Heb momenteel een foutcode in mijn Avensis D4D 2005, uitgelezen met mijn hobbyapparaat, zag de volgende code:
P0380 Glow Plug/Heater Circuit "A" Malfunction
Betekent dit 4 Gloeibougies vervangen of iets anders.
Van de winter had ie al problemen met starten.
Graag uw hulp/info.
Niet gevonden wat je zocht? Misschien is je vraag al eens beantwoord voor je Toyota Avensis of stel zelf een nieuwe vraag.
Generic OBD Error Code Details for P0380
What does this mean?
OBD Code P0380refers to
The optical sensor provides a high resolution signal to the Powertrain Control Module (PCM) by counting pulses on the sensor disk located in the injection pump. The high resolution is one of the most important inputs by the PCM for fuel control and timing. This test monitors the number of high resolution pulses which have been missed (not detected). It's based on a comparison between the number of pulses that were detected since the last pump cam pulse and the number of the pulses that should have occurred. There are approximately 64 high resolution pulses for every cam pulse.
Symptoms
Possible sumptoms of OBD code P0380
- Engine Light ON (or Service Engine Soon Warning Light)
Causes
Possible causes of OBD code P0380
- Open or short in the optical sensor circuit - Optical sensor connector - Damaged optical sensor - Damaged PCM or ECM The Error code is generally activated on detection of the following conditions: Some high resolution pulses are missing from the optical sensor to the PCM
Possible Solutions
- If damage, repair optical sensor circuit - Replaced optical sensor - Replaced PCM or ECM
