
Coolant temperature: 15 °C
Voltage terminal 30: 14.583 V
Misfire recognition reference moment: 11.469 %
Misfire sum counter: 205
Counter: implaus. short-term adapt. values: misfire detection: 0
10593 - Cylinder 3
P0303 00 [039] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 131397 km
Date: 2019.01.30
Time: 07:35:51
10592 - Cylinder 2
P0302 00 [039] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 131397 km
Date: 2019.01.30
Time: 07:35:51
Readiness: 0000 0000
Misfires occur on cylinders 1,2,3,4. It is possible the misfires occurred also before the tuning, I could not test/have not noticed this. It started during cold weather. The tuner said; first put new sparkplugs & ignition coils + fuel with RON 98. So, I replaced these plugs&coils (all BERU) in December 2018. Not solved. I am fueling octane/RON 95. Yesterday I changed to RON 98. I report back if this results in less misfires.
Logs with vcds (sorry if not all the measurements are useful). I only have adv.meas and I have no:
RFP_AV (bypass valve %)
IGA_AD_KNK[5] (in degrees; knock detection/timing pulled on cylinder)
I think these have different names in my engine/vcds:
Bypass valve f high press turboch turbine inlet: actual value
Test of knock sensors: short trip result-Test_Program_Channel 165 (not sure)
Performance log run in gear3 dsg-manual (I forgot Turbo-sampling):
https://log.malonetuning.com/chart/24639...
(click Graph – Cycle bottom axis; to get Time instead of RPM). This one to be sure turbo, air, boost etc. are not suspicious.) Does this one looks OK?
Log of a normal trip with count of misfires. Note on cyl 2 and 3 there are the most:
https://log.malonetuning.com/chart/24640...
Log of a normal trip with:
Coolant temperature
Median injection timing
Exhaust temperature 1 bank 1
Fuel high pressure: actual value
Ignition timing adjustment cylinder 1
Correction factor injector cylinder 1-2-3
https://log.malonetuning.com/chart/24641...
This looks strange to me (but possible this behavior is normal…):
https://www.dropbox.com/s/6hpg9drf2g95tq...
Maybe somebody can help solving the misfire issue. If RON 98 fuel will not help, the second step is walnut cleaning the intake and valves. With a mini camera I noticed light carbon buildup. Some say this can also be the reason. Airfilter, oil+filter is renewed last week.
If I need to make more/other logs/vcds readings, let me know!
Br,
Philippe
The Netherlands
Niet gevonden wat je zocht? Misschien is je vraag al eens beantwoord voor je Skoda Octavia of stel zelf een nieuwe vraag.
