Ik heb de volgende problemen met mijn auto:
- De cruise control werkt niet.
- Airco werkt niet.
- parkeersensoren werken niet.
Wie kan mij hiermee helpen?
Chassis Type: 7H - VW Transporter
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ5H020160 Mileage: 248060km/154137miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 997 016 D HW: 028 101 127 1
Component: R5 2,5L EDC G000AG 7596
Revision: 12345678 Serial number: VWZ7Z0D0410655
Coding: 0001075
Shop #: WSC 00181 211 05511
VCID: 1B31D35FA165
2 Faults Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 000 - - - Intermittent
Freeze Frame:
RPM: 1638 /min
Torque: 187.9 Nm
Speed: 26.0 km/h
Load: 32.2 %
Voltage: 14.29 V
Bin. Bits: 00001100
Temperature: 47.7°C
Temperature: 35.1°C
18097 - Powertrain Data Bus: Implausible Message from Elect. Load Controller
P1689 - 000 - - - Intermittent
Freeze Frame:
RPM: 798 /min
Torque: 31.7 Nm
Speed: 41.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 1.0
Readiness: 0 0 0 X 1
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No: 09K 927 750 J
Component: AQ 250 6F 0621
Coding: 0000008
Shop #: WSC 00181 211 70242
VCID: 3C7330C304AB
No fault code found.
Address 03: ABS Brakes Labels: 7H0-907-37x-ESP-F.lbl
Part No: 7H0 907 379 H
Component: ESP FRONT MK25 0202
Coding: 0006315
Shop #: WSC 02756 785 00200
VCID: 3A7F36DB0E9F
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 7H5 907 040 B
Component: CLIMAtronic T5 X 3717
Coding: 0000040
Shop #: WSC 02737 785 00200
VCID: 2A5F069BFE3F
Part No: 7H5 907 049 D
Component: Display_2_ClimaT5 X 0307
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
(no units): 2.0
Temperature: 29.0°C
Temperature: 31.0°C
Address 09: Cent. Elect. Labels: 7H0-937-049.lbl
Part No: 7H0 937 049 L
Component: BORDNETZ SGVER 1.0 1901
Coding: 0000357
VCID: 3B7133DF01A5
4 Faults Found:
01598 - Drive Battery Voltage
002 - Lower Limit Exceeded
00901 - Back-Up Lamps
012 - Electrical Fault in Circuit - Intermittent
00991 - Interior Lights
00895 - Cruise Control Switch (E45)
008 - Implausible Signal - Intermittent
Address 0D: Slide Door, Left Labels: None
Part No: 7H0 959 243 J
Component: Schiebetuer-SG 404 0320
Shop #: WSC 00000 000 00000
VCID: 397D29D70B99
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 11 AIRBAG VW61 0R 0003
Coding: 12593
Shop #: WSC 02756
VCID: 2759FFAFED2D
4 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01218 - Side Airbag Igniter; Passenger Side (N200)
32-10 - Resistance too High - Intermittent
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
25-10 - Unknown Switch Condition - Intermittent
00589 - Airbag Igniter 1; Passenger Side (N131)
33-10 - Resistance too Low - Intermittent
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H5 920 870 L
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 05112
Shop #: WSC 03433
VCID: 3A7F36DB0E9F
WV2ZZZ7HZ5H020160 VWZ7Z0D0410655
1 Fault Found:
01300 - Control Module for Navigation with CD-Rom (J401)
49-00 - No Communications
Address 18: Aux. Heat Labels: Redir Fail!
Part No: 7H0 815 071 C
Component: Standheizung 0207
VCID: 285BFC93E033
1 Fault Found:
00664 - Fuel gauge
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway KCAN 0001
Coding: 00006
Shop #: WSC 02737
VCID: F0EB54F39863
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
Address 45: Inter. Monitor Labels: Redir Fail!
Part No: 7H5 951 171 A
Component: Innenraumueberw. 2409
Coding: 0000012
Shop #: WSC 02757 785 00200
VCID: 2D550D87CFD1
Part No: 7H0 951 171 A
Component: Innenraumueberw. 1506
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: C Komfortgerát 0004
Coding: 00078
Shop #: WSC 00181
VCID: 326F1EFBD6EF
Subsystem 1 - Part No: 7H1959801A
Component: Tõrsteuer.FS KLO 0203
Subsystem 2 - Part No: 7H1959802
Component: Tõrsteuer.BF KLO 0203
1 Fault Found:
01135 - Interior Monitoring Sensors
36-10 - Open Circuit - Intermittent
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7H5 919 044 E
Component: DACHDISPLAY 0538
Revision: 00800538 Serial number: 2009267.07
Coding: 0000001
VCID: 346318E32CFB
1 Fault Found:
01336 - Data Bus for Comfort System
004 - No Signal/Communication - Intermittent
Address 76: Park Assist Labels: None
Part No: 7E0 919 283
Component: Parkingsyst. T5 T5M 801
Coding: 01127
Shop #: WSC 02756
VCID: ECD34083B44B
Address 78: Slide Door, Right Labels: None
VCID: 397D29D70B99
Address 7D: Aux. Heat Labels: None
Part No: 7H0 819 002 H
Component: Luftstandheizung, D 0424
Revision: 32020424 Serial number: 0097616
VCID: 2B51039FF1C5
1 Fault Found:
00668 - Supply Voltage Terminal 30
End ---------------------------------------------------------------------
Geplaatst door remco van der put-1 , lid sinds 5 jaar geleden
Met een groots assortiment in de beste auto-onderdelen, aanbiedingen en merken vind je altijd een optimale mix tussen A-merken en aanbiedingen. Voor iedere automobilist weet Carpardoo de juiste auto onderdelen of auto-accessoires te vinden.
0 Reacties
