Beste lezer,
Ik heb het volgende probleem. Ik heb de electrische pomp vervangen en krijg het volgende via vcds te zien:
VCDS
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 18.9.1(x64) Data version: 20190114 DS296.0
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Wednesday,23,January,2019,12:27:29:23780
VIN: WVWZZZ1KZ9W411717 License Plate:
Mileage: 185350km-115171mi Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZ9W411717 Mileage: 185350km-115171miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
VCDS
Self-Diagnosis Log
Page 2
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 AG HW: 03L 906 022 G
Component: R4 2.0l TDI G000SG 9979
Revision: 13H01--- Serial number:
Coding: 0000072
Shop #: WSC 00191 264 15243
VCID: 6A8ECBA9D07A2717209-803E
4 Faults Found:
001681 - Fan 1 Control Circuit
P0691 - 000 - Short to GND
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 185349 km
Time Indication: 0
Date: 2013.06.15
Time: 11:54:10
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 64.8°C
Temperature: -1.8°C
Lambda: 9.5 %
Lambda: 0.0 %
001152 - Coolant Fan Control Circuit 1
P0480 - 000 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 185349 km
Time Indication: 0
Date: 2013.06.15
Time: 11:54:11
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 64.8°C
Temperature: -1.8°C
Lambda: 9.5 %
Lambda: 0.0 %
001617 - Sensor Reference Voltage B
VCDS
Self-Diagnosis Log
Page 3
P0651 - 000 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 185349 km
Time Indication: 0
Date: 2013.06.15
Time: 11:54:26
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Temperature: 64.8°C
(no units): 0.0
Torque: 30.0 Nm
009754 - Coolant Pump 2
P261A - 000 - Open circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 185349 km
Time Indication: 0
Date: 2013.06.15
Time: 11:54:31
Freeze Frame:
RPM: 943 /min
Speed: 0.0 km/h
Voltage: 13.83 V
Lambda: 79.7 %
Bin. Bits: 10011111
Bin. Bits: 00000000
Temperature: 32.4°C
Readiness: 0 0 0 0 1
VCDS
Self-Diagnosis Log
Page 4
Address 03: ABS Brakes Labels:. 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0016641
Shop #: WSC 01357 011 00200
VCID: 76B6EFD994C2F3F7B41-8022
No fault code found.
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 5K0 907 044 AJ HW: 5K0 907 044 AJ
Component: Climatronic 130 0303
Revision: 00002001
Coding: 0000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 73B0D6CD8B30E6DF93F-8026
1 Fault Found:
13701888 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Motorsteuergerät - bitte Fehlerspeicher auslesen]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 74
Reset counter: 215
Mileage: 184924 km
Date: 2019.01.17
Time: 15:14:56
VCDS
Self-Diagnosis Log
Page 5
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 AE HW: 1K0 937 087 AE
Component: BCM PQ35 H+ 111 0709
Revision: AD111709
Coding: 40180A20E82110C040480080140089EC40FF04FF520101F0DC4401040000
Shop #: WSC 12345 123 12345
VCID: 74B2D5D18EBEE1E78A5-8020
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 08100 21 0501
Coding: 009795
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 215
Mileage: 185358 km
Time Indication: 0
Date: 2013.06.15
Time: 12:25:49
Freeze Frame:
Term 15 On
Voltage: 14.25 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5K0 919 475 E HW: 5K0 919 475 E
Component: PARKHILFE 8K H01 0012
Revision: -------- Serial number: 12561203803214
Coding: 100001
VCID: 382A21E1D256458766D-806C
VCDS
Self-Diagnosis Log
Page 6
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 020 0507
Serial number: 003C2D03WBG6
Coding: 00003135
ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 77A8E2DD9F488AFFAF7-8022
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V U01 ----
Serial number: 68166140ZZZZZZZZZZZZ
Crash sensor for side airbag: front passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V U01 ----
Serial number: 6E174141ZZZZZZZZZZZZ
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 103A0C25ZZZZZZZZZZZZ
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 2053001BZZZZZZZZZZZZ
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 055 0111
Coding: 0000732
VCID: 78AAE1E19ED68587A6D-802C
Subsystem 1 - Part No: 3C8 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H2ÿ 0021
Coding: 00000227
Shop #: WSC 00000
VCDS
Self-Diagnosis Log
Page 7
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 870 C HW: 5K0 920 870 C
Component: KOMBI H21 0028
Serial number: 00000000000000
Coding: 170B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 2D0400B52D94F02F05B-8078
1 Fault Found:
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 216
Mileage: 183519 km
Date: 2019.01.03
Time: 20:03:57
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 180908F2001896
Coding: E9A07F064006020002
VCID: 353428D5C944B8EF7DB-8060
VCDS
Self-Diagnosis Log
Page 8
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H21 0028
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09.rod
1 Fault Found:
9456681 - Key
B104C 29 [008] - Implausible Signal
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Mileage: 171464 km
Date: 2018.08.06
Time: 18:04:12
VCDS
Self-Diagnosis Log
Page 9
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 BX
Component: RNS-MID H02 4020
Revision: AB001001 Serial number: VWZ6Z7H9145098
Coding: 04000402000000810000
VCID: 2F381ABD2718823F377-807A
2 Faults Found:
00856 - Radio Antenna
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 215
Mileage: 185352 km
Time Indication: 0
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 215
Mileage: 185357 km
Time Indication: 0
Date: 2013.06.15
Time: 12:20:51
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1K0 959 701 AG HW: 1K0 959 701 AG
Component: Tuer-SG 008 2033
Coding: 0005302
VCID: 73B0D6CD87B0E6DF93F-8026
VCDS
Self-Diagnosis Log
Page 10
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 01324 785 00200
VCID: 2A0E0BA910FAE717E09-807E
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1K0 959 702 AG HW: 1K0 959 702 AG
Coding: 0005558
VCID: 74B2D5D182BEE1E78A5-8020
VCDS
Self-Diagnosis Log
Page 11
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 215
Mileage: 185352 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 215
Mileage: 185357 km
Time Indication: 0
Date: 2013.06.15
Time: 12:20:51
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 AL HW: 1K0 959 703 AL
Component: Tuer-SG 007 2009
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 7AAEFBE9A0DA9797D09-802E
VCDS
Self-Diagnosis Log
Page 12
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Component: Tuer-SG 007 2101
Coding: 0000144
VCID: 36362FD9D442B3F7741-8062
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 C HW: 3C8 035 730 C
Component: Telefon 012 0822
Revision: -------- Serial number: 35909603557421
Coding: 020004000100110000000400
ASAM Dataset: EV_UHVPremi A02705
ROD: EV_UHVPremi_A02.rod
VCID: 2310E68D7B50365FA3F-8076
End----------(Elapsed Time: 01:16, VBatt start/end: 13.9V/14.1V)-----------
Daarnaast zie ik op mijn dashboard auto een krul en voel ik geen vermogen als ik rijd. Weet iemand wat er aan de hand is? Mijn dank is groot.
Niet gevonden wat je zocht? Misschien is je vraag al eens beantwoord voor je Volkswagen Golf 6 of stel zelf een nieuwe vraag.
Dat is een sensorspanning vanuit de motor computer.
Als daar wat mis mee is dan krijgen diverse sensoren geen of niet de juiste spanning. Dat kan een oorzaker zijn.
Anders de bedrading van de elektrische pomp doormeten.
