I have a Toyota Carina E 1.8 from 1996 and want to build in a Vialle LPI (Gas) -System in my car:
Does anyone has (good or bad) long-time experiences with a Vialle LPI - System in his Carina E (7A-FE - engine)?
I´ve heard about problems with the lean mix - motor and especially with the valves. Although one is checking the valves every 30.000 Km and although using FLASH-LUBE, there could be damaged valves after 100 - 120.000 KM or a further correction of the valves is not possible, once again. Is this correct?
Who knows a good Vialle-LPI-Dealer (not aisb in Baarlo)?
At last: Does the LPI-pump functions very well (even after e.g. 30.000 Km)? I´ve heard about problems after a while, primarily if driving often very fast.
Please answer in english or german, if possible, because my dutch is very bad.
Bedankt!
Niet gevonden wat je zocht? Misschien is je vraag al eens beantwoord voor je Toyota Carina of stel zelf een nieuwe vraag.
martin
